POV-Ray : Newsgroups : povray.text.scene-files : Missing glows in 3.5? An alternative solution Server Time
16 Apr 2026 17:30:50 EDT (-0400)
  Missing glows in 3.5? An alternative solution (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Missing glows in 3.5? An alternative solution
Date: 17 Sep 2001 02:20:03
Message: <3BA5935F.ED3A0FBD@yahoo.com.au>
I have liked the fade_power option in glows, and a simple modification
of the macro accomodates this. Excellent idea Warp.
MJL
#macro Glow(GlowColor, Fade_Power, Scale)
  sphere
  { 0, 1 hollow no_shadow
    pigment { rgbt 1 }
    interior
    { media
      { emission 1/Scale
        density
        { spherical poly_wave Fade_Power density_map
          { [0 rgb 0][1 rgb GlowColor]
        samples 1,1 intervals 1 confidence .1 // quite fast settings
        method 3
    scale Scale
Date: 20 Sep 2001 18:37:48
Message: <3baa6fbc@news.povray.org>
thanks and i have a question!! this is only for lights.. is there a way for
making surface glow over objects??
Date: 20 Sep 2001 18:54:42
Message: <3baa73b2@news.povray.org>
ahmet oktar <ahm### [at] yahoocom> wrote:
: thanks and i have a question!! this is only for lights.. is there a way for
: making surface glow over objects??
  You can make instances of the glows alone like this:
object { Glow(<0,.5,1>, 1) translate whatever }
or attach it to an object like:
union
{ object { MyObject }
  object { Glow(<0,.5,1>, 1) }
  translate whatever
  And you can of course scale and rotate glows as well.
Date: 2 Oct 2001 06:17:16
Message: <3bb9942c@news.povray.org>
In article <3ba1fac9@news.povray.org>, "Warp" <war### [at] tagpovrayorg> wrote:
Hi, I am running pov-ray 3.1, and it bombs on teh method 3 command in the
macr below.
Is this a failing of 3.1 or is somethng else wrong?
> ----------8<------------8<-------------8<-------------8<-------------8<-----
> #macro Glow(GlowColor, Scale)
>   sphere
>     pigment { rgbt 1 }
>     interior
>     { media
>       { emission 1/Scale
>         density
>         { spherical density_map
>           { [0 rgb 0][.5 rgb GlowColor*.5][1 rgb 1] }
>         method 3
>     scale Scale
> #end
> camera { location -z*10 look_at 0 angle 35 } plane { y,-2 pigment {
> checker rgb 1, rgb .5 } }
> light_source
> { <-1.5,1,0>, <1,.5,0>
>   looks_like { Glow(<1,.5,0>, .5) }
> light_source
> { <2,.5,0>, <0,.5,1>
>   looks_like { Glow(<0,.5,1>, 1) }
  Rob Brown-Bayliss
 ---======o======---
Date: 2 Oct 2001 06:41:11
Message: <3bb999c7$1@news.povray.org>
The media "methods" are not supported in 3.1. Either use the beta of 3.5 or
wait until it's final release. You could also use MegaPov from Nathan Kopp
 http://nathan.kopp.com/patched.htm) but if you choose this option, you can
as well use the real "glows" instead of this macro.
HTH,
Marc-Hendrik
Rob Brown-Bayliss schrieb in Nachricht <3bb9942c@news.povray.org>...
>macr below.
Date: 2 Oct 2001 08:14:49
Message: <3bb9afb9@news.povray.org>
Rob Brown-Bayliss <on_### [at] clearnetnz> wrote:
: Hi, I am running pov-ray 3.1, and it bombs on teh method 3 command in the
: macr below.
  Did you read the subject of my message?
  Ok, it doesn't *technically* say that it's a 3.5 macro, but I think it
implies it well enough.
Date: 2 Oct 2001 09:24:19
Message: <3bb9c003@news.povray.org>
You can also try and disect this and see if you can come up with anything(Hint,
start at the pigment statement):
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
Date: 2 Oct 2001 11:29:24
Message: <3bb9dd54@news.povray.org>
        samples 2,2 intervals 8 confidence .1 // increased intervals
(samples too)
      //  method 3  // comment out for v3.1
The above might fair well in 3.1 although I didn't check on it.  Basically,
v3.5 can get by with intervals 1 whereas v3.1 cannot.
Bob H.
Date: 2 Oct 2001 17:51:57
Message: <3bba36fc@news.povray.org>
Bob H. <omn### [at] msncom> wrote:
: The above might fair well in 3.1 although I didn't check on it.  Basically,
: v3.5 can get by with intervals 1 whereas v3.1 cannot.
  In 3.1 you will get a grainy glow. If you pump up the samples and intervals
and other parameters you might get a smooth result but then the render times
will go through the roof.
Date: 5 Oct 2001 12:23:19
Message: <3bbdde77@news.povray.org>
Warp,
	I tried this, and it seems to stay "Spherical".. Granted the macro is a sphere..
	Make sense.. so Does this only work as a sphere?  If so I'll just Modify the Macro to
be "Cylindrical"
	thanks
Dave
> union
>   translate whatever
