![](/i/fill.gif) |
This is the code for the picture in p.b.i.
The parameters of the macro are:
- PigX : Pigment the gradient is calculated from
- Plane : Normal vector of the significant plane
- Scale : Scale of the gradient pattern
BEGIN Pov-code
// 2d gradient pattern for pigments
// January 2001 Christoph Hormann <chr### [at] gmx de>
#version unofficial MegaPov 0.6;
location 12*z
direction z
sky z
up z
right x
look_at <0.0, 0.0, 0.0>
angle 34
#macro Pigment_Gradient_2d (PigX, Plane, Scale)
#local Pigm_Test=
gradient Plane
color_map {
[0.00 rgb 0.0 ]
[1/Scale rgb 1.0 ]
#local Pigm_Disp=
gradient Plane
pigment_map {
[0.00 color rgb 0 ]
[1.00 PigX ]
Pigm_Test
warp {
displace {
Pigm_Disp
type 1
#declare Pigm_Basic01=
bozo
color_map {
[0.00 rgb 0.0 ]
[0.45 rgb 0.1 ]
[0.50 rgb 0.9 ]
[1.00 rgb 1.0 ]
turbulence 0.3
scale 0.7
#declare Pigm_Basic02=
gradient x
color_map {
[0.00 rgb 0.0 ]
[0.55 rgb 0.1 ]
[0.60 rgb 0.9 ]
[1.00 rgb 1.0 ]
turbulence 0.5
scale 1.2
#declare T_XX_01=
pigment { Pigm_Basic01 }
finish { ambient 1 diffuse 0 }
#declare T_XX_01s=
Pigment_Gradient_2d (Pigm_Basic01, z, 15)
#declare T_XX_02=
pigment { Pigm_Basic02 }
#declare T_XX_02s=
Pigment_Gradient_2d (Pigm_Basic02, z, 15)
box {
<-1.5, -1.5, 0>, <1.5, 1.5, 0>
texture { T_XX_01 }
translate <1.6, 1.6, 0>
box {
texture { T_XX_01s }
translate <-1.6, 1.6, 0>
box {
texture { T_XX_02 }
translate <1.6, -1.6, 0>
box {
texture { T_XX_02s }
translate <-1.6, -1.6, 0>
END Pov-code
![](/i/fill.gif) |
