POV-Ray : Newsgroups : povray.text.scene-files : random picture colloge Server Time
6 Oct 2024 10:17:54 EDT (-0400)
  random picture colloge (Message 1 to 1 of 1)
Subject: random picture colloge
Date: 23 Sep 2000 20:36:43
Message: <7688.301T2372T12265085PeterC@nym.alias.net>
This silly little .pov script will make a random
colloge of images.  Four images are stacked (as if they
were photoshop layers) and randomly faded.
        Before running the script, add/edit the add_image()
calls to use your images.  It is a work in progress so the
code is sort of haphazard.  Still, it's neat enough that I
thought some of you would find it interesting.
  randomly composite pics, sort of like wasshinames "Picture Garden"
  proggy on the miggy.
#ifndef (rseed)
  #declare rseed = seed(24875300);
#declare amiga = true; // set to false for windows gamma
global_settings {
  #if (amiga = true)
    assumed_gamma 2.4
  #else
    assumed_gamma 2
  number_of_waves 10
  max_trace_level 20
  location 0
  orthographic
  right <1, 0, 0>
  up <0, 1, 0>
  translate <0, 0, -10>
#macro do_random_pure_color()   // returns an RGB vector
  #local xx = int(6 * rand(rseed));
  #switch (xx)
    #case (0)
      #local rcolor = <1, rand(rseed), 0>;
      #break
    #case (1)
      #local rcolor = <1, 0, rand(rseed)>;
      #break
    #case (2)
      #local rcolor = <rand(rseed), 1, 0>;
      #break
    #case (3)
      #local rcolor = <rand(rseed), 0, 1>;
      #break
    #case (4)
      #local rcolor = <0, 1, rand(rseed)>;
      #break
    #else
      #local rcolor = <0, rand(rseed), 1>;
  rcolor // return color
// if you use png, add a png type.
#declare tga_type = 0;
#declare gif_type = 1;
#declare iff_type = 2;
#declare sys_type = 3;
#declare max_pics = 50;
#declare num_pics = 0;
#declare pic_list = array[max_pics]
#declare pic_type_list = array[max_pics]
#macro add_pic(pic_type, pic_name)
  #declare pic_type_list[num_pics] = pic_type;
  #declare pic_list[num_pics] = pic_name
  #declare num_pics = num_pics + 1;
/* Here is where you put in the name of your image files!
   Have one "Add_pic" call per picture */
add_pic(tga_type, "ea1_big.tga")
add_pic(tga_type, "alexie-saile.tga")
add_pic(tga_type, "otrek_br_1.tga")
add_pic(gif_type, "pmk_tanker.gif")
add_pic(tga_type, "devo_control_room.tga")
add_pic(tga_type, "pipe_corridor.tga")
add_pic(tga_type, "room_br.tga")
add_pic(tga_type, "trek_space2.tga")
add_pic(tga_type, "trek_space3.tga")
add_pic(tga_type, "trek_space4.tga")
// pick & make first layer
#declare which_pic = int(num_pics * rand(rseed));
#declare back_zone = pigment {
  image_map {
    #switch(pic_type_list[which_pic])  // bitmap type
      #case (gif_type)
        gif
        #break
      #case (iff_type)
        iff
        #break
      #case (sys_type)
        sys
        #break
      #else
        tga
    pic_list[which_pic] // bitmap name
  translate <-0.5, -0.5, 0>
// pick & make second layer
#declare middle_zone = pigment {
  image_map {
      #case (gif_type)
        gif
        #break
      #case (iff_type)
        iff
        #break
      #case (sys_type)
        sys
        #break
      #else
        tga
// pick & make top layer
#declare top_zone = pigment {
  image_map {
      #case (gif_type)
        gif
        #break
      #case (iff_type)
        iff
        #break
      #case (sys_type)
        sys
        #break
      #else
        tga
// pick & make layer above top layer
#declare extra_top_zone = pigment {
  image_map {
      #case (gif_type)
        gif
        #break
      #case (iff_type)
        iff
        #break
      #case (sys_type)
        sys
        #break
      #else
        tga
#declare clear = texture {
  pigment { color rgbt <1, 1, 1, 1> }
  finish { ambient 1 diffuse 0 }
#macro do_layer_sweep(pigm, z_off)
  #if (rand(rseed) > 0.5)
    #local which_dir = <1, 0, 0>;
  #else
    #local which_dir = <0, 1, 0>;
  polygon {
    5,
    <-0.5, 0.5, z_off>,
    < 0.5, 0.5, z_off>,
    < 0.5, -0.5, z_off>,
    <-0.5, -0.5, z_off>,
    <-0.5, 0.5, z_off>
      gradient which_dir
      #local g1 = 0.5 * rand(rseed);
      #local g2 = (1 - g1) * rand(rseed);
      #local g2 = max(0.2, g2);
      #local g2 = g2 + g1;
      texture_map {
        [ g1  clear ]
        [ g2
              pigment { pigm translate 0.5 * which_dir }
      } // end of texture map
      translate -0.5 * which_dir
      #if (rand(rseed) > 0.2)
        scale <-1, 1, 1>  // reverse (flip) picture left-right
    } // end of texture
  } // end of box
#macro do_layer_frame(pigm, z_off)
  #local g1 = 0.2 + 0.2 * rand(rseed);
  #local t1 = texture {
    gradient <0, 1, 0>
    frequency 2
    texture_map {
      [ 1 - g1  clear ]
      [ 1
            pigment { pigm }
  } // end of texture local
  polygon {
    5,
    <-0.5, 0.5, z_off>,
    < 0.5, 0.5, z_off>,
    <-0.5, 0.5, z_off>
      gradient <1, 0, 0>
      frequency 2
      texture_map {
        [ 1 - g1   t1 ]
        [ 1        pigment { pigm } finish { ambient 1 diffuse 0 } ]
  } // end of box
#macro do_layer_spot(pigm, z_off)
  #render "\ndo layer spot\n"
  #local which_offset = int(5 * rand(rseed));
  #switch (which_offset)
    #case (0)
      #local poffset = <-1/6, -1/6, 0>;
      #break
    #case (1)
      #local poffset = <-1/6, 1/6, 0>;
      #break
    #case (2)
      #local poffset = < 1/6, -1/6, 0>;
      #break
    #case (2)
      #local poffset = < 1/6, 1/6, 0>;
      #break
    #else
      #local poffset = <0, 0, 0>;
    spherical
    translate poffset
    texture_map {
      [ 0.75  clear ]
      [ 0.9
            pigment { pigm translate -poffset }
  polygon {
    5,
    <-0.5, 0.5, z_off>,
    < 0.5, 0.5, z_off>,
    <-0.5, 0.5, z_off>
      t1
  } // end of box
#macro do_layer_mix(pigm, z_off)
  polygon {
    5,
    <-0.5, 0.5, z_off>,
    < 0.5, 0.5, z_off>,
    <-0.5, 0.5, z_off>
      average
      texture_map {
        [ 2 clear ]
  } // end of box
#macro do_layer(pigm, z_off)
  #local which_method = int(5 * rand(rseed));
  #switch (which_method)
    #case (0)
      #break
    #case (1)
    #case (2)
      #break
    #case (3)
      #break
    #else
polygon {
  5,
  <-0.5, 0.5, 0>,
  < 0.5, 0.5, 0>,
  < 0.5, -0.5, 0>,
  <-0.5, -0.5, 0>,
  <-0.5, 0.5, 0>
  // do back layer
    pigment { back_zone }
// do middle layer
do_layer(middle_zone, -0.01)
// do top layer
do_layer(top_zone, -0.02)
// do extra top layer
do_layer(extra_top_zone, -0.02)
/* actual end of this file */
