POV-Ray : Newsgroups : povray.text.scene-files : "Infinite" reflection in a dodecahedron Server Time
2 Jan 2026 16:17:25 EST (-0500)
  "Infinite" reflection in a dodecahedron (Message 1 to 1 of 1)
Subject: "Infinite" reflection in a dodecahedron
Date: 4 Oct 1999 12:41:53
Message: <37F8D963.733E@aol.com>
As requested, this is the source code for the dodecahedron reflection
image I posted on povray.binaries.images.
Note that the union keyword, not merge, is used here because it allows
the cylinders and spheres to appear outside the shape as well as inside,
if you set ShapeSize to a smaller value. (At its current setting, the
camera is inside the shape boundary, but it is capable of looking into
the dodecahedron from the outside because of the reflective surface's
setting.)
Forgive the wraparound on some of these lines... you may have to fix up
the #declare statements to use this code.
Lummox JR
/* "Infinite" reflection */
#include "textures.inc"
global_settings {max_trace_level 20}
camera {location -10*z direction 1.5*z right x*4/3 up y look_at 0}
light_source {<-3,5,-2>, color White}
#declare ShapeSize=10;
#declare z1=-ShapeSize;
union {
    merge {
        plane {z,z1} plane {-z,z1}
        plane {z,z1 rotate -x*degrees(atan2(2,1))} plane {-z,z1 rotate
        plane {z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,72>} plane
{-z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,72>}
        plane {z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,144>}
plane {-z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,144>}
        plane {z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,-72>}
plane {-z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,-72>}
        plane {z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,-144>}
plane {-z,z1 rotate -x*degrees(atan2(2,1)) rotate <0,0,-144>}
        texture {pigment {color rgbt 1} finish {reflection 1 diffuse 0
ambient 1}}
        hollow
        no_shadow
    merge {
        sphere {-x*ShapeSize/4,ShapeSize/8 texture {Chrome_Metal pigment
{color Blue}}}
        sphere {x*ShapeSize/4,ShapeSize/8 texture {Chrome_Metal pigment
{color Red}}}
        sphere {-y*ShapeSize/4,ShapeSize/8 texture {Chrome_Metal pigment
{color Green}}}
        #declare y1=z1*(sqrt(5)-1)/2;
        #declare x1=y1*tan(radians(36));
        #declare tetraP=array[20]
        #declare tetraP[0]=<x1,y1,z1>;
        #declare tetraP[15]=<-x1,-y1,-z1>;
        #declare
tetraP[5]=vrotate(vrotate(<0,2*x1,0>,-z*18),-x*degrees(atan2(2,1)))+tetraP[0];
        #declare
tetraP[10]=vrotate(vrotate(<0,-2*x1,0>,-z*18),-x*degrees(atan2(2,1)))+tetraP[15];
        #declare a1=0;
        #while (a1<20)
          #declare tetraP[a1+1]=vrotate(tetraP[a1],z*72);
          #declare tetraP[a1+2]=vrotate(tetraP[a1],z*144);
          #declare tetraP[a1+3]=vrotate(tetraP[a1],-z*144);
          #declare tetraP[a1+4]=vrotate(tetraP[a1],-z*72);
          #declare a1=a1+5;
        #declare a1=0;
        #while (a1<5)
          cylinder {tetraP[a1],tetraP[mod(a1+1,5)],0.1 texture
{Chrome_Metal}}
          cylinder {tetraP[a1+15],tetraP[mod(a1+1,5)+15],0.1 texture
{Chrome_Metal}}
          cylinder {tetraP[a1],tetraP[a1+5],0.1 texture {Chrome_Metal}}
          cylinder {tetraP[a1+15],tetraP[a1+10],0.1 texture
{Chrome_Metal}}
          cylinder {tetraP[a1+5],tetraP[mod(a1+2,5)+10],0.1 texture
{Chrome_Metal}}
          cylinder {tetraP[a1+5],tetraP[mod(a1+3,5)+10],0.1 texture
{Chrome_Metal}}
          sphere {tetraP[a1],0.1 texture {Chrome_Metal}}
          sphere {tetraP[a1+5],0.1 texture {Chrome_Metal}}
          sphere {tetraP[a1+10],0.1 texture {Chrome_Metal}}
          sphere {tetraP[a1+15],0.1 texture {Chrome_Metal}}
          #declare a1=a1+1;
    rotate y*20
    rotate -30*z
