POV-Ray : Newsgroups : povray.text.scene-files : Gaussian random numbers Server Time
16 Apr 2026 18:50:48 EDT (-0400)
  Gaussian random numbers (Message 11 to 17 of 17)
Subject: Re: Gaussian random numbers
Date: 3 Jul 2001 09:43:37
Message: <3b41cc09@news.povray.org>
Reusser <reu### [at] chorusnet> wrote:
: Wait a minute.  I made my assumption on the fact that pov-ray has a ln keyword.  I
: assumed that that meant there was also a natural log in which case log would be
: base 10.  If this is not the case, then what does ln do?
  POV-Ray 3.1 doesn't have an ln() function. The log() function is used
as natural logarithm.
  However, it seems that this will be changed in POV-Ray 3.5...
Date: 3 Jul 2001 09:44:22
Message: <3b41cc35@news.povray.org>
: Well I stand corrected.  It still works either way, so I guess you can just change
: it to 1.
  Or just remove it, as dividing by 1 doesn't change anything.
Date: 3 Jul 2001 11:59:00
Message: <3B41EA8A.FA7E1CE@chorus.net>
MegaPov .714 has a keyword "ln" that turns blue when I type it in.  What does that do
if it's not a natural log function?
 -Rico
Subject: RE: Gaussian random numbers
Date: 6 Jul 2001 22:07:59
Message: <3b466eff@news.povray.org>
Hi all,
> And here's the macro:
> #declare e = 2.718281828459;
> #macro gauss(RSR)
>   sqrt(-2*log(rand(RSR))/log(e))*cos(2*pi*rand(RSR))
> #end
I tried it and Pov-Ray assumes "log" is in base e, so log(e)=1 and you don't
need it.
But the formula would stand correct if you assume log is in base 10 because
of the base change formula log BASE e(x) = log BASE 10(x) / log BASE 10(e)
Greets
Pablo Viojo.-
pvi### [at] adinetcomuy
Date: 7 Jul 2001 06:57:01
Message: <3b46eafd$1@news.povray.org>
Sorry, I mailed this direct to you. I just misused Outlook...
How about this:
#macro Gauss2(RS,w)
 #local i=w;
 #local r=0;
 #while (i>0)
  #local r=r+rand(RS)/w;
  #local i=i-1;
 r
RS... Random Seed
w... "width" of the distribution (the higher w, the narrower the dist.)
produces values between 0 and 1, with the maximum at 0.5
Here's a simple test scene (add the above macro at the top):
#declare spectrum
=array[30]{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
#declare i=0;
#declare R=seed(1712942);
#while(i<10000)
 #declare r=Gauss2(R,2)*30;
 #declare spectrum[int(r)]=spectrum[int(r)]+1/50;
 #declare i=i+1;
#declare _x=0;
#while (_x<30)
 box{
  <_x,0,-0.5>,<_x+1,spectrum[_x],0.5>
ment{
   color rgb <1,0.2,0.2>
  finish{
   ambient 0.2
   specular 1
   brilliance 0.6
   roughness 0.1
 #declare _x=_x+1;
 location <15,50,-80>
 look_at <15,30,0>
light_source {
 <-20,50,-50>*100
 color rgb 1
Date: 7 Jul 2001 07:03:05
Message: <3b46ec68@news.povray.org>
Michael Zier <zie### [at] atlantiswh2tu-dresdende> wrote:
: #declare spectrum
: =array[30]{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
  Wouldn't it be easier to initialize that with a #while-loop? Specially
if you want a lot more items...
Date: 7 Jul 2001 07:06:54
Message: <3b46ed4e$1@news.povray.org>
Warp <war### [at] tagpovrayorg> schrieb in im Newsbeitrag:
3b46ec68@news.povray.org...
> : #declare spectrum
Sure, *g*
