POV-Ray : Newsgroups : povray.text.scene-files : Media Question Server Time
15 Mar 2026 19:12:50 EDT (-0400)
  Media Question (Message 1 to 3 of 3)
Subject: Media Question
Date: 15 Mar 2000 12:32:31
Message: <38cfc92f$1@news.povray.org>
I'm somewhat confused by the different results shown below for BoxA and
BoxB. Both boxes are clear, below the camera and light and filled with the
same scattering media. BoxA, which is a shallow box, behaves as I expect -
the light is scattered, some back towards the camera, and hence shows up as
white. BoxB, which is much deeper, shows up as black (with white spots in
ordinary POV, solid black in MegaPOV). I don't understand why the depth of
the box has an impact on scattering media in this situation. After all, if I
look at a cloud, it shows as white irrespective of the physical thickness of
the cloud (provided the cloud is not too thin).
#declare AorB = 1; // 1=BoxA, any other val for BoxB
light_source{<0,0,0> color White*4 translate <-60, 30, -30>
media_interaction on}
camera{location  <0.0, 5.0, -5.0> look_at   <0.0, 0.0,  0.0>}
#declare Plain_White_Scattering_Media =
media{
  scattering{1, White}
#declare BoxA =  // nice 'n' white in both POV and MP (method 3 for MP)
box
  <-10000, -1, -10000>
  < 10000,  0,  10000>
  pigment{rgbf<1,1,1,1>}
  hollow on
  interior{media{Plain_White_Scattering_Media}}
#declare BoxB = // completely black (with white spots in POV, pure black in
MP)
box
  <-10000, -10000, -10000>
  < 10000,  0,  10000>
  hollow on
#if (AorB  = 1)
  object{BoxA}
#else
  object{BoxB}
Subject: Re: Media Question
Date: 16 Mar 2000 07:34:46
Message: <38D0D4E6.F3426478@iname.com>
	With the deeper box, nearly all samples are taken in the
middle of the box where all the light from the light_source
has been absorbed while going in. In standard POV, samples
are taken at random, so for some points you've got a fair
chance of having a sample that's taken near enough the side
to be lighted. In MegaPOV with method 2 or 3, the samples
are regularly spaced and all are taken inside.
	If you push the samples count waaayyy up, you'll notice
that the effect diminishes... Another solution is to add
another box completely transparent, hollow, shadowless...
just inside your container to make POV take samples near the
sides:
POV, pure black in MP)
union { // <-----------Add this
box
  < 10000,  0,  10000>
  hollow on
box {  // <-----------Add the following lines
  <-9999, -9999, -9999>, < 9999, -1, 9999>
  pigment { rgbf 1 }
  hollow
  no_shadow
		Jerome
Date: 16 Mar 2000 16:07:45
Message: <38d14d21@news.povray.org>
Aha! A model for media that I can understand. I hadn't realised, and not yet
worked out, about the middle of the media being the only area sampled with
the defaults. That seems to fit with what I've seen. Many thanks. I won't
need to use the union - great tip though - as the shallow box meets my
needs. I was just very confused as to what was going on.
Tom Melly
tom### [at] tomandluforce9couk
http://www.tomandlu.force9.co.uk
Jerome <ber### [at] inamecom> wrote in message
news:38D0D4E6.F3426478@iname.com...
> sides:
> box
>   < 10000,  0,  10000>
>   hollow on
>   pigment { rgbf 1 }
>   hollow
>   no_shadow
