POV-Ray : Newsgroups : povray.text.scene-files : lathe bugged glass Galileo Thermometer Server Time
14 Sep 2025 14:31:08 EDT (-0400)
  lathe bugged glass Galileo Thermometer (Message 1 to 3 of 3)
Subject: lathe bugged glass Galileo Thermometer
Date: 16 Nov 2000 16:45:29
Message: <3a145579@news.povray.org>
// Persistence of Vision Ray Tracer Scene Description File
// File: galileo thermometer.pov
// Vers: MegaPov 0.6a
// Desc: A Galileo thermometer, with lathe "bug" perhaps as noted by KalleK in p.b.i.
group
// Date: 2000.87
// Auth: Bob Hughes
// Note: checkered plane for floor is speckled for unknown reason. Beware: Slow to
render!
#version unofficial MegaPov 0.6;
global_settings {
        assumed_gamma 2.4
        max_trace_level 16
light_source { <500,1000,-750> color rgb <1,1.1,1.125>}
light_source { <-25,150,50> color rgb <.5,.33,.25> shadowless}
camera
  location  <0,7.5,-30>
  angle 34
  look_at   <0,5.75,0>
  rotate -5*y
// a heat wave effect (not any good)
#declare HotWave=
texture {pigment {rgbf 1} normal {wrinkles .8} scale .01}
#declare CoolWave=
texture {pigment {rgbf 1} normal {wrinkles .2} scale .015}
#declare NoWave=
texture {pigment {rgbf 1} normal {wrinkles 0} scale 1}
plane {z,-25
        material {
        texture {gradient y texture_map {
                [.05 HotWave] [.33 CoolWave] [.5 NoWave]
        } scale 2.5 translate -1.75*y}
        interior {ior 1.01}
   rotate -5*y
// problem with this part?
plane {y,-.01 pigment {checker color rgb .67 color rgb .75 scale 10}
 clipped_by {box {<-100,-1,-100>,<100,1,100>}}
sky_sphere // rain shower clouds
    pigment
    gradient y
    color_map { [0 color rgb<.7,.8,.9>] [.1 color rgb<.1,.5,.9>] }
    pigment
    bozo  turbulence .7
 color_map {
 [0.0,0.4 color rgbt<.6,.65,.675,0> color rgbt<.65,.65,.675,.7>]
 [0.4,0.5 color rgbt<.65,.65,.675,.7> color rgbt<1,1,1,1>]
 [0.5,0.7 color rgbt<1,1,1,1> color rgbt<1,1,1,1>]
 [0.7,1 color rgbt<.9,.925,.975,.8> color rgbt<.925,.95,.95,0>]
  } scale <1,.33,2>
    pigment
    granite  turbulence .1
 color_map {
 [0.0,0.4 color rgbt<.3,.35,.375,0> color rgbt<.35,.325,.375,.9>]
 [0.4,0.5 color rgbt<1,1,1,1> color rgbt<1,1,1,1>]
 [0.7,1 color rgbt<.55,.525,.6,.8> color rgbt<.5,.525,.55,0>]
  } scale <1,1.25,2>
    pigment
    gradient y
    color_map { [0 color rgbt<.725,.7,.8,.6>] [1 color rgbt<.9,.925,.95,.9>] }
// bright single rainbow
  rainbow {
    direction <.1,-.36,.8>
    angle 30
    width 5
    distance 15
    color_map {
  [0.0,0.19 color rgbt<2,0,2,1> color rgbt<0,0,3,.975> ]
  [0.19,0.33 color rgbt<0,0,3,.975> color rgbt<0,2,2,.925> ]
  [0.33,0.475 color rgbt<0,2,2,.925> color rgbt<0,3,0,.95>]
  [0.475,0.6 color rgbt<0,3,0,.95> color rgbt<2,2,0,.925>]
  [0.6,0.75 color rgbt<2,2,0,.925> color rgbt<2.5,1.5,0,.9125>]
  [0.75,1.0 color rgbt<2.5,1.5,0,.9125> color rgbt<3,0,0,1>]
    jitter 0.02
    up <0,1,-.2>  // 1*y is normal up (any x or z value will tilt)
    arc_angle 100
    falloff_angle 40
// end sky
#declare Outside=
lathe {
  cubic_spline
  11,
  <0, 0>, <1.5, .0125>, <1.1, .05>, <1, .15>, <1, .95>, <.85, 1.075>, <.5, 1.1125>,
<.2, 1.133>, <.1, 1.145>,
<.005, 1.16>, <0, 1.167>
 // sturm
#declare Inside=
lathe {
  cubic_spline
  12,
  <0, .067>, <0, .05>, <.9, .03>, <.9, .05>, <.9, .15>, <.9, .9333>, <.775, 1.06>,
<.475, 1.09>, <.175, 1.1>,
<.08, 1.125>, <.005, 1.133>, <0, 1.15>
 // sturm
#declare GlassTubeAndLiquid=
union {
//intersection {
difference {
        object {Outside}
        object {Inside}
 pigment {rgbft <.975,.9825,.99,.95,.075>}
 normal {wrinkles .008 scale .12}
 finish {ambient 0 diffuse .05 specular .8 roughness .0025
         reflection_type 1 reflection_min .0333 reflection_max .333
         conserve_energy
 interior {ior 1.5 caustics 1 fade_distance .75 fade_power 1 fade_color <.6,.7,.67>
        dispersion 1.1 disp_nelems 9 }
  scale <1,10,1>
difference {
object {Inside scale 1.001}
superellipsoid {<1,.15> scale 1.0225 rotate 90*x translate 2.02*y}
 pigment {rgbft <.99,.99,.99,.925,.125>}
 finish {ambient 0 diffuse .025 specular .6 roughness .005
         reflection_type 1 reflection_min .005 reflection_max .15
         conserve_energy
 interior {ior 1.35 caustics 1 fade_distance .5 fade_power 1 fade_color <.67,.67,.6>
        dispersion 1.05 disp_nelems 9 }
  scale <1,10,1>
GlassTubeAndLiquid
#declare Temp60Tab=
difference {
union {
        torus {.123,.02 rotate 90*z translate -.85*y
     pigment {rgb <.9,.7,.5>*1.5}
        cylinder {-.025*z,.025*z,.234 translate -1.125*y}
text {ttf "arialbd.ttf", "60", .0333, 0 align_center
        pigment {rgb <.8,.825,.825>}
         scale .3 translate <0,-1.23,-.0251>}
     pigment {rgb <.9,.9125,.925>*1.5}
      finish {ambient .05 diffuse .5 specular .75 roughness .025 metallic brilliance 1
reflection .125}
#declare Temp65Tab=
union {
difference {
        cylinder {-.025*z,.025*z,.234}
text {ttf "arialbd.ttf", "65", .0333, 0 align_center
         scale .3 translate <0,-.13,-.0251>}
 rotate -7.5*x translate -1.125*y
reflection .125}
#declare Temp70Tab=
union {
difference {
text {ttf "arialbd.ttf", "70", .0333, 0 align_center
 rotate 10*x translate -1.125*y
reflection .125}
#declare Temp75Tab=
difference {
union {
text {ttf "arialbd.ttf", "75", .0333, 0 align_center
reflection .125}
#declare Temp80Tab=
difference {
union {
text {ttf "arialbd.ttf", "80", .0333, 0 align_center
reflection .125}
#declare Temp85Tab=
difference {
union {
text {ttf "arialbd.ttf", "85", .0333, 0 align_center
reflection .125}
#declare FloatOutside=
lathe {
  cubic_spline
  11,
  <0, 0>, <.001, .001>, <.125, .0225>, <.275, .067>, <.5125, .225>, <.59, .4>, <.567,
.475>, <.45, .67>, <.15,
.825>, <.1, 1>, <0, 1.1>
 // sturm
#declare FloatInside=
lathe {
  cubic_spline
  11,
  <0, 0>, <.001, .0025>, <.1125, .025>, <.25, .075>, <.5, .25>, <.55, .4>, <.525,
.425>, <.4, .6>, <.125, .67>,
<.05, .75>, <0, .8>
 // sturm
#declare GlassFloatAndLiquid=
union {
difference {
        object {FloatOutside}
        object {FloatInside}
 pigment {rgbft <.975,.9825,.99,.875,.075>}
 finish {ambient .5 diffuse 1.1 specular .8 roughness .0025
         conserve_energy
 interior {ior 1.5 caustics 1 fade_distance .25 fade_power 1 fade_color <.6,.67,.67>
difference {
object {FloatInside scale 1.001}
superellipsoid {<1,.15> scale 1.025/2 rotate 90*x translate -.375*y}
  scale <1,1.25,1>*.67
 rotate 180*z
union {
object {GlassFloatAndLiquid
 pigment {rgbft <.099,.099,.99,.9,.05>}
 finish {ambient 0 diffuse .3 specular .6 roughness .005
         reflection_type 1 reflection_min .0025 reflection_max .125
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.1,.1,.8>}
 object {Temp60Tab}
      rotate 10*y translate <.25,9,.25>
union {
 pigment {rgbft <.099,.99,.99,.9,.05>}
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.1,.8,.8>}
 object {Temp65Tab}
      rotate 5*y    translate <.125,7.25,-.25>
union {
 pigment {rgbft <.099,.99,.099,.9,.05>}
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.1,.8,.1>}
 object {Temp70Tab}
      rotate -45*y translate <.125,6,-.125>
union {
 pigment {rgbft <.99,.99,.099,.9,.05>}
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.8,.8,.1>}
 object {Temp75Tab}
      rotate 50*y translate <-.25,5,.125>
union {
 pigment {rgbft <.99,.099,.099,.9,.05>}
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.8,.1,.1>}
 object {Temp80Tab}
      rotate -40*y translate <-.125,3,-.25>
union {
 pigment {rgbft <.99,.099,.99,.9,.05>}
         conserve_energy
 interior {ior 1.3 caustics 1 fade_distance .25 fade_power 1 fade_color <.8,.1,.8>}
 object {Temp85Tab}
      rotate 20*y translate <.25,1.5,-.125>
// omniVerse http://users.aol.com/persistenceofv/all.htm
Subject: Re: lathe bugged glass Galileo Thermometer
Date: 17 Nov 2000 07:58:24
Message: <3a152b70$1@news.povray.org>
Hi Bob!
(Thanks! I'll keep that rainbow and skysphere.)
It's exactly that part. Your plane is too close to the x-z-plane. (if you
change -.01 into -.02 there are no speckles)
Guess:
The checker-pattern changes in the height of 0. If you get too close to this
change, this effect appaers. And because of the 'scale 10' in the
pigmentstatement you are "in reality" 0.001 povunits appart from zero.
I'm a bit astonished at the fact, that the precission problem is that big
(0.001 is a huge number in this case)!
I came across this checkered-precission-problem in former times. When I
layered a checker and a scale-2-checker, the changes where not the same
place. (I made an animation in which I cut a box with a moving plane and the
different scaled checkers jumped in different times.
Once more shall we say: is it a bug?
But my effect was without speckles, maybe the errors got nothing todo with
eachother.
cukk
Date: 18 Nov 2000 17:42:09
Message: <3a1705c1@news.povray.org>
"KalleK" <kal### [at] gmxde> wrote in message news:3a152b70$1@news.povray.org...
YW
> Guess:
I hadn't thought of that.  Thanks much.
Well, yeah, I knew that number tends to be at a lower limit for some things.  It is
something I try to keep in
mind but I still often use such low scales/numbers in defiance of such limitations.
Texture is not the usual
thing I consider though, out of habit I guess.
> eachother.
That is good to know about.  Bad, but good to know.
