POV-Ray : Newsgroups : povray.text.scene-files : Ball RIP scene file Server Time
15 Mar 2026 05:06:04 EDT (-0400)
  Ball RIP scene file (Message 1 to 1 of 1)
Subject: Ball RIP scene file
Date: 20 Dec 2004 14:48:31
Message: <41c72c8f$1@news.povray.org>
Scene Source Follows
// -w1152 -h864
global_settings
     max_trace_level 20
camera
     location <0, 0.2, -1>
     look_at <0.4, 0.3, 3>
     focal_point <0.4, 0.3, 2.2>
     blur_samples 128
     confidence .9
     variance 1/64
     aperture 0.2
global_settings
     radiosity
         pretrace_end 0.003
         //normal on
        // media on
default { finish { ambient 0 diffuse 0.7 } }
light_source
     <-7, 3,-7>, rgb 120
     fade_power 2
     fade_distance 1
     spotlight radius 5 falloff 15 tightness 50 point_at <0,1,3>
     area_light x*2,y*2,2,2 circular orient adaptive 1
light_source
     <5, -.5,-20>, rgb 200
     fade_power 2
     fade_distance 1
     spotlight radius 35 falloff 45 tightness 0 point_at <0,1,3>
     area_light x*10,y*10,2,2 circular orient adaptive 1
//light_group
light_source
     <4, 5, 9>, rgb 180
     fade_power 2
     fade_distance 1
     spotlight radius 5 falloff 10 tightness 50 point_at <0,.5,3>
     area_light x*.5,y*.5,2,2 circular orient adaptive 1
     sphere{
      0,1
      hollow
      texture
               checker rgb 0.25 filter 1 rgb 0.75 filter 1
             scale <.5,1,1>*0.075
             warp { spherical }
         finish
             specular 0.7 roughness 0.001
             reflection { 0.3, 1.0 fresnel on }
             conserve_energy
      interior
         //ior 1.5
         media { scattering {4,rgb <0.70,0.85,1>*10} samples 15
intervals 1}
         media { absorption rgb <0.5,0.8,1>*120 samples 25 intervals 1
                 density {
                     agate
                     //turbulence 1
                     scale .15
                     density_map
                         [0.00 rgb 0.0]
                         [0.01 rgb 0.5]
                         [0.99 rgb 0.8]
                         [0.99 rgb 1.0]
                         [1.00 rgb 1.0]
      rotate x*12
      rotate z*35
      rotate y*15
      translate z*3+y*.5
    // global_lights 1}
plane { y, -0.50000000001 texture {
         checker
                     wood  rotate x*.5 translate x*10 turbulence 0.1
scale 0.005
                     color_map
                         [0.0 rgb <0.3, 0.2, 0.1>*2.2]
                         [1.0 rgb <0.2, 0.1, 0.0>*2.2]
                     warp { repeat x*0.20 offset 0.002}
                 normal {
                     gradient x 1.0 scale <0.2,1,1>
                     slope_map {
                         [0.00 <0.0, 0.0>]
                         [0.05 <0.05, 0.0>]
                         [0.95 <0.05, 0.0>]
                         [1.00 <0.0, 0.0>]
                 finish {
                     phong 1.0 phong_size 50
                     reflection {0.2, 1 falloff 2}
scale 0.005
                     color_map
                         [0.0 rgb <0.3, 0.2, 0.1>*3]
                         [1.0 rgb <0.2, 0.1, 0.0>*3]
                 normal {
                     slope_map {
                         [0.00 <0.0, 0.0>]
                         [0.05 <0.05, 0.0>]
                         [0.95 <0.05, 0.0>]
                         [1.00 <0.0, 0.0>]
                 finish {
                 rotate y*90
         scale 0.7
         rotate y*-18
~Mike
