POV-Ray : Newsgroups : povray.text.scene-files : 2d gradient pattern for pigments Server Time
13 Jun 2026 04:26:34 EDT (-0400)
  2d gradient pattern for pigments (Message 1 to 1 of 1)
Subject: 2d gradient pattern for pigments
Date: 6 Jan 2001 04:22:17
Message: <3A56E3CA.7055F9EB@gmx.de>
This is the code for the picture in p.b.i.
The parameters of the macro are:
- PigX : Pigment the gradient is calculated from
- Plane : Normal vector of the significant plane
- Scale : Scale of the gradient pattern
BEGIN Pov-code
// 2d gradient pattern for pigments
// January 2001 Christoph Hormann <chr### [at] gmxde>
#version unofficial MegaPov 0.6;
  location    12*z
  direction   z
  sky         z
  up          z
  right       x
  look_at     <0.0, 0.0, 0.0>
  angle       34
#macro Pigment_Gradient_2d (PigX, Plane, Scale)
  #local Pigm_Test=
    gradient Plane
    color_map {
      [0.00 rgb 0.0 ]
      [1/Scale rgb 1.0 ]
  #local Pigm_Disp=
    gradient Plane
    pigment_map {
      [0.00 color rgb 0 ]
      [1.00 PigX ]
  Pigm_Test
  warp {
    displace {
      Pigm_Disp
      type 1
#declare Pigm_Basic01=
    bozo
    color_map {
      [0.00 rgb 0.0 ]
      [0.45 rgb 0.1 ]
      [0.50 rgb 0.9 ]
      [1.00 rgb 1.0 ]
    turbulence 0.3
    scale 0.7
#declare Pigm_Basic02=
    gradient x
    color_map {
      [0.00 rgb 0.0 ]
      [0.55 rgb 0.1 ]
      [0.60 rgb 0.9 ]
      [1.00 rgb 1.0 ]
    turbulence 0.5
    scale 1.2
#declare T_XX_01=
   pigment { Pigm_Basic01 }
   finish { ambient 1 diffuse 0 }
#declare T_XX_01s=
     Pigment_Gradient_2d (Pigm_Basic01, z, 15)
#declare T_XX_02=
   pigment { Pigm_Basic02 }
#declare T_XX_02s=
     Pigment_Gradient_2d (Pigm_Basic02, z, 15)
box {
  <-1.5, -1.5, 0>, <1.5, 1.5, 0>
  texture { T_XX_01 }
  translate <1.6, 1.6, 0>
box {
  texture { T_XX_01s }
  translate <-1.6, 1.6, 0>
box {
  texture { T_XX_02 }
  translate <1.6, -1.6, 0>
box {
  texture { T_XX_02s }
  translate <-1.6, -1.6, 0>
END Pov-code
