POV-Ray : Newsgroups : povray.text.scene-files : Lemon slice Server Time
10 Nov 2025 23:03:06 EST (-0500)
  Lemon slice (Message 1 to 2 of 2)
Subject: Lemon slice
Date: 18 Feb 2000 08:38:02
Message: <8EDE91DBBseed7@204.213.191.228>
// Persistence of Vision Ray Tracer Include File
// File: Lemon.inc
// Vers: 3.1
// Desc: Object for Grenadine.pov
// Date: 1999/06/04
// Auth: ingo
#version 3.1;
global_settings{assumed_gamma 1.0}
camera{
  location  <-3.0, 0.01, -3.0>
  look_at   <0.0, 0.0,  0.0>
  angle 45
light_source{
  <500, 550, -100>
  rgb 1
#declare SS=seed(7);
#declare R_uit= 3;
#declare R_in=2.9;
#declare Ring = difference {
   cylinder {< 0  , 0, 0>, <1  , 0, 0>, R_uit}
   cylinder {<-0.1, 0, 0>, <1.1, 0, 0>, R_in}
#declare R2_uit= 0.8;
#declare R2_in=0.7;
#declare Ring2 = difference {
   cylinder {< 0  , 0, 0>, < 1  , 0, 0>, R2_uit}
   cylinder {<-0.1, 0, 0>, < 1.1, 0, 0>, R2_in}
#declare LemonOut= intersection {
   merge {
      difference {
         merge {
            object {Ring translate < 0.01, 0, (R_uit+R_in)/2>}
            object {Ring translate <-1.01, 0,-(R_uit+R_in)/2>}
         box {<-1.1, 0.1,-1>, <1.1, 2, 1>}
      difference {
         box {<-1, 0,-(R_uit-R_in)/2>, < 1, 1.1, (R_uit-R_in)/2>}
         box {
            <-2.5, 0,-1>, <2.5, 2, 1>
            translate <0, 0.5, 0>
            rotate <0, 0,-20>
      difference{
         object {
            Ring2
            translate <-0.5, 0, 0>
            scale <2.2, 1, 1>
            translate < 0, 0, (R2_uit+R2_in)/2>
         box {<-2.1, 0,-1>,<2.1,-3, 1>}
         translate <0, 0.499999, 0>
         rotate <0, 0,-20>
   merge {
      cylinder {<0, 0,-0.5>, <0, 0, 0.5>, 0.8}
      torus {0.8, 0.2 scale <1, 1.1, 1> rotate <90, 0, 0>}
#declare BS1= array[24] {
   < 24.8, 49.8>, < 13.0, 31.4>, <  4.0,  8.8>, <  0.1,  9.4>
   <  0.1,  9.4>, <- 7.4, 10.7>, <-12.5, 30.4>, <-21.1, 49.8>
   <-21.1, 49.8>, <-33.3, 76.9>, <-39.8, 87.0>, <-29.2, 91.4>
   <-29.2, 91.4>, <-20.0, 95.3>, <-10.0, 95.9>, <  0.0, 95.9>
   <  0.0, 95.9>, < 10.0, 95.9>, < 21.3, 95.8>, < 30.0, 90.7>
   < 30.0, 90.7>, < 41.3, 84.0>, < 45.1, 86.5>, < 24.8, 49.8>
#declare BS2= array[24] {
   < 24.8, 55.8>, < 13.0, 31.4>, <  4.0,  8.8>, <  0.1, 15.0>
   <  0.1, 15.0>, <- 7.4, 10.7>, <-12.5, 30.4>, <-21.1, 49.8>
   < 30.0, 90.7>, < 41.3, 84.0>, < 45.1, 86.5>, < 24.8, 55.8>
#declare BS3= array[24] {
   < 23.0, 49.8>, < 13.0, 31.4>, <  4.0,  8.8>, <  0.1,  6.0>
   <  0.1,  6.0>, <- 7.4, 10.7>, <-12.5, 30.4>, <-21.1, 49.8>
   < 30.0, 90.7>, < 41.3, 84.0>, < 45.1, 85.0>, < 23.0, 49.8>
#declare BS4= array[24] {
   < 24.8, 49.8>, < 13.0, 31.4>, <  4.0, 11.8>, <  0.1,  9.0>
   <  0.1,  9.0>, <- 7.4, 13.7>, <-12.5, 30.4>, <-21.1, 49.8>
   <-21.1, 49.8>, <-33.3, 76.9>, <-39.8, 87.0>, <-21.2, 91.4>
   <-21.2, 91.4>, <-20.0, 95.3>, <-10.0, 95.9>, <  0.0, 95.9>
#declare J=0;
#declare Part1= prism {
   bezier_spline
   -0.5, 0.5, 24,
   #while (J<24)
      #declare P= BS1[J];
      P
      #declare J=J+1;
   scale < 0.0095, 1, 0.0095>
#declare J=0;
#declare Part2= prism {
   bezier_spline
   -0.5, 0.5, 24,
   #while (J<24)
      #declare P= BS2[J];
      P
      #declare J=J+1;
#declare J=0;
#declare Part3= prism {
   bezier_spline
   -0.5, 0.5, 24,
   #while (J<24)
      #declare P= BS3[J];
      P
      #declare J=J+1;
#declare J=0;
#declare Part4= prism {
   bezier_spline
   -0.5, 0.5, 24,
   #while (J<24)
      #declare P= BS4[J];
      P
      #declare J=J+1;
#declare LemonTex= texture {
      granite
      scale <0.2,5,1>
      colour_map {
         [0.4 rgbf <1,0.65,0,0.4>]
         [0.6 rgbf <1,0.8,0,0.4>]
         [0.7 rgbf <1,0.9,0,0.6>]
         [0.9 rgb <1,0.7,0>*1.5 ]
   normal {granite -0.1 turbulence 0.3 scale <0.2,5,1>}
   finish {
      specular .9
      roughness 0.01
#declare Parts= union {
   object {Part1 }
   object {Part2 rotate <0,   360/7 ,0>}
   object {Part3 rotate <0,2*(360/7),0>}
   object {Part4 rotate <0,3*(360/7),0>}
   object {Part1 rotate <0,4*(360/7),0>}
   object {Part2 rotate <0,5*(360/7),0>}
   object {Part3 rotate <0,6*(360/7),0>}
   rotate <90,0,0>
#declare LemonSlice = union {
   intersection {
      object {LemonOut}
      object {Part1 rotate <90,0,0>}
      texture {LemonTex rotate <90,0,0> translate rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part2 rotate <0,360/7,0> rotate <90,0,0>}
      texture {LemonTex rotate <0,360/7,0> rotate <90,0,0> translate
rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part3 rotate <0,2*(360/7),0> rotate <90,0,0>}
      texture {LemonTex rotate <0,2*(360/7),0> rotate <90,0,0> translate
rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part4 rotate <0,3*(360/7),0> rotate <90,0,0>}
      texture {LemonTex rotate <0,3*(360/7),0> rotate <90,0,0> translate
rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part1 rotate <0,4*(360/7),0> rotate <90,0,0>}
      texture {LemonTex rotate <0,4*(360/7),0> rotate <90,0,0> translate
rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part2 rotate <0,5*(360/7),0> rotate <90,0,0>}
      texture {LemonTex rotate <0,5*(360/7),0> rotate <90,0,0> translate
rand(SS)*5}
   intersection {
      object {LemonOut}
      object {Part3 rotate <0,6*(360/7),0> rotate <90,0,0>}
      texture {LemonTex rotate <0,6*(360/7),0> rotate <90,0,0> translate
rand(SS)*5}
   difference {          //outside
      object {LemonOut}
      object {Parts}
         cylindrical
         rotate <90,0,0>
         texture_map {
            [0.05, pigment {rgb <1,0.8,0>}
                   normal {granite .1 scale 0.1}
                   finish {phong 0.8 phong_size 20}
            [0.06, pigment {rgb <1,0.9,0.7>}
                   normal {granite .07 scale 0.5}
//object { LemonSlice}
Ingo
Subject: Re: Lemon slice
Date: 18 Feb 2000 17:42:19
Message: <38adcacb@news.povray.org>
This is a great slice of fruit!  Easily as complex as the real thing  ;-)  I was
thinking before I tried a render of it that the script seemed overdone for such
a simple object but I can see why now.
