POV-Ray : Newsgroups : povray.text.scene-files : Fitting a box into the view (was Re: A simple geometry problem for you...) Server Time
16 Apr 2026 02:10:48 EDT (-0400)
  Fitting a box into the view (was Re: A simple geometry problem for you...) (Message 1 to 1 of 1)
Subject: Fitting a box into the view (was Re: A simple geometry problem for you...)
Date: 14 Nov 2005 15:50:56
Message: <4378f8b0@news.povray.org>
JRG wrote on povray.off-topic:
> Suppose you have a bounding box, aligned with the axes. Then you have a
> camera, placed in a known location, pointing towards a known
> direction... and the up vector can be any direction. You also know the
> horizontal and vertical FOVs. Now suppose you want to transform the
> camera in order to make the bounding box fit the view as close as
> possible. You want to preserve its original direction and FOV, thus
> moving its location and its interest only.
And here goes a povray script showing my solution to this not-so-trivial
problem ;-)
A sample result and a figure illustrating the algorithm are in
povray.binaries.images.
I'm posting this in case anyone needs it in the future...
Vincent
Download 'bb.pov.txt' (7 KB)
