POV-Ray : Newsgroups : povray.text.scene-files : Re: Announce: IsoCSG include file 0.2.1 Server Time
18 Apr 2026 05:56:51 EDT (-0400)
  Re: Announce: IsoCSG include file 0.2.1 (Message 1 to 10 of 14)
Subject: Re: Announce: IsoCSG include file 0.2.1
Date: 14 Mar 2002 08:31:23
Message: <4a919u88sccs10t78e21ssgf4aimjlm1s0@4ax.com>
On Wed, 13 Mar 2002 14:36:39 +0100, Christoph Hormann <chr### [at] gmxde>
wrote:
> I fixed a few problems since i posted the first version in p.b.s-f.  Also
> wrote some documentation and an add-on for the Povray 3.5 insert menu.
> http://www.tu-bs.de/~y0013390/pov/ic/index.html
Here is proposition of IC_Box macro with function returning linear distance to
the box shape.
#macro IC_Box( Start , End )
  #local Start=Start+<0,0,0>;
  #local End=End+<0,0,0>;
  #local Cx=max(Start.x, End.x);
  #local Cy=max(Start.y, End.y);
  #local Cz=max(Start.z, End.z);
  #local Dx=min(Start.x, End.x);
  #local Dy=min(Start.y, End.y);
  #local Dz=min(Start.z, End.z);
  #local Inside=function{pattern{object{box{ Start , End }}}};
  function(x, y, z){
    select(
      Inside(x,y,z),
      0,
      f_r(min(x-Dx,max(x-Cx,0)),min(y-Dy,max(y-Cy,0)),min(z-Dz,max(z-Cz,0))),
      max(x-Cx, y-Cy, z-Cz, Dx-x, Dy-y, Dz-z)
ABX
Date: 14 Mar 2002 09:06:20
Message: <3C90AE5C.92DFE7CA@gmx.de>
> the box shape.
Nice, now you just need the same for cylinders and cones and fix the scale
macro to maintain the linear distance (i'm not sure if that's possible)
and it will be a perfect distance function for all 'merge' CSGs...
BTW, wouldn't the f_rounded_box() function be faster in this case?
Last updated 13 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 14 Mar 2002 09:11:09
Message: <gkb19ucue9hip9eo1sr8g29oe5v85oq8e3@4ax.com>
On Thu, 14 Mar 2002 15:06:20 +0100, Christoph Hormann <chr### [at] gmxde>
Currently I'm changing cylinder. Cone will be next :-)
> and fix the scale
It is only possible for <a,a,a> scale I think.
That's what was my intention.
I tried this f_rounded_box solution at first but I'm not sure it returns
linear distances after scaling so I did it myself.
ABX
Date: 14 Mar 2002 11:14:16
Message: <i0j19u4tb02n2dkmc7qv3np7vkoo5k703h@4ax.com>
On Thu, 14 Mar 2002 15:06:20 +0100, Christoph Hormann <chr### [at] gmxde> wrote:
#macro IC_Cylinder (Start, End, Radius)
  #local Center = <0,0,0>+(Start+End)/2;
  #local Cx=Center.x;
  #local Cy=Center.y;
  #local Cz=Center.z;
  #local Len=vlength(End-Center);
  #if (Len=0)
    #error "iso_csg.inc: Error: zero height cylinder"
  #local fn_T=function { Reorient_Trans(End-Center, x)  }
  #local fn_X=
  function(x, y){
    select(x,max(x,y),select(y,max(x,y),f_r(x,y,0)))
  #local fn_Y=
  function(x, y, z){
    fn_X( abs(fn_T(x, y, z).x)-Len, f_r(0,fn_T(x, y, z).y,fn_T(x, y, z).z)-Radius)
  function(x, y, z){
    (fn_Y((x-Cx),(y-Cy),(z-Cz)))
ABX
Date: 15 Mar 2002 05:43:07
Message: <luj39usb6135jfhup6m7kk4s5b8u3557gp@4ax.com>
> Nice, now you just need the same for cones
#macro IC_Cone (Start, Radius1, End, Radius2)
  #switch(select(Radius1-Radius2,-1,0,1))
    #case(0)
      IC_Cylinder (Start, End, Radius1)
    #break
    #case(-1)
      #local temp=Start;
      #local Start=End;
      #local End=temp;
      #local temp=Radius1;
      #local Radius1=Radius2;
      #local Radius2=temp;
    #else
      #local Cx=Start.x;
      #local Cy=Start.y;
      #local Cz=Start.z;
      #local Len=vlength(End-Start);
      #if (Len=0)
        #error "iso_csg.inc: Error: zero height cone"
      #local fn_T=function { Reorient_Trans(End-Start, x)  }
      #local Edge=vnormalize(<Len,Radius1-Radius2,0>);
      #local Ex=Edge.x;
      #local Ey=Edge.y;
      #local fn_X=
        function(x, y){
          select(
            x,
            select(
              y-Radius1,
              -x,                                   // under bottom
              f_r(x,y-Radius1,0)                    // bottom rounded edge below
bootom plane
            select(
              x*Ex-Ey*(y-Radius1),
              f_r(x,y-Radius1,0),                   // bottom rounded edge above
bootom plane
              select(
                x*Ey+y*Ex-Radius1*Ex,
                max(-x,x-Len,x*Ey+y*Ex-Radius1*Ex), // inside and above top cone
                select(
                  x*Ex-Ey*y-(Ex*Len-Ey*Radius2),
                  x*Ey+y*Ex-Radius1*Ex,             // outside edge
                  select(
                    y-Radius2,
                    x-Len,                          // above top
                    f_r(x-Len,y-Radius2,0)          // top rounded edge
      #local fn_Y=
        function(x, y, z){
          fn_X( fn_T(x, y, z).x, f_r(0,fn_T(x, y, z).y,fn_T(x, y, z).z))
      function(x, y, z){
ABX
Date: 15 Mar 2002 07:43:39
Message: <3C91EC7C.8364088@gmx.de>
Wow, those selects can really confuse...
I think both these and the 'B' versions should be in separate include
files since they are purely optional.
I have not tried yet, but i suppose using f_rounded_box() is faster than
your version while the cylinder/cone macros are better than a manual
translation of the rounding macros from 'shapes.inc' with radius 0.
I will also add a 'compensated' version of scale to maintain the linear
distance as good as possible (correcting with the average of the scales
with non isotropic scaling).
Date: 15 Mar 2002 08:01:13
Message: <ger39ucvme0mk53clgkv44p8fmu4ttbelj@4ax.com>
On Fri, 15 Mar 2002 13:43:40 +0100, Christoph Hormann <chr### [at] gmxde>
Yes. Perhaps You, Tor or someother fan of functions will find simpler version
but it was simples I found. But all rounded versions are only slightly slower
than yours sharp shapes.
Yes, currently I have 3 file on my machine
iso_csg - your
iso_rcsg - rounded version
iso_bcsg - bounding layer
iso_bcsg doesn't contain #include of #iso_csg or #iso_bcsg so it works with
both (depending what was included by user)
> your version
I suppose. Internall codec works much faster than VM code as f_r() shows. But
I only affraid about characteristic outside of surface with threshold 0 - does
it saves linear distance ?
You can look into p.b.i at sample image.
Great.
ABX
Date: 15 Mar 2002 08:31:01
Message: <7qt39ukhkjdj5gt1gah4q5k6palf1rma51@4ax.com>
wrote:
> Here is proposition of ...
#macro IC_Inverse(Fn)
  function{-Fn(x,y,z)}
ABX
Date: 15 Mar 2002 09:41:27
Message: <3C920815.8F29C292@gmx.de>
I think so.
Date: 22 Mar 2002 04:38:47
Message: <olul9u8hc942jc3as41bkn2pv8v7ve9ful@4ax.com>
#macro IC_Threshold ( F , Threshold )
  function{ F(x,y,z) - Threshold }
threshold is not a part of csg but this macro can be usefull when you want
combine isosurfaces with different thresholds
ANX
