POV-Ray : Newsgroups : povray.text.scene-files : Wierd results with circular area light (Scene File) Server Time
18 Dec 2025 06:22:08 EST (-0500)
  Wierd results with circular area light (Scene File) (Message 1 to 6 of 6)
Subject: Wierd results with circular area light (Scene File)
Date: 22 Feb 2000 21:52:38
Message: <IEazOJy=+4sQqUQTE73IhliDvVnz@4ax.com>
POV-Ray Scene Description File
File Name:	Orient_Test_2.pov
Description:	Testing the circular and orient keywords
Author:		Glen Berry
Author's Email:	pho### [at] ezwvcom
Date:		02/22/2000
#version unofficial MegaPov 0.4;
global_settings { ini_option "Width=600"
                                  ini_option "Height=600"
                                  ini_option "Antialias=On"
                                  ini_option "Antialias_Threshold=0"
camera { location -z*500
                   up y
                   right x
                   angle 45
                   look_at 0
box { <-1,-1,0>, <1,1,1>
           pigment { color White }
           finish { ambient 0.2 diffuse 0.8 }
           scale <300, 300, 1>
#declare Total = 8;
#declare Count=0;
#while(Count<Total)
   cylinder { <50, 0, -50>, <50, 0, 0.1>, 10
                      pigment { color Orange }
                      rotate z*Count*(360/Total)
   #declare Count=Count+1;
// Circular Area Light, with orient?
light_source { 0
                            color rgb 1
                            area_light <40, 0, 0> <0, 0, 40> 9, 9
                            circular
                            orient
                            adaptive 0
                            jitter
                            translate -z*30
Subject: Re: Wierd results with circular area light (Scene File)
Date: 24 Feb 2000 12:21:30
Message: <38b5689a@news.povray.org>
Glenn Berry wrote:
<Snip>
>light_source { 0
>                            color rgb 1
>                            area_light <40, 0, 0> <0, 0, 40> 9, 9 <----
fault is here
>                            circular
>                            orient
>                            adaptive 0
>                            jitter
>                            translate -z*30
Replace the <40,0,0>,<0,0,40> with <-20,0,0>,<20,0,40>.
I'm not that good at explaining but you should be able to figure out the
error in your code.
Jide
Date: 24 Feb 2000 12:31:50
Message: <oGi1OPB2tv841XKqSM1u3MstZKKk@4ax.com>
>error in your code.
I appreciate your help with this. For the record, I patterned my code
after the official Windows POV insert menu. If you look at the insert
menu's entry for "area light" you will see a line that contains this:
    <8, 0, 0> <0, 0, 8>
I simply changed the 8's to 40's, thinking all was well. Actually, I
did think the line looked a little odd, but I trusted the insert menu
to be correct.
One final thought: You have a comma inserted between your vectors, but
the example in the insert menu does not. I wonder which is the most
proper syntax? I'll try both and find out, I guess.
thanks again,
Glen Berry
Date: 24 Feb 2000 12:57:00
Message: <38b570ec@news.povray.org>
>>error in your code.
>    <8, 0, 0> <0, 0, 8>
>to be correct.
I've never used the insert menu. It's a better workout for the brain when
you need to remeber every command :)
Propably the manuals <a,b,c> <d,e,f> but for some strange reason I've gotten
the <a,b,c>,<d,e,f> superimposed to my brain. It works and that's what I'm
mostly after in my code (well ok I do have pretty strict rules for tabs and
whatnot)
>thanks again,
>Glen Berry
Always glad to help whenever I can.
Jide
Date: 24 Feb 2000 13:32:07
Message: <38b57927@news.povray.org>
Glen Berry <7no### [at] ezwvcom> wrote...
>                            adaptive 0
This line is also a problem.  Either comment out this line so that you'll
use 9x9 non-adaptive, or use at least "adaptive 1".  Either of those will
increase the number of samples and thus will get rid of the artifacts.
-Nathan
Date: 24 Feb 2000 19:19:33
Message: <R8m1OPApqQRREtQoUIWNKXFvUGWz@4ax.com>
On Thu, 24 Feb 2000 13:28:50 -0500, "Nathan Kopp" <Nat### [at] Koppcom>
>>                            adaptive 0
This line was also influenced by the Win POV insert menu. It's
"default" for adaptive is 0, although it lists other values in a
comment field.
As you can imagine, I will be modifying my insert menu.   :)
I appreciate everyone's help with this.
thanks,
Glen Berry
