POV-Ray : Newsgroups : povray.text.scene-files : Merry Christmas Server Time
15 Apr 2026 20:47:10 EDT (-0400)
  Merry Christmas (Message 1 to 6 of 6)
Subject: Merry Christmas
Date: 23 Dec 2010 09:48:20
Message: <4d136134@news.povray.org>
See image in p.b.i.
Paolo
Download 'us-ascii' (16 KB)
Subject: Re: Merry Christmas
Date: 23 Dec 2010 18:54:46
Message: <4d13e146@news.povray.org>
> See image in p.b.i.
> Paolo
Nome advices:
Don't use assumed_gamma. It's deprecated.
hf_gray_16 should be left out. When using version 3.7, you need to use a
command line switch.
max_intersextion is deprecated and phased out. It may cause an error in
future versions.
number_of_wave should be left out most of the time. If you set it, it's
good practice to reset it to 10 at the end of the scene.
For the media, intervals default to 1 and MUST be left at that value.
(default value = 1 with method 3, was 10 when using method 1)
samples only use a single value. That value should always be larger than
3 and default to 10. You can put a second value, but it will always be
silently ignored.
ratio is not used. (was used with method 1)
The values used in your scene are left over from version 3.1 and earlier
that used sampling method 1. Since version 3.5, the default is sampling
method 3.
When using radiosity, diffuse 1.3 can give unexpected over brightening.
Without radiosity, diffuse plus ambient should total 1 or less to have a
realistic result.
Date: 23 Dec 2010 20:32:07
Message: <4d13f817$1@news.povray.org>
Am 24.12.2010 00:54, schrieb Alain:
Shouldn't be necessary any longer, as that value is now properly
initialized to the default before each render.
Date: 23 Dec 2010 22:28:10
Message: <4d14134a@news.povray.org>
Good thing. The problem is for version 3.6 users, it still not corrected
for them.
Date: 27 Dec 2010 04:20:16
Message: <4d185a50$1@news.povray.org>
>Alain  on date 24/12/2010 00:54 wrote:
>> See image in p.b.i.
>> Paolo
> Nome advices:
> hf_gray_16 should be left out.[...]
> Alain
Alain, Clipka, thank you for your notes, I'll revise my templates!
Paolo
Date: 27 Dec 2010 04:24:49
Message: <4d185b61@news.povray.org>
  Actually that's still an open question. No assumptions should be made
until a final official 3.7 release.
