![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
i stumbled across this old scene files last week
where i tried to implement an idea that Clifford
Pickover mentions in one of his marvelous books
("Mazes for the Mind: Computers and the unexpected",
Clifford A. Pickover, St. Martin's Press, New York).
in chapter 45, "Squashed Worlds That Pack Infinity
into a Cube", p.249), he describes a simple method
to do exactly this.
i was interested how various objects would look like
in zenospace, and so i wrote this little scene.
- feel free to improve or extend it!
please note that there are two versions of the
sphere function. - i guess that the second one
is just a little faster. i did not verify this,
though.
BTW, there is more in cliff's books that also
inspired me, he even did some raytracing himself.
you'll find amazing pictures there! - to find out
more, please see
http://www.pickover.com/
(his homepage)
and
http://RealityCarnival.Com
(his newest homepage ;)
and
http://sprott.physics.wisc.edu/pickover/neoreality.html
(a page about his neoreality novels)
if you want to find out more about his work.
..and click on the links below to visit my own site,
where you will find even more about raytracing,
programming and other things i do!
gimi
- ok, and here is the source:
<source>
// zeno.pov
// by gim### [at] psico ch - http://www.psico.ch
#default {
color rgbt < .5, .5, .5, 0 >
finish {
ambient .9 diffuse .1
phong 0.4 phong_size 200
specular .4 roughness .2
// infinite plane in a box
// arguments:
// a,b,c : plane (xyz) parameters,
// r : plane distance,
// as in "ax + by + cz = r"
#declare f_zeno_plane = function(a,b,c, r, x,y,z) {
a * atanh(x)
+ b * atanh(y)
+ c * atanh(z)
+ r
// finite sphere in a box - first version
// arguments:
// a,b,c : sphere center point
// r : sphere radius
#declare f_zeno_sphere1 = function(a,b,c, r, x,y,z) {
sqrt(
pow(atanh(x)-a, 2)
+ pow(atanh(y)-b, 2)
+ pow(atanh(z)-c, 2)
) - r
// finite sphere in a box - second version
// arguments:
#declare f_zeno_sphere2 = function(a,b,c, r, x,y,z) {
pow(atanh(x)-a, 2)
) - pow(r, 2)
isosurface {
function {
f_zeno_plane(
4, 16, -8, +2,
x,y,z
// cut off "noise"
contained_by { box { -.999999, +.999999 } }
threshold 0
accuracy .01
evaluate 1, 1.1, 0.90
translate -2.1*x
isosurface {
function {
f_zeno_sphere1(
0.8, -0.5, -1, 1.5,
x,y,z
// cut off "noise"
threshold 0
accuracy .01
evaluate 10, 1.1, 0.90
isosurface {
function {
f_zeno_sphere2(
0.8, -0.5, +1, 1.5,
x,y,z
// cut off "noise"
threshold 0
accuracy .01
translate +2.1*x
sky_sphere {
gradient y ramp_wave
color_map {
[ 0.000/6 color rgbft <1,1,0, 0,0> ]
[ 1.000/6 color rgbft <0,1,0, 0,1> ]
[ 1.001/6 color rgbft <0,1,0, 0,1> ]
[ 2.000/6 color rgbft <0,1,1, 0,0> ]
[ 3.000/6 color rgbft <0,0,1, 0,1> ]
[ 3.001/6 color rgbft <0,0,1, 0,1> ]
[ 4.000/6 color rgbft <1,0,1, 0,0> ]
[ 5.000/6 color rgbft <1,0,0, 0,1> ]
[ 5.001/6 color rgbft <1,0,0, 0,1> ]
[ 6.000/6 color rgbft <1,1,0, 0,0> ]
location <0,4,-8>
look_at 0
angle 45
light_source {
<0,10,0>
color rgb 1
</source>
mailto:gim### [at] psico ch
http://www.psico.ch/
http://psico.servehttp.com/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the links. How would you translate the function:
y = cos(n*x*acos(x))
into POV syntax?
Thanks much,
Dennis
"gimi" <gim### [at] psico ch> wrote in message news:3E3### [at] psico ch...
> hi,
> to do exactly this.
> though.
> more, please see
> (his homepage)
> and
> and
> gimi
> <source>
> // zeno.pov
> #default {
> texture {
> pigment {
> finish {
> // arguments:
> a * atanh(x)
> + b * atanh(y)
> + c * atanh(z)
> + r
> // arguments:
> sqrt(
> pow(atanh(x)-a, 2)
> ) - r
> // arguments:
> pow(atanh(x)-a, 2)
> ) - pow(r, 2)
> isosurface {
> function {
> f_zeno_plane(
> 4, 16, -8, +2,
> x,y,z
> // cut off "noise"
> threshold 0
> accuracy .01
> translate -2.1*x
> isosurface {
> function {
> f_zeno_sphere1(
> 0.8, -0.5, -1, 1.5,
> x,y,z
> // cut off "noise"
> threshold 0
> accuracy .01
> isosurface {
> function {
> f_zeno_sphere2(
> 0.8, -0.5, +1, 1.5,
> x,y,z
> // cut off "noise"
> threshold 0
> accuracy .01
> translate +2.1*x
> sky_sphere {
> pigment {
> color_map {
> camera {
> location <0,4,-8>
> look_at 0
> angle 45
> light_source {
> <0,10,0>
> color rgb 1
> </source>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> into POV syntax?
(the name "y" is used by povray itself, so i'll rename it to
"_y"; for the same reason, you will probably not use "x" either)
#declare _y = cos(n*_x*acos(_x));
HTH
gimi
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
