POV-Ray : Newsgroups : povray.text.scene-files : Code for the Missile image posted Server Time
10 Dec 2025 20:09:22 EST (-0500)
  Code for the Missile image posted (Message 1 to 1 of 1)
Subject: Code for the Missile image posted
Date: 12 May 2006 03:30:03
Message: <4464397b@news.povray.org>
#include "glass.inc"
#include "stars.inc"
#include "shapes.inc"
#include "functions.inc"
#declare showFire = true;
#declare showSmoke = true;
//  location  <0,0,-25>
//  look_at   <10, -3,  0>
  location  <-40,-25,-25>
  look_at   <0, -3,  0>
//  location  <0,20,-1>
//  look_at   <0, 0,  0>
global_settings {max_trace_level 12 }
light_source  {
  <-500, 2000, -500>
  color White
  //area_light <50,0,0>,<0,0,50> 3,3
  //jitter
  //adaptive 1
  media_interaction on
  media_attenuation on
background { color <0.25,0.35,0.80> }
light_group {
union   {
        // sensor
        box     {
                <0, .2 , .2>,
                <-.1, -.2, -.2>
                                leopard scale <20,.01,.01>
                                pigment_map     {
                                                [0 Orange*1.2]
                                                [.099 Orange*1.2]
                                                [.1 Black]
                                                [1 Black]
                        finish  {
                                specular .1
                                roughness .001
                                ambient 0
        // glass sphere
        sphere  {
                <0,0,0>,.4
                scale <.7,1,1>
                interior{
                        ior 1.4
                                //Clear
                                rgbt <0.858824,0.576471,0.439216,.9>
                        finish  {
                                specular .5
                                roughness .1
                                reflection      { 0..5 }
                                ambient 0
        // missile body
        union   {
                cone    {
                        <0,0,0>,.5,
                        <3,0,0>,1
                cylinder{
                        <3,0,0>,
                        <9,0,0>,1
                cone    {
                        <9,0,0>,1,
                        <13.5,0,0>,1.4
                cylinder{
                        <13.5,0,0>,
                        <20,0,0>,1.4
                cone    {
                        <20,0,0>,1.4,
                        <21.5,0,0>,1
                #declare r1 = 0;
                #while(r1 < 4)
                        prism   {
                                linear_spline
                                0,.1,3,
                                <0,0>,<1,0>,<1,.8>
                                rotate <-90,0,0>
                                translate <4,1,0>
                                rotate <r1*90,0,0>
                                scale 1
                        #declare r1 = r1 + 1;
                #declare r1 = 0;
                #while(r1 < 4)
                        prism   {
                                linear_spline
                                0,.1,5,
                                <0,0>,<5,0>,<5.2,.8>,<4.9,1.8>,<2,1.8>
                                rotate <-90,0,0>
                                translate <14,1.4,0>
                                rotate <r1*90,0,0>
                                scale 1
                        pigment { White *1.5  }//*1.5
                        finish  {
                                specular .2
                                roughness 0.001
                                ambient 0
                        normal  {
                                bumps scale .0001
                                bump_size .01
        translate <-21.5,0,0>
        rotate <30,0,0>
#if(showSmoke = true)
// smoke oject
#declare pObject = union {
        cone    {
                <2,0,0>,0,
                <15,0,0>,2
        cylinder{
                <15,0,0>,
                <1000,0,0>,2
//smoke trail
cylinder        {
                <2,0,0>
                <1000,0,0>,
                4
                hollow
        interior        {
                        media   {
                                intervals 5 //5  higher slows it up and
gives smoother images
                                samples 5  //5 lower = more blocky
                                method 3
                                absorption 0.2
                                scattering      {
                                                1,color  Gray25
                                                extinction .4//1.2 //amount
of above color subtracted as it passes through, darkens the cloud
                                density {
                                        pigment_pattern { object {pObject}}
// pattern of the media
                                        warp    { turbulence <.5,1,1> }
                                        color_map       {
                                                        [0 rgb 0]
                                                        [.45 rgb 0]
                                                        [.5 rgb 1]
                                                        [1 rgb 1]
                texture { pigment { Clear } }
#if(showFire = true)
//jet exhaust
difference      {
                sphere  {
                        <0,0,0>,
                        1
                box     {
                        <0,4,4>,
                        <-4,-4,-4>
                hollow
                scale <40,2,2>
                interior        {
                                media  {
and gives smoother images
                                       emission .3 //1    brightness of
glowing media
                                       density  {
                                                spherical scale <50,3,3>
                                                warp    {
                                                        turbulence
<.8,.07,.05>
                                                density_map     {
        [0 rgb 0]
        [.6 rgb 0]
        [.7 color
Yellow]
        [.8 color
Yellow]
        [.9 color
White]
        [1 color
White]
                                Clear
//cloud scape
light_source  {
  <0, -1000,0>
  color White*.1
  media_interaction off
global_lights on
}// end of light_group
union {
   plane {
      y, 260
         finish {ambient 0 diffuse 0.7}
            bozo turbulence 1.00 translate 200*y
            color_map {
               [0.5, rgb 1 transmit 1.0]
               [1.0, rgb 1 transmit 0.6]
            scale 0.125
         scale 1500
   plane {y, 240}
         bozo turbulence 0.35 translate 300*y
         color_map {
            [0.8, rgb 1 transmit 0.5]
         scale 10 warp {turbulence 0.7} scale 1/10
         scale 0.125
      scale 2500
      finish {ambient 0 diffuse 0.5}
         bozo turbulence 0.35 translate 400*y
         color_map {
            [0.8, rgb 1 transmit 0.4]
         scale 0.125
      scale 2500
   hollow double_illuminate
   //scale 1/200
   no_shadow
   translate <0,0,100>
   rotate <40,0,-20>
POV Tips and Hints at ...
http://povman.blogspot.com/
