POV-Ray : Newsgroups : povray.text.scene-files : Something weird with gamma and the camera Server Time
12 Jul 2025 06:32:17 EDT (-0400)
  Something weird with gamma and the camera (Message 1 to 5 of 5)
Subject: Something weird with gamma and the camera
Date: 24 Jan 2016 07:15:43
Message: <56a4c06f@news.povray.org>
Take a look at the scene I attached.
Look for the line:
#declare camera_eye = -1; // -1 = no eye, 0 = left eye, 1 = right eye
Render the scene. Then change the above variable to 0 or 1 and render
the scene again.
Why are the colors so different between the two renders?
Mike
Download 'ldr_androbot_mech_new_stereoscopic_test.pov.txt' (583 KB)
Subject: Re: Something weird with gamma and the camera
Date: 24 Jan 2016 10:52:49
Message: <56a4f351$1@news.povray.org>
Am 24.01.2016 um 13:15 schrieb Mike Horvath:
Because you're not paying attention to the parse warnings ;)
------ (camera_eye=-1)
Parse Warning: assumed_gamma not specified, so gamma_correction is
turned off for compatibility with this pre POV-Ray 3.7 scene. See the
documentation for more details.
Parse Warning: This scene did not contain a #version directive. Please
be aware that as of POV-Ray 3.7, unless already specified via an INI
option, a #version is expected as the first declaration in a scene file.
POV-Ray may apply settings to some features that are
intended to maintain compatibility with pre-3.7 scenes. You are strongly
encouraged to add a #version statement to the scene to make your intent
clear. Future versions of POV-Ray may make the presence of a #version
statement mandatory.
In other words: Your scene has no "#version" statement at all => POV-Ray
now presumes a legacy scene, so you get 3.6 gamma handling defaults
(which is no gamma handling).
------ (camera_eye=0)
Possible Parse Error: assumed_gamma not specified in this POV-Ray 3.7 or
later scene. Future versions of POV-Ray may consider this a fatal error.
To avoid this warning, explicitly specify 'assumed_gamma 1.0' in the
global_settings section. See the documentation for
more details.
Parse Warning: This scene had other declarations preceding the first
#version directive. Please be aware that as of POV-Ray 3.7, unless
already specified via an INI option, a #version is expected as the first
declaration in a scene file. If this is not done, POV-Ray
may apply compatibility settings to some features that are intended to
make pre-3.7 scenes render as designed. You are strongly encouraged to
add a #version statement to the scene to make your intent clear. Future
#version mandatory.
In other words: Your scene has a belated "#version 3.7" statement => you
get 3.7 gamma handling defaults (which is "assumed_gamma 1.0").
"But where does this '#version 3.7' statement come from?" you might ask.
The secret lies in the inclusion of "transforms.inc", which you only
pull in for camera_eye=0 or 1:
As is customary for library include files, it does specify its own
"#version" statement, so that future versions of POV-Ray may invoke
backward compatibility mode for that paticular file in case they
introduce some breaking changes to functionality. However, in order to
not break the main scene's "#version" choice, it needs to revert the
change at the end of the file; this is done using the following
construct (which also acts as a guard against double inclusion):
    #ifndef(FOO_INC_TEMP)
    #declare FOO_INC_TEMP = version;
    #version 3.5; // for example
    // include file content goes here
    #version FOO_INC_TEMP
Enter a quirk of the version handling as of version 3.7: As you can
infer from the warning you get, as long as you don't specify a
"#version" directive the /effective/ SDL version will be 3.6, because we
presume that anything without a "#version" statement is a legacy scene.
*But* the "version" pseudo-variable will return 3.7 (or whatever is the
actual version of the POV-Ray binary you are running) in this case.
This is to allow scenes to have "#version" as their very first statement
(which is officially a mandatory requirement for 3.7 and later scenes),
but still be able to adapt to the actual version used, by employing a
construct like the following:
    #version version;
    #if (version >= 3.70)
      #version 3.7; // use 3.7 features if we can have them
      #declare Subsurface_On = yes;
    #else
      #version 3.6; // need at least 3.6
    #endif
Thus, if you don't explicitly specify a "#version" directive, you'll get
3.6 behaviour by default, but including any standard include file will
effectively set "#version 3.7" at the end of that include.
Date: 24 Jan 2016 18:31:52
Message: <56a55ee8$1@news.povray.org>
> more details.
> #version mandatory.
>      #end
>      #version version;
>      #else
>      #endif
Thanks for clearing this up! The file was created using an LDraw to
POV-Ray converter. For some reason they bundle the program along with
POV-Ray 3.7 even though issues like these can easily arise. I will
forward this information along to the group.
Mike
Date: 25 Jan 2016 03:50:03
Message: <web.56a5dfff85b549be33c457550@news.povray.org>
> .... However, in order to
>     #end
Thanks for that. It's the best explanation I've seen for why that code is
placed at the beginning and end of all built-in #include files. I have to admit
that I've never fully understood the code's full purpose until now.
The way that the #version directive is described in the documentation may have
been part of the reason why I didn't fully grasp it.  The docs give this
example...
#local Temp_Vers = version;  // Save previous value
#version 1.0;              // Change to 1.0 mode
..... // Version 1.0 stuff goes here...
#version Temp_Vers;        // Restore previous version
IMO, the comment "Save previous value" (or version) in that first line should
instead say, "Save current version", as that is what is really meant there.  (I
do now realize that, when including an #include file in a scene, the SCENE's
#version would be the meaning of "previous value"-- but it's a little bit
confusing, when read 'out of context' in the docs there.)
A question out of curiosity (and using your #include file example above of the
variable name #ifndef(FOO_INC_TEMP) : Is the reason for using such 'odd'
variable names in #include files (of which some *are* rather odd) so that the
chances of it being an *actual* variable name in a scene file are very low? In
other words, are they purposely odd so that they won't be confused with other
scene file variables that we would normally think to use? OR does it matter at
all? (as #include files use #local variables, not #declared ones)
By the way, in the 3.7 documentation concerning #version for SCENE use, it says
(in error?), "Naturally the default setting for this option is #version 3.5."
Should that say 3.62 now?
Date: 25 Jan 2016 09:15:00
Message: <web.56a62d0485b549bead6fa18f0@news.povray.org>
Yes, that's exactly the rationale behind the variable name. This is of
particular importance if the include file use "#declare" instead of "#local",
which some files do (and actually all files should, unless they are supposed to
be included multiple times) to detect whether they have been included before.
Looks like that portion of the docs is very much outdated.
