POV-Ray : Newsgroups : povray.text.scene-files : Modified Circle Text Macro (labels) Server Time
30 Jun 2024 04:19:05 EDT (-0400)
  Modified Circle Text Macro (labels) (Message 1 to 1 of 1)
Subject: Modified Circle Text Macro (labels)
Date: 13 Jan 2004 18:34:36
Message: <4004808c$1@news.povray.org>
/* the macro belongs in ..\includes\shapes.inc file, caution if overwriting
previous macro! */
/* BEGIN MODIFIED CIRCLE TEXT MACRO */
// Circle_Text author: Ron Parker
/* Circle_Text( Font, Text, Size, Spacing, Thickness, Radius, Inverted,
                Justification, Angle )
Creates a text object with the bottom (or top) of the character cells
aligned
with all or part of a circle.  This macro should be used inside an
object{...}
block.
         Font: The font to use (see the documentation for the text object)
         Text: The text string to be created
         Size: The height of the text string, as you would use to scale a
               standard text object
      Spacing: The amount of space to add between the letters.
    Thickness: The thickness of the letters (see the documentation for the
               text object)
       Radius: The radius of the circle along which the letters are aligned
     Inverted: If this parameter is nonzero, the tops of the letters will
               point toward the center of the circle.  Otherwise, the
bottoms
               of the letters will do so.
Justification: One of the constants Align_Left, Align_Right, or Align_Center
        Angle: The point on the circle from which rendering will begin.  The
               +x direction is 0 and the +y direction is 90 (i.e. the angle
               increases anti-clockwise.
        Label: Orient to imaginary cylinder surface. Values -1 to 1 go from
               angles -90 to +90, with 0 being top of text toward +z.
               This is not aligned to y-axis! Think wood pattern, -z to +z.
#macro Circle_Text(F, T, S, Sp, Th, R, I, J, A, L)
   #local FW = Text_Width(F, T, S, Sp);
   #local TO = text {ttf F T 1 0 scale<S, S, 1>}
   #local TH = max_extent(TO).y;
   #local C = array[strlen(T)]
   #if(FW > 2*pi*R)
      #error concat("\n\n**** Text string \"", T, "\" is too long for a
circle of the specified radius.\n\n\n")
   #local AW = -FW*180/pi/R;
   #local SA = A;
   #local EA = A + AW;
   #if(((J = Align_Right) & !I)|((J = Align_Left) & I))
      #local SA = A - AW;
      #local EA = A;
   #else
      #if(J = Align_Center)
         #local SA = A - AW/2;
         #local EA = A + AW/2;
   #local CI = 1;
   #while(CI <= strlen(T))
      #local OE = Text_Width(F, substr(T,CI,1), S, Sp);
      #local LW = Text_Width(F, substr(T,1,CI), S, Sp) - OE;
      #local LA = SA + AW*LW/FW + OE/2/FW*AW;
      #if(I)
         #local LA = EA - (LA - SA);
      #local TO = text {ttf F substr(T, CI, 1) Th 0 scale<S,S,1>}
   #local CA = L; // added bottle label orientation. Bob Hughes
      #if(I)
         #local C[CI-1] =
         object {TO
            rotate 180*z
            rotate -90*CA*x
            translate <OE/2, TH, 0>
            rotate -90*z
            translate R*x
            rotate LA*z
      #else
         #local C[CI-1] =
         object {TO
            rotate 90*CA*x
            translate -OE/2*x
            rotate -90*z
            translate R*x
            rotate LA*z
      #local CI = CI + 1;
   // Create the final object, a union of individual text object letters.
   union {
      #local CI=0;
      #while(CI < strlen(T))
         object {C[CI]}
         #local CI = CI + 1;
/* END MODIFIED CIRCLE TEXT MACRO */
/* BEGIN EXAMPLE SCENE */
#include "shapes.inc"
camera {location <0,1.5,-3.5> look_at 0}
light_source {<5,5,-20> rgb 1 shadowless}
background {rgb 1}
cylinder {<0,0,-1>,<0,0,1>,1
 pigment { // use object pigment pattern
object {
 Circle_Text(
  "cyrvetic.ttf",
  "Centered text, not inverted",
  .2, 0.0, .03, 1.01, false, Align_Center, 90, 1
 color rgbf <1,1,1,0.9>,
 color rgb 0
 rotate -90*x
/* END EXAMPLE SCENE */
Bob H.
http://www.3digitaleyes.com
