POV-Ray : Newsgroups : povray.text.scene-files : Missing glows in 3.5? An alternative solution Server Time
16 Apr 2026 17:30:50 EDT (-0400)
  Missing glows in 3.5? An alternative solution (Message 11 to 13 of 13)
Subject: Re: Missing glows in 3.5? An alternative solution
Date: 2 Oct 2001 11:29:24
Message: <3bb9dd54@news.povray.org>
        samples 2,2 intervals 8 confidence .1 // increased intervals
(samples too)
      //  method 3  // comment out for v3.1
The above might fair well in 3.1 although I didn't check on it.  Basically,
v3.5 can get by with intervals 1 whereas v3.1 cannot.
Bob H.
Date: 2 Oct 2001 17:51:57
Message: <3bba36fc@news.povray.org>
Bob H. <omn### [at] msncom> wrote:
: The above might fair well in 3.1 although I didn't check on it.  Basically,
: v3.5 can get by with intervals 1 whereas v3.1 cannot.
  In 3.1 you will get a grainy glow. If you pump up the samples and intervals
and other parameters you might get a smooth result but then the render times
will go through the roof.
Date: 5 Oct 2001 12:23:19
Message: <3bbdde77@news.povray.org>
Warp,
	I tried this, and it seems to stay "Spherical".. Granted the macro is a sphere..
	Make sense.. so Does this only work as a sphere?  If so I'll just Modify the Macro to
be "Cylindrical"
	thanks
Dave
> ahmet oktar <ahm### [at] yahoocom> wrote:
> : thanks and i have a question!! this is only for lights.. is there a way for
> : making surface glow over objects??
>   You can make instances of the glows alone like this:
> object { Glow(<0,.5,1>, 1) translate whatever }
> or attach it to an object like:
> union
> { object { MyObject }
>   object { Glow(<0,.5,1>, 1) }
>   translate whatever
>   And you can of course scale and rotate glows as well.
