POV-Ray : Newsgroups : povray.text.scene-files : how to speed it up Server Time
17 Apr 2026 18:57:59 EDT (-0400)
  how to speed it up (Message 1 to 2 of 2)
Subject: how to speed it up
Date: 29 Dec 1999 18:24:02
Message: <386a9812@news.povray.org>
Hi
I've convert some 3DS-Files to POV-Ray. Now the object looks like
#declare MyObj=union {
  union {  /* subobject 1 */
    triangle { <......
    triangle { <......
    triangle { <......
    triangle { <......
  union {  /* subobject 2 */
    triangle { <......
    triangle { <......
    triangle { <......
    triangle { <......
  texture { .... }
If I render the scene in POV-Ray, it Povray render as much as longer.
Example:
an empty room (4 Walls , one light source, 800 x 600) needs 2 minutes
with this 3DS-Object, which you is only 50 x 50 pixel large Povray needs 6
minutes, because povray need more time to render the wall, where you can't
see the objects. I hope you understood me.
Is there the posiblity to speed it up. I've tried bounded_by, but not with
better results. Could you give me an example or a tip?
thank you
  frank
Subject: Re: how to speed it up
Date: 1 Jan 2000 18:17:52
Message: <386E8AF0.4E2445DA@xenoarch.com>
tray adding the command line option +mb1
but without knowing where the lights are in relation to the object i
won't be sure
Frank Stolle wrote:
> Hi
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>     triangle { <......
>   texture { .... }
> Example:
> thank you
>   frank
