On 15/09/2018 11:58, Stephen wrote:
> rotate <20.000,0.000,0.000>
That might be -19 to -21 not rotate 20*x
Regards
On 9/15/2018 6:58 AM, Stephen wrote:
> On 15/09/2018 11:43, Mike Horvath wrote:
>> I have textures, but do not know how to orient them with respect to
>> the axial tilt, orbit and sun. Is anyone familiar with how to do this?
>> Mike
> For Z up Left handed scenes.
> texture {
> pigment {
> image_map{
> png "F:\Graphics\B3D Data\Maps\Planets\Earth\EarthMap2.png"
> interpolate 2
> map_type 1
> Then for orientation in an orbit. Rotate the sphere the planet texture
> will follow.
Thanks. But which direction does the axis tilt with respect to the Sun
on a given day?
Mike
>>> Mike
>> texture {
>> pigment {
>> image_map{
>> interpolate 2
>> map_type 1
>> will follow.
> on a given day?
Earth currently has an axial tilt of about 23.4° and the angle does not
change. With respect to the Sun on a given day, it depends on there it
is in its orbit.
https://en.wikipedia.org/wiki/Axial_tilt#Earth
So if you start your Planetarium at the summer or winter equinox. The
mechanics will take care of themselves.
I think. :)
Regards
Latest version is attached. It is *very* close, but the Earth is off by
about one month's worth of travel.
Here is the document I am using as a guide:
https://ssd.jpl.nasa.gov/txt/aprx_pos_planets.pdf
And I am using this website to compare my render to:
https://in-the-sky.org/solarsystem.php
Set it to JD 2458376.5, which is equivalent to A.D. 2018 Sep 15.
I am not sure where my calculations have gone wrong.
Mike
Download 'orrery_sphere_trail_new.pov.txt' (25 KB)
> Mike
If you zoom out, Jupiter is also in the wrong place, so Maybe my results
are *not* so close after all.
Mike
Updated the scene. It is working correctly now.
Mike
Download 'orrery_sphere_trail_b.pov.txt' (29 KB)
