![](/i/fill.gif) |
// BEGIN pov-code
// Persistence of Vision Ray Tracer Scene Description File
// File: rad_iso_01a.pov
// Desc: isosurface & radiosity test
// Date: July 2001
// Auth: Christoph Hormann
#version unofficial MegaPov 0.7;
global_settings {
assumed_gamma 1.0
radiosity {
pretrace_start 0.08
pretrace_end 0.004
count 300
error_bound 0.1
recursion_limit 1
low_error_factor .5
gray_threshold 0.0
minimum_reuse 0.015
brightness 1
adc_bailout 0.01/2
location <10.0, 10.0, 2.0>
direction y
sky z
up z
right x*1.333333
look_at <0.0, 0.0, 1.0>
angle 40.0
// Based on Kari Kivisalo's lighting configuration
// modified in both color and intensity
#macro G(Color,g)
rgb<pow(Color.x,g),pow(Color.y,g),pow(Color.z,g)>
#declare Gamma=2.2;
#declare SkyColor=G(<132,164,255>/255,Gamma); // @ 15000K rgb white=6500K
//#declare SunColor=G(<255,235,197>/255,Gamma); // @ 5400K rgb
white=6500K
#declare SunColor=G(<255,184,130>/255,Gamma); // changed
#declare EnergyRatio=9; // sun/sky energy ratio
#declare EQ=1.18; // normalisation for sun-sky colors
light_source {
<-8000.0, 8000.0, 4000.0>
color rgb 0.5*SunColor*EnergyRatio/EQ // changed
area_light 90*x 90*y 5,5
jitter
orient
#declare Sky_Bckg_12 = texture {
gradient z
color_map {
[0.40 color rgb < 0.880, 0.935, 0.976 >]
[0.95 color rgb < 0.400, 0.500, 0.900 >]
finish {
diffuse 0
ambient 1
rotate 27*x
sphere {
<0, 0, 0>, 1
Sky_Bckg_12
scale<100000, 100000, 20000>
no_shadow
hollow on
#declare fn_sphere=function{"sphere",<0.2>}
#declare fn_Noise=function {
agate
color_map {
[0 rgb 0]
[1 rgb 1]
translate -0.25*z
#declare Mountains_01=
isosurface{
function {
((1+0.1)
- 0.1^(fn_sphere(x, y, z-0.3))
- 0.1^(z)) - (fn_Noise(x*3,y*3,z*3))*0.26
method 2
//eval
max_gradient 20
accuracy 0.001
contained_by{box{<-2.7, -2.7, -0.1>, <1.7, 1.7, 1>}}
pigment { color rgb <0.78, 0.58, 0.42> }
finish { ambient 0.0 diffuse 0.6 }
scale 5
object { Mountains_01 }
// END pov-code
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
