POV-Ray : Newsgroups : povray.text.scene-files : Hills Server Time
15 Mar 2026 19:16:20 EDT (-0400)
  Hills (Message 1 to 4 of 4)
Subject: Hills
Date: 24 Mar 2000 10:56:10
Message: <38db901a@news.povray.org>
Following is an excerpt from my "Floating Skyscrapers" scene, unfinished, to
illustrate a way of making hilly terrain geometry
It's up to you do define a nice GrassyHill texture!
See also my message  in povray.general  in reply to  JR Lummox
	FSLAND.POVI
	Defines land, hills, woods, roads for Floating
	Skyscrapers
	(c) Daren Scot Wilson, 1999
	BULGE - basic hill/valley form used to build hillfunc
	Takes <x,y> vector and params, returns z value
	center = <x,y> center of hill
	radius = sort of more or less the radius
	    - oops, radius is a keyword, use "radioo"
	elong = 0 for round, 1.0 extreme elongation
	elway = angle (degrees) direction of major axix
	    - elongation is 2nd rank symmetric tensor, trace=1.0
	shape = power of ratio, normally 1 to 2 or more
	decay = power for root, normally 0.5 to 1.0
	     - increase shape will sorta cancel decrease in decay
	lop = <x,y> lopsidedness.
	      <0,0> is symmetric.  Max is  unit vector in any dir.
		  If lop is nonzero, is best to have shape > 2
#macro bulge(pt, center, radioo, elong, elway, shape, decay, lop)
  #local dx = pt.x - center.x;
  #local dy = pt.x - center.y;
  #local ec = elong*cosd(elway*2);
  #local es = elong*sind(elway*2);
  #local dd = (1+ec)*dx*dx + 2*es*dx*dy + (1-ec)*dy*dy;
  #local term = pow(dd/(radioo*radioo), shape);
  #local lopterm = - min(1.0, (lop.x*dx + lop.y*dy)/radioo/(term+1));
  pow( term + 1.0 + lopterm, -decay)
	hillfunc returns z for given <x,y>
#macro hillfunc(point)
	#local xx=point.x;
	#local yy=point.y;
	zgroundzero
	+ 5*sin(xx/350-yy/250)
	+ 3*sin(xx/83+yy/331)
	+ 5*sin(xx/222+yy/46)
	+ 5*sin(-xx/154-yy/37)
	+ 3*sin(xx/40+yy/91)
	+ 2*sin(xx/17+yy/59)
	+ 4*sin(xx/188-yy/35)
	+ 3*sin(xx/164-yy/31)
	-40*bulge(point, < -900,  100>,  700,  .3,  60, 1.8, .5, <.2,0>  )
	+55*bulge(point, < -600, 1100>,  240,   0,   0, 3.3, 1.1, <0,-1> )
	-20*bulge(point, < -250, 1300>,  360,  .5,  45, 2.0, 0.7, <-.5,-.4> )
	+45*bulge(point, <-1500, 1300>,  500,  .3, -10, 2.0, 1.0,  <0, .2>   )
	// distance mountains
	+500*bulge(point, <-4000, 1500>, 150,  .3,  95, 7.0, 0.3, <.5,0> )
	+280*bulge(point, <-3800, 2200>, 130,  .3,  95, 3.0, 0.3, <-.5,.1> )
	+270*bulge(point, <-3700, 2250>, 100,  .3,  25, 2.0, 0.5, <0,1> )
#declare hillscale = 1.5;
#macro hillpoint(xx, yy)
     <xx, yy, hillscale *hillfunc(<xx,yy>)*0 >
#macro hillnorm(xx,yy)
	// find gradient by finite diff
	#local d = 2.5;
	#local gx = hillfunc(<xx+d,yy,0>) - hillfunc(<xx-d,yy,0>);
	#local gy = hillfunc(<xx,yy+d,0>) - hillfunc(<xx,yy-d,0>);
	< -gx/2/d, -gy/2/d,  1.0>
// Check the syntax of macros
#declare yayay = hillfunc(<200,300,0>);
#declare znonzo = hillpoint(222,333);
#declare nranra = hillnorm(333,444);
// Create ground as a bezier mesh
// grid points are <hx, hy> and are nonuniformly spaced
//#declare minstep = 5;   // too fine, too slow
#declare minstep = 25;   // final scene
//#declare minstep = 75;   // faster, fairly good
//#declare minstep = 50;   // faster, fairly good
//#declare minstep = 250;    // faster for testing
#if (1)   // enable hilly ground
#declare hx = FinalEye.x + 100;
#while (hx > -4000)
   #declare dx = minstep + abs(hx-FinalEye.x)*.20;
   #declare hy = FinalEye.y;
   #while (hy<4000)
      #declare dy = minstep + abs(hy-FinalEye.y)*.2;
      #declare   se = hillpoint(hx,        hy);
	  #declare   sw = hillpoint(hx-dx,     hy);
	  #declare   ne = hillpoint(hx,       hy+dy);
	  #declare   nw = hillpoint(hx-dx,    hy+dy);
	  #declare   mm = hillpoint(hx-.5*dx, hy+.5*dy);
	  // normal vectors at these places
	  #declare  nse = hillnorm(hx,        hy);
	  #declare  nsw = hillnorm(hx-dx,     hy);
	  #declare  nne = hillnorm(hx,       hy+dy);
	  #declare  nnw = hillnorm(hx-dx,    hy+dy);
	  #declare  nmm = hillnorm(hx-.5*dx, hy+.5*dy);
#if (0)	    // test objects to mark grid squares
sphere { se+z,  2 pigment {color rgb 1} finish {ambient .2 diffuse .7 phong
4}}
sphere { se+z+5*x, 2 pigment {color rgb 1} finish {ambient .2 diffuse .7
phong .4}}
sphere { se+z+10*x, 2 pigment {color rgb 1} finish {ambient .2 diffuse .7
phong .4}}
sphere { se+z+15*x, 2 pigment {color rgb 1} finish {ambient .2 diffuse .7
phong .4}}
sphere { se+z+15*y,  2 pigment {color rgb 1} finish {ambient .2 diffuse .7
phong .4}}
cone { se,1, sw,6  texture {GaudyWhite}}
cone { se,1, ne,6  texture {GaudyGreen}}
cone { se,1, mm,6  texture {GaudyGreen}}
#endif
#if (1)     // choose mesh or bezier
	  mesh {
	    #if (1)
		smooth_triangle { nw,nnw, mm,nmm, ne,nne }
		smooth_triangle { ne,nne, mm,nmm, se,nse }
		smooth_triangle { se,nse, mm,nmm, sw,nsw }
		smooth_triangle { sw,nsw, mm,nmm, nw,nnw }
		#else
		triangle { nw, mm, ne }
		triangle { ne, mm, se }
		triangle { se, mm, sw }
		triangle { sw, mm, nw }
		#endif
		texture { GroundTex }
#else
		bicubic_patch {
		    type 1    // 0=min mem,slow   1=uses more mem, lots faster
			u_steps 3
			v_steps 3
			flatness .1
			hillpoint(hx,         hy  ),
			hillpoint(hx-.4*dx,   hy  ),
			hillpoint(hx-.6*dx,   hy  ),
			hillpoint(hx-1*dx,    hy  ),
			hillpoint(hx,         hy+.4*dy  ),
			hillpoint(hx-.4*dx,   hy+.4*dy  ),
			hillpoint(hx-.6*dx,   hy+.4*dy  ),
			hillpoint(hx-1*dx,    hy+.4*dy  ),
			hillpoint(hx,         hy+.6*dy  ),
			hillpoint(hx-.4*dx,   hy+.6*dy  ),
			hillpoint(hx-.6*dx,   hy+.6*dy  ),
			hillpoint(hx-1*dx,    hy+.6*dy  ),
			hillpoint(hx,         hy+dy  ),
			hillpoint(hx-.4*dx,   hy+dy  ),
			hillpoint(hx-.6*dx,   hy+dy  ),
			hillpoint(hx-1*dx,    hy+dy  )
#endif // mesh/bezier enable
	  #declare hy=hy+dy;
   #declare hx = hx-dx;
#end // enable hilly ground
/*----------------- Final Catch-All ground plane ----------*/
#if (1)
plane { z, -250
#endif
Daren Scot Wilson
dar### [at] pipelineocm
www.newcolor.com
Subject: Re: Hills
Date: 24 Mar 2000 11:06:42
Message: <38db9292@news.povray.org>
BTW, don't anyone be put off by the (C) in that "Hills" script - i permit
everyone to make full use of the ideas and code in that file.   My (C)
applies to the whole body of work for the Floating Skyscrapers povray script;
i just "rubber-stamp" all my scripts that way.   You may have whatever fun
you like with that one file.
Daren Scot Wilson
www.newcolor.com
Subject: Re: Hills
Date: 24 Mar 2000 11:25:57
Message: <38DB9749.DD3C090C@aetec.ee>
Well, with regard to the copyright here is excerpt from one article:
===============8<===========================================
The correct form for a notice is:
   "Copyright <dates> by <author/owner>"
You can use C in a circle instead of "Copyright" but "(C)"
has never been given legal force.  The phrase "All Rights
Reserved" used to be required in some nations but is now
not needed.
although many texts contain (c) or (C)...
Subject: Re: Hills
Date: 25 Mar 2000 23:22:01
Message: <38DD905B.DAEA54EE@excite.com>
Actually it depends even on the country you're in, here in Australia
everything produced is copyright automatically, even without the (C)
symbol - of course you do need to be able to prove you own the item....
> not needed.
Politicians - It seems to me that the worst of them could convince
me that horse shit tastes like honey-cake; the best of them would
leave me believing that I alone in all the world had failed to
enjoy its flavour.
The individual is more important then the state!
