POV-Ray : Newsgroups : povray.text.scene-files : Mandelbrot Explorer Server Time
17 Dec 2025 20:23:11 EST (-0500)
  Mandelbrot Explorer (Message 1 to 2 of 2)
Subject: Mandelbrot Explorer
Date: 13 Jun 2000 19:38:59
Message: <3946C5CD.33BE1D0D@erols.com>
I wrote a bit of POV scene code to help explore Mandelbrots.  The
source is at the end of this message.
The helpful part is the macro defined at the very beginning; it centers
the view around a particular point, so that there is no need to use
guess work.  Simply render, select a spot worthy of further magnification,
add in code using the Center() macro, and then add a scale transform to
zoom in.
You can also tweak the color map and the frequency setting to get a
pleasant combination of colors.
Enjoy,
John
// SCENE FILE FOLLOWS
#local SizeX=320; // the width of the preview window
#local SizeY=240; // the height of the preview window
#macro Center(pX,pY)
  translate <(SizeX-1)/2-pX,pY-(SizeY-1)/2,0>/(SizeY-1)
plane
{ -z, 0
  texture
    finish { ambient 1 diffuse 0 }
    pigment
    { mandel 4000
      frequency 44
      ramp_wave
      color_map
        [0/6 rgb <0,0,0>]
        [1/6 rgb <1,0,0>]
        [2/6 rgb <1,1,0>]
        [3/6 rgb <1,1,1>]
        [4/6 rgb <0,1,1>]
        [5/6 rgb <0,0,1>]
        [6/6 rgb <0,0,0>]
// these next two lines put the mandelbrot fully into the screen
      translate x*.75
      scale .4
// from here on, use the Center() macro to center the view on a
// particular point in the preview; then use the scale transform
// to zoom in.
// for instance,
//    Center(245,56)
//    scale 10
// will center it around an interesting area, and zoom by 10
// at that spot.
camera { orthographic
  location -z
  direction z
  up y
  right x*4/3
// END OF SCENE FILE
ICQ: 46085459
Subject: Re: Mandelbrot Explorer
Date: 13 Jun 2000 23:43:21
Message: <39470175.AACF2C62@erols.com>
wow -- this has got to be one of the coolest things i've seen done with
pov-ray!  I think this is my first visit to pts-f just because of that awesome
shot in the images group -- great work man!
-Gene
