POV-Ray : Newsgroups : povray.text.scene-files : Updated screen.inc Server Time
13 Nov 2026 08:59:42 EST (-0500)
  Updated screen.inc (Message 1 to 18 of 18)
Subject: Updated screen.inc
Date: 3 Nov 2016 21:31:29
Message: <581be4f1$1@news.povray.org>
I posted this a few years a go, but recently did a few tweaks to fixed
compatibility issue with the original version.
Mike
Download 'screen.inc.txt' (8 KB)
Subject: Re: Updated screen.inc
Date: 3 Nov 2016 21:36:48
Message: <581be630@news.povray.org>
> Mike
Forgot to add a test scene.
Mike
Download 'axonometric_projection_comparison.pov.txt' (10 KB)
Date: 4 Nov 2016 09:14:28
Message: <581c89b4$1@news.povray.org>
There is no license statement with your file.  It is evident that you
based your modifications on a pre-3.7 version of the file, and as such,
it would bear the license of that version of POV-Ray, but there is no
indication of that to the user.
You should be aware that there was a change to macro Screen_Object in
version 3.7.  If you are considering this change, note that it will
cause a parse error in versions 3.5 and 3.6.*.
Date: 30 Aug 2018 21:32:06
Message: <5b889a96@news.povray.org>
I updated the script slightly. There is now also the license, and I
incorporated the official changes to the Screen_Object macro.
Mike
Date: 30 Aug 2018 21:36:50
Message: <5b889bb2$1@news.povray.org>
> Mike
Why does it save and restore the version, but not change it?
dik
Rendered 1024 of 921600 pixels (0%)
Date: 30 Aug 2018 22:38:14
Message: <5b88aa16@news.povray.org>
>> Mike
I forgot about that. What should I do instead?
Mike
Date: 30 Aug 2018 22:58:35
Message: <5b88aedb$1@news.povray.org>
I would just delete those two lines, they are unnecessary.
dik
Date: 30 Aug 2018 23:07:48
Message: <5b88b104@news.povray.org>
Okay. Unfortunately, the file has never had any version numbers, so all
the different versions floating around (I'm not the only one) are hard
to keep straight.
Mike
Date: 30 Aug 2018 23:10:09
Message: <5b88b191$1@news.povray.org>
Another update, with more of Dick's tips.
Mike
Date: 31 Aug 2018 09:28:44
Message: <5b89428c$1@news.povray.org>
Am 31.08.2018 um 04:58 schrieb dick balaska:
A smarter approach would be to leave them in, and add a `#version 3.7`
(or some such) indicating the minimum version of POV-Ray known to work
with the include file.
Date: 5 Sep 2018 17:43:47
Message: <5b904e13$1@news.povray.org>
I added the version check back in. It should work in POV 3.7 and later now.
Mike
Date: 15 Sep 2018 02:29:53
Message: <5b9ca6e1$1@news.povray.org>
I noticed I let a bug slip in that was causing the "Screen_Object()"
macro to fail. I have attached the updated script.
Mike
Date: 15 Sep 2018 18:50:00
Message: <web.5b9d8c4ad61dfd43a47873e10@news.povray.org>
> Mike
Thanks! Haven't tried it out yet, but will.
I made a few changes of my own to the original screen.inc years ago-- to improve
its precision with HIGH-res cylindrical height_fields and such, when made there.
(and also figured out where to add an 'inside vector' to such things, for use in
CSG.) I hope I can find the old code at some point; I think I lost it :-(
Date: 23 Jun 2019 22:40:00
Message: <5d103800$1@news.povray.org>
I discovered a lot of bugs that I didn't notice before.
These updated versions may work better. There are new test cases in the
demo scene. Let me know if they're not working.
Michael
Download 'screen_mjh.inc.txt' (9 KB) Download 'screen_mjh.pov.txt' (10 KB)
Date: 25 Jun 2019 03:32:00
Message: <5d11cdf0@news.povray.org>
Some small tweaks, as well as some notes.
NOTES (MJH)
* Camera_Angle and Camera_Zoom are ignored by Mode 2.
* Outputted Camera_Look_At is incorrect with Mode 2 when orthographic
   projection is disabled. Not sure this can be fixed.
* In my opinion, Set_Camera_Angle and Set_Camera_Zoom should disregard
   Camera_Aspect_Ratio. Instead, Camera_Aspect_Ratio should be handled
   at other points in the code. However, altering this behavior could
   affect old scenes.
Download 'screen_mjh.inc.txt' (10 KB) Download 'screen_mjh.pov.txt' (10 KB)
Date: 25 Jun 2019 03:34:33
Message: <5d11ce89$1@news.povray.org>
> NOTES (MJH)
>    affect old scenes.
Additional note:
Is it even possible to determine the look_at point when you are using
location, direction, right, and up and perspective projection?
Michael
Date: 25 Jun 2019 03:37:32
Message: <5d11cf3c$1@news.povray.org>
Oops, I forgot to trim some test code that causes experimental behavior.
I have attached the unaffected code to this post.
Michael
Download 'screen_mjh.inc.txt' (10 KB) Download 'screen_mjh.pov.txt' (10 KB) Download 'notes.txt' (1 KB)
Date: 25 Jun 2019 06:04:17
Message: <5d11f1a1@news.povray.org>
Made some minor tweaks, and updated the documentation. These are
probably the last changes I will make unless there is feedback.
Michael
Download 'screen_mjh.inc.txt' (11 KB) Download 'screen_mjh.pov.txt' (10 KB) Download 'notes.txt' (1 KB)
