POV-Ray : Newsgroups : povray.text.scene-files : Extrusions PoV code Server Time
16 Dec 2025 16:00:14 EST (-0500)
  Extrusions PoV code (Message 1 to 2 of 2)
Subject: Extrusions PoV code
Date: 17 Oct 2000 09:03:34
Message: <39EC4E87.A692CADF@reading.ac.uk>
// Extrusions ...
// By Mike Andrews, 16th Oct 2000
#version unofficial Megapov 0.6;
global_settings{
  assumed_gamma 1
#declare pig_crack = pigment { crackle form <1,0,0> }
#declare pig_crackn = pigment { crackle }
#declare fn_crack = function { pigment { pig_crack } }
#declare fn_crackn = function { pigment { pig_crackn } }
#declare fn_rm = function {
(1-sqrt(sqrt(fn_crack)))*sqrt(sqrt(fn_crackn)) }
#declare pig_b1 = pigment { bozo colour_map {[0 rgb 0][1 rgb 1]} }
#declare fn_b1 = function { pigment { pig_b1 } }
#declare pig_base = pigment { function { tanh(2*3.7*abs(fn_b1-0.5)) }
scale 1 colour_map {[0 rgb 0][1 rgb 1]} }
// #declare pig_base = pigment { function { fn_rm } colour_map {[0 rgb
0][1 rgb 1]} }
// #declare pig_test = pigment { granite colour_map {[0 rgb 0][1 rgb 1]}
scale 0.5 }
// #declare pig_test = pigment { function { abs(sin(x*pi*5)*sin(y*pi*5))
#declare pig_test = pigment { function { fn_rm } scale 0.5 frequency 1 }
#declare MyPigment = pigment {
  pig_test
  pigment_map {
    [0.0 colour rgb 0]
    [0.1
      pig_base
      colour_map {
        [0 rgb <.6,.6,.2>]
        [1 rgb <.5,1,.5>]
    [1.0
      pig_base
      colour_map {
        [0 rgb <.2,.2,.7>]
        [1 rgb <1,.5,.5>]
  warp { displace { pig_base type 1 } }
//  location  <0.0, 0.5, -4.0>*3 // gives an wider view
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  0*x
  color rgb 1.0
  translate <-30, 30, -30>
plane {
  -z, 0
    pigment{ MyPigment }
    finish{ specular 0.5 roughness 0.001 }
Subject: Re: Extrusions PoV code
Date: 17 Oct 2000 14:33:21
Message: <39EC9BD2.1B1F12AD@reading.ac.uk>
Hi Folks,
Just been playing with the code again.
Try multiplying the camera location by three and putting multiple
identical displace_warps where the current one is. The one with seven
warps could be called 'Fast Clear Water' or something :-)
I'm using a 1024x768 version as my wallpaper at the moment ...
Bye for now,
	Mike Andrews.
