POV-Ray : Newsgroups : povray.text.scene-files : source for spiky spheres Server Time
15 Mar 2026 12:07:33 EDT (-0400)
  source for spiky spheres (Message 1 to 1 of 1)
Subject: source for spiky spheres
Date: 8 Sep 2001 21:22:09
Message: <3903.649T211T12703144PeterC@nym.alias.net>
Source for that image I posted on the binaries group.
-- spiky4.pov --
#declare ntsc = false;
#declare rseed = seed(81499475);
global_settings {
  assumed_gamma 1.8
  number_of_waves 11
  max_trace_level 14
  location 0
  direction <0, 0, 1.5>
  #if (ntsc = true)
    right <(320/200) * (10/11), 0, 0>
  #else
    right <(640/480), 0, 0>
  up <0, 1, 0>
  rotate z*-15
  rotate x*-6
  rotate y*-20
  translate <32 + 2, -2, 0>
#declare wall_pig1 = pigment {
  bozo
  turbulence 1.3
  color_map {
    [ 0.4 color rgb 1 ]
    [ 1.0 color rgb 0.5 ]
  scale 1/4
torus {
  32, 4
    gradient <0, 1, 0>
    scale 4
    pigment_map {
      [ 0.0 wall_pig1 ]
      [ sin(radians(22.5)) wall_pig1 ]
      [ sin(radians(22.5)) wall_pig1 rotate <23, 64, 18>
        translate <2, 0, 3> ]
      [ sin(radians(45)) wall_pig1 rotate <23, 64, 18>
      [ sin(radians(45)) wall_pig1 rotate <70, -13, 84> ]
      [ sin(radians(45 + 22.5)) wall_pig1 rotate <70, -13, 84> ]
      [ sin(radians(45 + 22.5)) wall_pig1 translate <15, 18, 2> ]
      [ sin(radians(90)) wall_pig1 translate <15, 18, 2> ]
    warp {
      repeat <0, 4, 0> offset <40, 0, -14> flip <0, 1, 0>
  finish { ambient 0 diffuse 1 }
  inverse
union {
  #declare rotz = 0;
  #while (rotz < 360)
    torus {
      32 + 4 * cos(radians(rotz)), 0.05
      translate <0, 4 * sin(radians(rotz)), 0>
    #declare rotz = rotz + (360 / 16);
  #declare roty = 0;
  #while (roty < 360)
    torus {
      4, 0.05
      rotate x*90
      translate <32, 0, 0>
      rotate y*roty
    #declare roty = roty + (360 / 64);
  pigment { color rgb 0.8 }
  finish {
    ambient 0 diffuse 1
    specular 2.0
    metallic
#declare spikeball = union {
  sphere { 0, 1 }
  #declare elivation = 0;
  #while (elivation < 90)
    #declare modradius = cos(radians(elivation));
    #declare incr_factor = 360 / int(modradius * 30);
    #declare roty = 0;
    #while (roty < 360)
  sphere {
    <1, 0, 0>, 0.2
    scale <1, 1/3, 1/3>
    rotate z*elivation
    rotate y*roty
      #if (elivation > 0)
  sphere {
    <1, 0, 0>, 0.2
    scale <1, 1/3, 1/3>
    rotate z*-elivation
    rotate y*roty
      #declare roty = roty + incr_factor;
    #declare elivation = elivation + (90/8);
  // lastly: spike for top and bottom poles
  sphere { <1, 0, 0>, 0.2 scale <1, 1/3, 1/3> rotate z*90 }
  sphere { <1, 0, 0>, 0.2 scale <1, 1/3, 1/3> rotate z*-90 }
#declare spike_texture = texture {
  pigment { color rgb 1 }
  finish {
    ambient 0 diffuse 1
object {
  spikeball
  rotate z*19
  rotate y*23
  translate <30, 0, 9>
  texture { spike_texture }
object {
  spikeball
  rotate z*-72
  rotate y*19
  translate <30, -1.6, 13>
object {
  spikeball
  rotate z*31
  rotate y*-17
  translate <26, -1.0, 18>
#declare spot_hue = <0, 0.4, 1>;
light_source {
  <25, 0, 14>
  color rgb spot_hue * 0.8 + 0.2
  fade_power 1.0
  fade_distance 3
  looks_like {
    union {
      sphere {
        0, 0.1
        pigment { color rgb spot_hue * 0.5 + 0.5 }
        finish { ambient 1 diffuse 0 }
      sphere {
        0, 1
        hollow
        pigment { color rgbt 1 }
        finish { ambient 0 diffuse 0 }
        interior {
          media {
            emission 1
            density {
              spherical
              scale 1/2
              color_map {
                [ 0.0 color rgb 0 ]
                [ 1.0 color rgb spot_hue* 2 ]
/* actual end of this file */
