POV-Ray : Newsgroups : povray.text.scene-files : ObjectToDF3Example.pov for creating DF3 files with povray directly. Server Time
13 Sep 2025 17:11:07 EDT (-0400)
  ObjectToDF3Example.pov for creating DF3 files with povray directly. (Message 1 to 1 of 1)
Subject: ObjectToDF3Example.pov for creating DF3 files with povray directly.
Date: 22 Sep 2013 21:27:52
Message: <523f9918$1@news.povray.org>
All,
I worked up a povray only solution for creating df3 files using objects
grouped by color in the 0-1 unit space & the relatively new
ARRAYS_WriteDF3() of arrays.inc.
As part of the attached code I have documented several DF3 issues I've
found the hard way and I'll duplicate that information here so it
eventually shows up in searches.
Notes on DF3 files in general no matter how used. Someday I'll have the
time to put together a tutorial with images. Perhaps one or more explain
why folks sometimes struggle with DF3 files.
1) Today we have 3 DF3 density file interpolation techniques 0,1 and 2.
0 = NO_INTERPOLATION, 1 = TRILINEAR_INTERPOLATION and 2 =
TRICUBIC_INTERPOLATION.
    - The 0 interpolation type is voxel centered.
    - The 1 & 2 types are vertice centered, shifting everything lower
1/2 voxel.
      - If mixing the two types this is important to understand,
especially with smaller DF3 files where the shift is relatively more
substantial. Functions in isosurfaces or patterns can re-align.
2) Interpolation type 2 rings / wobbles when there are any surface
protrusions, or when say a plane of one value has a larger or smaller
value inserted in that plane. If using type 2 for anything you want to
be numerically stable, use multiple single value coincident DF3 files. I
tend not to use option 2 at all.
    a) Further, if the ring goes below 0 or above 1 it gets clamped at 0
or 1.
3) Keep your DF3 data away from the array edges for interpolation types
1 & 2.
    - Both techniques implement edge wrapping / handling which mangle
things near the DF3 edges.
    - I'm now adding a buffer of 5 df3 voxels around meaningful inner
values.
Bill P.
Download 'utf-8' (7 KB)
