POV-Ray : Newsgroups : povray.text.scene-files : L*C*h(uv) functions Server Time
17 Mar 2026 08:00:49 EDT (-0400)
  L*C*h(uv) functions (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: L*C*h(uv) functions
Date: 21 Nov 2016 18:50:38
Message: <5833884e$1@news.povray.org>
On 11/21/2016 4:33 PM, Mike Horvath wrote:
> On 11/21/2016 4:23 PM, clipka wrote:
>> So if I understand you correctly, the shape you want is exactly the
>> volume for which R, G and B are all within the range from 0 to 1.
> Yes, exactly!
>> That sounds like a job for an isosurface to me.
>> Variant A: Create six isosurfaces, each representing one of the
>> boundaries (R<0, G<0, B<0, R>1, G>1, B>1), and intersect them.
>> Variant B: Refactor the functions from variant A, so that they have the
>> same threshold, combine them using max() or min() to achieve the
>> intersection effect, and turn that into a single isosurface.
> I don't know how to do either variant. :(
> Mike
Forgot to add that I want to use polar coordinates (if that makes a
difference).
Mike
Date: 21 Nov 2016 19:46:28
Message: <58339564$1@news.povray.org>
> Am 21.11.2016 um 21:56 schrieb Mike Horvath:
>>>> Actually, I can create a pigment already. But I don't know how to use
>>>> the functions in a isosurface or a parametric to make the 3D object the
>>>> pigment gets applied to, if possible.
>>>> Mike
>>> Oops! You'll need to know these as well.
>>> #declare correctRGB1 = function(R,G,B) {min(max(R,0),1)}
>>> #declare correctRGB2 = function(R,G,B) {min(max(G,0),1)}
>>> #declare correctRGB3 = function(R,G,B) {min(max(B,0),1)}
>> That is wrong. The RGB values should *not* be corrected. In fact, if any
>> of R, G or B are outside the range of 0 to 1, then the coordinate/color
>> should be discarded. Sorry!
I am trying random things now.
isosurface
	function {max(convertLCH2RGB_R(x,y,z), 1)}
	contained_by
		box {-2,+2}
//	threshold FLOAT_VALUE
	accuracy	0.01
	max_gradient	5
//	[evaluate P0, P1, P2]
//	open
//	[max_trace INTEGER] | [all_intersections]
	pigment {rgb 1}
This takes a long time to render, but there's nothing visible happening.
Mike
Date: 21 Nov 2016 23:22:15
Message: <5833c7f7$1@news.povray.org>
I tried this as well.
parametric
	function { convertLCH2RGB_R(u,100,v) }
	function { convertLCH2RGB_G(u,100,v) }
	function { convertLCH2RGB_B(u,100,v) }
	<0,0>, <100,360>
	contained_by
		box {-2,+2}
	max_gradient	5
	accuracy	0.01
	precompute	10 x,y,z
	pigment {rgb 1}
The render is too slow. The pps is below 100 and still dropping.
Mike
Date: 22 Nov 2016 02:30:45
Message: <5833f425$1@news.povray.org>
Am 22.11.2016 um 01:46 schrieb Mike Horvath:
> isosurface
throw away the max() function, and take care of the polar-ish coordinate
system by replacing:
with:
    convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x/z)*pi/180)
(presuming you want L up and I got the math right)
>     contained_by
>         box {-2,+2}
... and use threshold 1. That should give you something visible.
>     accuracy    0.01
>     max_gradient    5
> //    open
>     pigment {rgb 1}
> Mike
Date: 22 Nov 2016 02:33:02
Message: <5833f4ae$1@news.povray.org>
>> isosurface
> with:
>>     contained_by
>>         box {-2,+2}
>>     accuracy    0.01
>>     max_gradient    5
>> //    open
>>     pigment {rgb 1}
>> Mike
THANK YOU!!
However atan2 requires two parameters and your math only has one.
Mike
Date: 22 Nov 2016 02:44:13
Message: <5833f74d@news.povray.org>
Am 22.11.2016 um 08:33 schrieb Mike Horvath:
> THANK YOU!!
Sorry, try atan2(x,z).
Date: 22 Nov 2016 02:45:52
Message: <5833f7b0$1@news.povray.org>
>> THANK YOU!!
Here is the whole file again with your changes. The shape I get when I
render is that of a pointy cap. I don't know if that's correct or not.
Mike
Download 'utf-8' (7 KB)
Date: 22 Nov 2016 03:31:26
Message: <5834025e$1@news.povray.org>
Am 22.11.2016 um 08:45 schrieb Mike Horvath:
>>> THANK YOU!!
How would I know -- I'm not familiar with that colour model.
Now you need to intersect that shape with the five others -- or use the
combined function:
    min(
      convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      convertLCH2RGB_G(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      convertLCH2RGB_B(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_G(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_B(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180)
should do the job, I think.
Date: 22 Nov 2016 03:43:51
Message: <58340547$1@news.povray.org>
On 11/22/2016 3:31 AM, clipka wrote:
>     min(
I think the last parameter should be atan2(x,z)*180/pi because atan2
returns radians and convertLCH2RGB_R expects degrees.
Also, here's a rough approximation of what the surface should look like.
https://commons.wikimedia.org/wiki/File:Cielch_color_solid_cylinder.png
But with smooth curves instead of blocky sections.
Mike
Date: 22 Nov 2016 03:44:21
Message: <58340565$1@news.povray.org>
>     min(
Forgot to say that the above just results in a cube.
Mike
