POV-Ray : Newsgroups : povray.text.scene-files : As requested: "B. Mandelbrot meets G. Julia" source Server Time
15 Jul 2025 02:30:24 EDT (-0400)
  As requested: "B. Mandelbrot meets G. Julia" source (Message 1 to 1 of 1)
Subject: As requested: "B. Mandelbrot meets G. Julia" source
Date: 20 Sep 2000 14:15:53
Message: <39C8FEF9.7AA2691B@cityweb.de>
// Benoit Mandelbrot meets Gaston Julia - "Creatures out of the dark"
// (c) 2000 Claudius Klein
// Sorry, I recently changed some values concerning the position and size
// of the fire and can't remember what it was before - so this will render
// NOT exactly the same image as previously posted.
#version unofficial MegaPov 0.5;
global_settings {
  assumed_gamma 1.0 max_trace_level 20
  post_process { soft_glow {1,16} }
  right x*image_width/image_height up y
  location <0,0,-2> look_at <0,0,0>
light_source { <-2,-2,-0.1> White fade_distance 2 fade_power 2 }
light_source { < 2,2,0.1>   White fade_distance 2 fade_power 2 }
#declare CM_Mandel =
color_map {
  [0.0 rgbt <0,0,1,1> ]
  [0.1 rgbt <0,1,0,1> ]
  [0.4 rgb  <1,0,0>   ]
  [0.6 rgb  <1,1,0>   ]
  [0.8 rgb  <0,1,1>   ]
  [1.0 rgbt <0,0,1,1> ]
#declare Mandel =
plane { z,0
    mandel 256
    color_map { CM_Mandel }
    translate <1.37,0,0> scale 10
  finish { ambient 1 diffuse 1 }
  hollow
#declare Julia =
julia_fractal {
  <-0.33,0.75,0,0> quaternion sqr max_iteration 8 precision 24
#declare TJulia =
    bozo turbulence 0.7 omega 0.7
    color_map { [0.2 rgb <1,0,0>]
                [0.5 rgb <0,1,0>]
                [0.8 rgb <0,0,1>] }
  finish { ambient 0 diffuse 0.1 specular 1 reflection 0.8 metallic blinn 1 }
#declare S = seed(30000);
#macro RandVec(var,S)
  <-var/2+rand(S)*var,-var/2+rand(S)*var,-var/2+rand(S)*var>
#declare FireGlowM =
material {
  texture { pigment { rgbt 1 } }
  interior {
    media { emission Red+Orange
            intervals 1 samples 3,3 method 3
            density { spherical scale 0.9 omega 0.7 turbulence 0.48 }
#declare FireLight =
light_source { <0,0,0>
  color Red+Orange
  fade_distance 15 fade_power 2
  media_interaction on media_attenuation on
#declare FireElement =
  sphere { <0,0,0>, 1 material { FireGlowM } hollow scale <2,1,2> }
#declare Fire =
union {
  object { FireElement rotate RandVec(360,S) translate RandVec(3,S) }
  object { FireLight }
object { Julia
  scale <0.5,0.5,0.5> rotate <0,0,-25> translate <0,0,0>
  texture { TJulia }
object { Mandel rotate z*-90}
object { Fire translate <0.5,-3,3> scale 0.5 }
// END OF SESSION
