POV-Ray : Newsgroups : povray.text.scene-files : Box with no lights source Server Time
2 Jan 2026 21:50:52 EST (-0500)
  Box with no lights source (Message 1 to 4 of 4)
Subject: Box with no lights source
Date: 23 Jan 1999 12:34:11
Message: <36AA08A8.F041BCD3@Kopp.com>
Here's the source for a box with no lights.  Originally made in
Moray, but then modified in POV.  If you uncomment the light source
and set the material for the ceiling back to DullWhite, you'll get a
more traditionally lit radiosity scene.
-Nathan Kopp
//  Persistance of Vision Raytracer V3.1
//  World definition file.
//  Contains 1 lights, 4 textures and 8 primitives.
//  This file was generated for POV-Ray V3.1 by
//  Moray V3.1 For Windows (c) 1991-1998 Lutz + Kretzschmar
//  Date : 01/21/1999    (21.01.1999)
  The text between these two comments is in MorayPOV.INC and is
  automatically included in all POV files that Moray exports.
default {
    pigment { rgb <1,0,0> }
    finish { diffuse 0.4 ambient 0.3 specular 0.6 roughness 0.001 }
/* // Scene Comment
This scene was created with Moray For Windows.
*/ // End Scene Comment
global_settings {
  adc_bailout 0.003922
  assumed_gamma 1.9
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 4
  number_of_waves 10
  ambient_light 1.5
  radiosity {
    brightness       3.3
    count            100
    distance_maximum 0
    error_bound      0.33
    gray_threshold   0.2
    low_error_factor 0.8
    minimum_reuse    0.015
    nearest_count    6
    recursion_limit  3
background { color <0.000,0.000,0.000> }
camera {  //  Camera StdCam
  location  <      0.000,     -11.000,       6.000>
  direction <        0.0,         0.0,      0.9786> // Aperture is 0.94 degrees
  sky       <    0.00000,     0.00000,     1.00000> // Use right handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.33333,         0.0,         0.0> // Aspect ratio
  look_at   <      0.000,       0.000,       5.000>
// *******  L I G H T S *******
light_source {   // Light1
  <0.000, 0.000, 9.000>
  color rgb <1.000, 1.000, 1.000>
  fade_distance  3.0
  fade_power 2.0
// ********  TEXTURES  *******
#declare DullWhite =
   material  // DullWhite
      texture
         pigment
            color rgb <1.0, 1.0, 1.0>
         finish
            ambient 0.1
            diffuse .9
//  $MRY$: 'DullRed'
#declare DullRed =
   material  // DullRed
      texture
         pigment
            color rgb <1.0, 0.125, 0.229167>
         finish
            ambient 0.1
            diffuse .9
//  $MRY$: 'DullGreen'
#declare DullGreen =
   material  // DullGreen
      texture
         pigment
            color rgb <0.166667, 0.906233, 0.1354>
         finish
            ambient 0.1
            diffuse .9
//  $MRY$: 'ShinyWhite'
#declare ShinyWhite =
   material  // ShinyWhite
      texture
         pigment
         finish
            ambient 0.1
            phong 0.1223
            phong_size 72.846667
            reflection 0.266167
// ********  REFERENCED OBJECTS  *******
// ********  OBJECTS  *******
difference{
  box { <-1, -1, -1>, <1, 1, 1>}
  box { <.8,-.5,-.5>,<1.1,.5,.5>}
  box { <.7,-.3,-.3>,<1.1,.3,.3>}
  box { <.6,-.2,-.2>,<1.1,.2,.2>}
  material {
    DullWhite
  scale 1.5
  rotate -45.0*z
  translate  <-2.0, 0.0, 1.5>
sphere { // Sphere001
  <0,0,0>,1
  material {
    ShinyWhite
    //DullWhite
  scale 2.0
  translate  <2.0, 1.0, 2.0>
box { // Floor
  material {
    DullWhite
  scale <5.0, 5.0, 0.1>
box { // LtWall
  material {
    DullGreen
  scale <0.1, 5.0, 5.0>
  translate  <-5.0, 0.0, 5.0>
box { // RtWall
  material {
    DullRed
  translate  <5.0, 0.0, 5.0>
box { // BackWall
  material {
    DullWhite
  scale <5.0, 0.1, 5.0>
  translate  <0.0, 5.0, 5.0>
box { // Ceiling
  material {
    //DullWhite
    texture{pigment{rgb<1,1,1>} finish{ambient 10}}
  translate  10.0*z
Subject: Re: Box with no lights source
Date: 23 Jan 1999 14:17:09
Message: <36aa1fec.862608@news.povray.org>
When I trace this scene in POV 3.1, I get a near black screen with the
white ceiling (and reflection of the ceiling on the ball) -- not even close
to what you posted in the binaries-group...
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xs4all.nl/~excel/pb.html
All Basic Code Archives -- http://come.to/abcpackets
Date: 23 Jan 1999 15:28:44
Message: <36AA3190.3EA4FD6C@Kopp.com>
Make sure to render it with radiosity turned on. (+QR for command-line option).
If you're using POV for Windows, go to "Render"-->"Edit Settings/Render" to
enter command line options.
Also, if you cancel a radiosity rendering part-way through, you'll have to
restart POV to make it work again (at least with the windows version).
-Nathan
Date: 24 Jan 1999 01:17:52
Message: <36aabb4d.1006501@news.povray.org>
Ah, yes, that seems to do the trick! Thanks!
(I assumed that the source itself would trigger the radiosity)
