POV-Ray : Newsgroups : povray.text.scene-files : PC System Time in POV-Ray Server Time
15 Mar 2026 23:16:31 EDT (-0400)
  PC System Time in POV-Ray (Message 1 to 4 of 4)
Subject: PC System Time in POV-Ray
Date: 29 Aug 1999 19:32:36
Message: <37c9c314@news.povray.org>
batch file (save as gettime.bat):
echo " > c:\gottime.txt
echo | more | time | find "Current" >> c:\gottime.txt
echo "; >> c:\gottime.txt
pov script:
// Persistence of Vision Ray Tracer Scene Description File
// File: gettime.pov
// Vers: 3.1
// Desc: Use to get system time after gettime.bat file is run.
// Date: 99.66
// Auth: Bob Hughes  mailto:inv### [at] aolcom?Subject=PoV-Scene
// Note: Run the batch file gettime.bat before rendering this script
to see system time.
//       Could be used to operate parameters based on the system time
for example by using
//       the HourTime and MinuteTime values.
#fopen MyFile "c:\gottime.txt" read
#read (MyFile,MyTime)
#fclose MyFile
#declare HourTime = val(substr(MyTime,20,2))
#declare MinuteTime = val(substr(MyTime,23,2))
#declare DayTime = substr(MyTime,31,1)
#declare Time =
 concat("Time is ", str(HourTime,2,0) ," Hours and ",
str(MinuteTime,2,0), " Minutes ", DayTime,"m")
 text{ttf "timrom.ttf",Time,0.05,0 scale <.75,1.25,1> translate -y/2
  pigment {rgb 1}
   finish {ambient 1}
  translate -5.75*x
camera
  location  <0,0,-9>
  look_at   <0,0,0>
There may be a problem with double digit hours since I only tested
with current time of 5 something o'clock. I will see. No, it is okay
for double digits too ;)
The rest is up to you as to how it is used.
omniVERSE
Subject: Re: PC System Time in POV-Ray
Date: 30 Aug 1999 08:09:58
Message: <37CA745A.DE9A5B0C@pacbell.net>
> omniVERSE
 Not to belittle your individual accomplishment here but by the time you
spend activating the batch file and then adding all of the necessary script
to your scene wouldn't it be simpler to just type the time in yourself ?
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 30 Aug 1999 16:25:50
Message: <jerry-3008991325500001@cerebus.acusd.edu>
In article <37CA745A.DE9A5B0C@pacbell.net>, Ken <tyl### [at] pacbellnet> wrote:
There are times when having access to the system time is useful for
automating things. The time can be used as a seed when you want random
numbers that change per render; it can be useful if you're rendering data
on a regular basis and you want it time stamped.
Jerry
Date: 31 Aug 1999 12:10:13
Message: <37cbfe65@news.povray.org>
Certainly a matter of how it's to be used. Think there are more uses
than I could come up with right now anyway. So far I've only made this
time of run thing, but yes, the variables are there to be plugged into
any definition.
Jerry <jer### [at] acusdedu> wrote in message
news:jer### [at] cerebusacusdedu...
time you
necessary script
yourself ?
random
data
> Jerry
