POV-Ray : Newsgroups : povray.text.scene-files : Cellular Automata Server Time
29 Aug 2025 16:06:52 EDT (-0400)
  Cellular Automata (Message 1 to 2 of 2)
Subject: Cellular Automata
Date: 10 Nov 2004 09:00:00
Message: <41921ee0$1@news.povray.org>
1-Dimensional (elementary) case.  More info here:
http://mathworld.wolfram.com/ElementaryCellularAutomaton.html
See PBI for two examples.  The thing I like about this algorithm is that
you merely need to enter the number of the rule (0 - 255) and the code
does the rest.
Dave Matthews
Download 'us-ascii' (4 KB)
Subject: Re: Cellular Automata
Date: 15 Nov 2004 20:26:06
Message: <4199572e@news.povray.org>
Why does it look out of focus?
Are 3D glasses needed?
d.
"Dave Matthews" <ns### [at] nospamedu> wrote in message
news:41921ee0$1@news.povray.org...
> does the rest.
> Dave Matthews
> //Cellular Automata (1-Dimensional) Realization by Dave Matthews
> // For reference, see
> // This array builds from bottom up, rather than top down, as in
> // the Mathworld examples.
> //Several Necessary Macros
> //This first macro converts a number (R_N) from 0 to 255 to entries in an
array.
> //(The array should be initialized to all
> //zeros, and the lowest place value starts at entry 0, to highest at entry
7.)
> #macro Fill_Rule (R_array, R_N)
>   #local Place = 0;
>   #local Quot = R_N;
>   #while (Place < 8 & Quot > 0)
>   #declare R_array[Place]=mod(Quot,2);
>   #local Quot = (Quot - R_array[Place])/2;
>   #local Place = Place + 1;
>   #end
> #end
> //This next macro uses a state array (O_A) of length _Len, and a rule
array (R_A) to
> //create the next state array (N_A).  The convention is used that the end
cells are deadened by permanent zero cells.
> #macro Next_Gen (O_A,N_A,_Len,R_A)
>   #local Place = 2*O_A[0] + O_A[1];
>   #declare N_A[0]=R_A[Place];
>   #local J = 1;
>   #while (J < _Len-1)
>     #local Place = 4*O_A[J-1] + 2*O_A[J] + O_A[J+1];
>     #declare N_A[J] = R_A[Place];
>     #local J = J + 1;
>   #end
>   #local Place = 4*O_A[_Len-2]+2*O_A[_Len-1];
>   #declare N_A[_Len-1] = R_A[Place];
> #end
> //Here we create a colored array of boxes,
> //with the color defined by
> //<State of Left Neighbor, State of Cell, State of Right Neighbor>
> //in each generation.  I know, it calculates one more row than it uses,
the "interested reader" can fix that.
> #macro Box_Realization (_Init_Array,_L,N_of_G,Rule_Number)
> union {
> #declare Obj = box {0, 1};
> #declare Rule_Array =  array[8];
> #local Dum = 0;
> #while (Dum < 8)
>   #declare Rule_Array[Dum] = 0;
>   #local Dum = Dum + 1;
> #end
> Fill_Rule(Rule_Array, Rule_Number)
> #declare _Old_Array = _Init_Array;
> #declare _New_Array = _Init_Array;
> #local Which_Gen = 0;
> #while (Which_Gen < N_of_G)
>   object { Obj pigment { color rgb <0, _New_Array[0], _New_Array[1]>*2 }
translate <0, 0, Which_Gen>}
>   #local K = 1;
>   #while (K < _L - 1)
>     object { Obj pigment { color rgb <_New_Array[K-1], _New_Array[K],
_New_Array[K+1]>*2 } translate <K,0,Which_Gen> }
>    #local K = K + 1;
>   #end
>   object { Obj pigment { color rgb <_New_Array[_L-2], _New_Array[_L-1],
0>*2 } translate <_L-1,0,Which_Gen> }
>   #declare _Old_Array = _New_Array;
>   Next_Gen(_Old_Array,_New_Array,_L,Rule_Array)
>   #local Which_Gen = Which_Gen + 1;
> #end
> #end
> //  Here we make the initializations
> //  This is where the fun parts come in!
> //  Just enter a rule number -- must be an integer, 0 - 255, I didn't trap
for errors!
> #declare Rule = 73;
> //  This is the width of your array
> #declare Number_Of_Cells = 101;
> #declare Initial_State = array[Number_Of_Cells];
> //  Here's where the initial state array is filled.  You can do this
manually, or according to a
> //  pattern of your choice.  A common approach is to just put one live
cell in the middle of the array.
> #local Fill = 0;
> #while (Fill < Number_Of_Cells)
> #if (Fill=23 | Fill=27 | Fill=62 | Fill=63)
> #declare Initial_State[Fill] = 1;
> #else #declare Initial_State[Fill] = 0;
> #end
> #local Fill = Fill+1;
> #end
> // Here's the "height" of the array.  Note that since the edge conditions
are "always dead after the edge"
> // they can cause "interference" as the number of generations increases.
> #declare Number_Of_Generations = 100;
> // Here's the picture!
> object {
Box_Realization(Initial_State,Number_Of_Cells,Number_Of_Generations,Rule) }
> background { color rgb 0.7 }
> light_source { 1000 rgb 1 }
> camera { angle 70 right x*image_width/image_height up y
>          location <Number_Of_Cells/2, Number_Of_Cells,
Number_Of_Generations/2>
>          look_at  <Number_Of_Cells/2, 0, Number_Of_Generations/2>
