POV-Ray : Newsgroups : povray.text.scene-files : Sphere of Torii - Need Help ! Server Time
16 Mar 2026 02:59:28 EDT (-0400)
  Sphere of Torii - Need Help ! (Message 1 to 7 of 7)
Subject: Sphere of Torii - Need Help !
Date: 25 Jan 1999 05:20:21
Message: <36ac4565.0@news.povray.org>
I am trying to generate a Sphere made of Torii, but I can't figure out the
math :(
The attached scene uses data from geodome to locate points on the sphere,
this may not be the easiest way of doing it, but I can't figure out any
other way.
If anyone can correct my math, or show me a better way of solving this
problem I would appreciate it.
Regards
Peter Houston
Download 'torusball.pov.txt' (5 KB)
Subject: Re: Sphere of Torii - Need Help !
Date: 25 Jan 1999 06:09:49
Message: <36ac50fd.0@news.povray.org>
figure out the
>math :(
Check out http://surf.to/uagalleries and visit the 'fantasy
artwork' gallery. There's an example of a sphere made of
tori incl. source.
Julius
Date: 25 Jan 1999 09:07:28
Message: <36ac7aa0.0@news.povray.org>
Not quite what I was looking for, I want the tori to be flat on the outside
of the sphere, imagine a polyhedron or geosphere with tori on each of the
faces.
Thanks anyway,
Peter Houston
Julius Klatte wrote in message <36ac50fd.0@news.povray.org>...
>tori incl. source.
>Julius
Date: 25 Jan 1999 19:10:20
Message: <36ACB3CC.D68920C9@ix.netcom.com>
I may not be understanding but can you clip the tori with a cylinder,
as in an difference ?
> faces.
> Thanks anyway,
> Peter Houston
> >tori incl. source.
> >Julius
Date: 25 Jan 1999 22:41:55
Message: <36AD3984.CA0B0183@virginia.edu>
I know what you want, and I've done it with triangles... but actually it
was with points, so I guess my function would work, you just set it to
the center point of the torus.  Let me modify my #macro and get back to
you.
Steve
> > faces.
> > Thanks anyway,
> > Peter Houston
> > >tori incl. source.
> > >Julius
Date: 25 Jan 1999 23:32:15
Message: <36AD4550.D4F07593@virginia.edu>
Okay.. this isn't perfect, but it should give you a good start...My
points are obviously NOT equidistant, but it should be a heck of a lot
easier than manually defining the points.
Steve
> you.
> Steve
> > > faces.
> > > Thanks anyway,
> > > Peter Houston
> > > >tori incl. source.
> > > >Julius
Download 'tball.inc.txt' (2 KB) Download 'tball.pov.txt' (1 KB)
Date: 26 Jan 1999 16:29:36
Message: <36ae33c0.0@news.povray.org>
That will do nicely, thanks for the help Steve.
Peter H.
Stephen Lavedas wrote ...
