POV-Ray : Newsgroups : povray.text.scene-files : Missing glows in 3.5? An alternative solution Server Time
5 Oct 2024 09:02:25 EDT (-0400)
  Missing glows in 3.5? An alternative solution (Message 1 to 10 of 13)
Subject: Missing glows in 3.5? An alternative solution
Date: 14 Sep 2001 08:40:41
Message: <3ba1fac9@news.povray.org>
One of the features not included in 3.5 were glows. Of course it's a pitty
because they are so useful, but the code was so incomplete and it was such
a late addition that it wasn't included.
  If you miss glows but want to use 3.5 anyways, you can replace them with
media.
  Of course using media is a lot slower (because media sampling is slower and
because the containers increase the need of a high max_trace_level), so
forget adding tens of thousands of glows to your scene, but at least you
can get something.
  Here is an example of how to achieve this:
----------8<------------8<-------------8<-------------8<-------------8<-----
#macro Glow(GlowColor, Scale)
  sphere
  { 0, 1 hollow no_shadow
    pigment { rgbt 1 }
    interior
    { media
      { emission 1/Scale
        density
        { spherical density_map
          { [0 rgb 0][.5 rgb GlowColor*.5][1 rgb 1]
        samples 1,1 intervals 1 confidence .1 // quite fast settings
        method 3
    scale Scale
camera { location -z*10 look_at 0 angle 35 }
plane { y,-2 pigment { checker rgb 1, rgb .5 } }
light_source
{ <-1.5,1,0>, <1,.5,0>
  looks_like { Glow(<1,.5,0>, .5) }
light_source
{ <2,.5,0>, <0,.5,1>
  looks_like { Glow(<0,.5,1>, 1) }
Subject: Re: Missing glows in 3.5? An alternative solution
Date: 14 Sep 2001 12:40:17
Message: <3ba232f1$1@news.povray.org>
Yeah ! Good ! Thanks
Martial
http://martial.rameaux.free.fr
Date: 14 Sep 2001 22:15:41
Message: <3ba2b9cd@news.povray.org>
news:3ba1fac9@news.povray.org...
pitty
> media.
Thanks Warp !, I've tried it and works fine. Now we have "glows" also in
3.5.
Txemi Jendrix
Date: 17 Sep 2001 02:20:03
Message: <3BA5935F.ED3A0FBD@yahoo.com.au>
I have liked the fade_power option in glows, and a simple modification
of the macro accomodates this. Excellent idea Warp.
MJL
#macro Glow(GlowColor, Fade_Power, Scale)
  sphere
    pigment { rgbt 1 }
    interior
    { media
      { emission 1/Scale
        density
        { spherical poly_wave Fade_Power density_map
          { [0 rgb 0][1 rgb GlowColor]
        method 3
    scale Scale
Date: 20 Sep 2001 18:37:48
Message: <3baa6fbc@news.povray.org>
thanks and i have a question!! this is only for lights.. is there a way for
making surface glow over objects??
Date: 20 Sep 2001 18:54:42
Message: <3baa73b2@news.povray.org>
ahmet oktar <ahm### [at] yahoocom> wrote:
: thanks and i have a question!! this is only for lights.. is there a way for
: making surface glow over objects??
  You can make instances of the glows alone like this:
object { Glow(<0,.5,1>, 1) translate whatever }
or attach it to an object like:
union
{ object { MyObject }
  object { Glow(<0,.5,1>, 1) }
  translate whatever
  And you can of course scale and rotate glows as well.
Date: 2 Oct 2001 06:17:16
Message: <3bb9942c@news.povray.org>
In article <3ba1fac9@news.povray.org>, "Warp" <war### [at] tagpovrayorg> wrote:
Hi, I am running pov-ray 3.1, and it bombs on teh method 3 command in the
macr below.
Is this a failing of 3.1 or is somethng else wrong?
>   sphere
>     pigment { rgbt 1 }
>     interior
>     { media
>       { emission 1/Scale
>         density
>           { [0 rgb 0][.5 rgb GlowColor*.5][1 rgb 1] }
>         method 3
>     scale Scale
> #end
> camera { location -z*10 look_at 0 angle 35 } plane { y,-2 pigment {
> light_source
> light_source
  Rob Brown-Bayliss
 ---======o======---
Date: 2 Oct 2001 06:41:11
Message: <3bb999c7$1@news.povray.org>
The media "methods" are not supported in 3.1. Either use the beta of 3.5 or
wait until it's final release. You could also use MegaPov from Nathan Kopp
 http://nathan.kopp.com/patched.htm) but if you choose this option, you can
as well use the real "glows" instead of this macro.
HTH,
Marc-Hendrik
Rob Brown-Bayliss schrieb in Nachricht <3bb9942c@news.povray.org>...
>macr below.
Date: 2 Oct 2001 08:14:49
Message: <3bb9afb9@news.povray.org>
Rob Brown-Bayliss <on_### [at] clearnetnz> wrote:
: Hi, I am running pov-ray 3.1, and it bombs on teh method 3 command in the
: macr below.
  Did you read the subject of my message?
  Ok, it doesn't *technically* say that it's a 3.5 macro, but I think it
implies it well enough.
Date: 2 Oct 2001 09:24:19
Message: <3bb9c003@news.povray.org>
You can also try and disect this and see if you can come up with anything(Hint,
start at the pigment statement):
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
