POV-Ray : Newsgroups : povray.text.scene-files : White is white ? Server Time
17 Apr 2026 22:34:02 EDT (-0400)
  White is white ? (Message 1 to 10 of 12)
Subject: White is white ?
Date: 17 Aug 1999 13:14:38
Message: <37b9987e@news.povray.org>
I'm currently trying to render a in-house scene, and so, I need to simulate
a white ceiling.
But when I try to specify a white texture, I always get a gray ceiling, even
when there is a light veryclose to it.
Could you give me some hints about this difficulty ?
I tried to play with ambiant, diffuse, etc.. but no effect seems OK..
Thnaks for your help.
Subject: Re: White is white ?
Date: 17 Aug 1999 15:32:27
Message: <37B9B97B.471914CD@tiac.net>
>a white ceiling.
Whenever I have this problem I multiply the color like this:
pigment{ rgb<1,1,1>*2}
or you can do ...rgb<2,2,2>  it's the same thing. Multiplying just
makes it quicker to tweek the settings.
You can do the same thing to the color of the lights too.
Date: 17 Aug 1999 15:35:41
Message: <37B9B97B.8A28DD0B@pacbell.net>
> a white ceiling.
Can you post the texture statement that you are using along with finish
and the type of light source you are using. This will help us narrow things
down for you.
 Hint: you can use values larger that 1 in your pigment statements i.e.
 pigment { rgb 1 } // standard white
is not as intense as
 pigment { rgb 2 } // intense white
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 17 Aug 1999 15:35:54
Message: <37B9AAEB.A9183467@panama.phoenix.net>
To save some typing I would just use pigment {rgb 2...3...etc.}.
Anthony L. Bennett
http://welcome.to/TonyB
Non nova, sed nove.
Date: 17 Aug 1999 15:37:25
Message: <37B9B9EA.3D7DD4C1@pacbell.net>
Phil Clute wrote:
Both contestants posted at 12:35 so the judges score this round a tie :)
Ken Tyler
Date: 17 Aug 1999 15:42:16
Message: <37B9BBCA.35B200F9@tiac.net>
Damn! I didn't really need to add the last line either. :)
Date: 17 Aug 1999 18:36:49
Message: <37B9E480.4584E867@merlin.net.au>
> a white ceiling.
The amount of lighting you get on a surface is determined by the
pigment, the lights visible from the surface and the angle at which the
light hits the surface.
Because the lights are usually high up near the ceiling, the angle will
be quite acute, causing the ceiling to appear dark.
One way to get around this is to use a low value for brilliance in your
finish.  In the extreme case, if you use zero for the brilliance, the
angle will have no effect at all, and the surface will be fully
illuminated.
Try something around 0.1 - 0.5 for starters.
Cheers, PoD.
Date: 18 Aug 1999 02:28:17
Message: <37ba5281@news.povray.org>
One way to get more realistic lighting is, of course, radiosity (but
expect problems using it). For some hints:
http://www.students.tut.fi/~warp/pics/Radiosity_test2/
Date: 18 Aug 1999 03:36:54
Message: <37BA60B5.2A120AF7@aol.com>
> a white ceiling.
Try finish {diffuse 1 brillance .1}
Diffuse just ups the brightness caused by lights.  Brilliance control the
falloff of your diffuse lighting.  The lower it gets, the larger the diffuse
'area'.
Date: 18 Aug 1999 05:31:23
Message: <37ba7d6b@news.povray.org>
>a white ceiling.
even
Try placing the light source as far from the object, as possible
(inside the room of course). I don't know if you'll get satisfying
result, but in my scenes textures looked brighter.
Wojtek Bauman aka reaver | rea### [at] spleenwawpl | ICQ: 3429749 |
http://reaver.spleen.waw.pl | PGP: finger bauman@inx.pm.waw.pl |
