POV-Ray : Newsgroups : povray.text.scene-files : Re: a little game Server Time
11 Nov 2025 11:33:38 EST (-0500)
  Re: a little game (Message 1 to 10 of 27)
Subject: Re: a little game
Date: 7 Jan 1999 07:21:03
Message: <3694A6BE.20A984B2@aol.com>
A little unsure of how to continue the formatting of this scene, so I'm
going to just add it in new again. Might be troubles encountered with
multiple posts of this thing at about the same time, which will cause
dropping out of scene code on occasion.
//BEGIN my change
     location <-100, 10, -100>
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
 pigment {rgb C/10 filter C/9}
  normal {waves .4 turbulence .2 scale .1 phase clock}
  finish {ambient .6-(C/11) diffuse .2+(C/15) specular .6 roughness .01
reflection .25
   irid {.6 thickness .3 turbulence .2} brilliance -.15 metallic .4}
  interior {ior 1.05 caustics 4 fade_distance 1.5 fade_power 1}
 scale <C/3,C/4,C/5>*7 rotate C*45*y rotate clock*360*y
  translate <3,5,-7>*4
#declare C=C+1;
//bobs part one
//END my change
gemelli david wrote:
> Hi,
> a few days ago, I posted an image called "foggy scene" in
> binaries.images
> and received very good suggestions. The problem is, I am not able to
> make
> everything, because:
> - there are a lot of things I am not good enough to do.
> - my computer is very slow (486DX2-66 8Mo).
> This gave me an idea, I don't know if it has been tried before (you did
> it
> with a poem I don't remember when):
> I posted an 'empty' scene, just a white floor, a camera and a light in
> scenes-text and the resulting image (very short !) in binaries.image
> with
> the name "a little game".
> What I suggest is that anyone who has an idea, take the source, post a
> message telling he is working on it and when it will be finished then
> post
> the results to the different groups (image and source).
> The main idea is that you can add what you want, even if it bears no
> relation
> to (I took this expression from my French/English dictionary, so ?) the
> rest
> of the scene or if it is a new part of an existing object, but you can't
> modify something that was already done. It may be preferable that the
> thing
> you add is a little/simple thing or a part of something.
> I am curious to see what can be resulting of this !
> Please tell me if you find this stupid or useless, maybe I am the only
> one to
> think it should be funny ?
>                          David GEMELLI
> // OK, that's it. The White plane is all yours
> // Feel free to add any comments you want !
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
=Bob
Download 'us-ascii' (1 KB)
Date: 8 Jan 1999 09:41:00
Message: <369618fc.0@news.povray.org>
I "checked out" the scene. Please don't change it. I'll check it back in
soon, with my added object.
Johannes.
Date: 8 Jan 1999 10:25:18
Message: <3696235e.0@news.povray.org>
And here the scenefile after my addition...
Johannes
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  superellipsoid { <0.1, 0.1> }
  superellipsoid { <1.0, 0.1> translate  0.93*y }
  superellipsoid { <1.0, 0.1> translate  0.93*x }
  material
    texture
      pigment { color rgb <0.8, 0.0, 0.0> }
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  scale <2.5, 2.5, 1.25>
  rotate <0, 0, 45>
  translate  <-80, 3.3, -70>
//End Johannes' part 1
Date: 8 Jan 1999 10:27:26
Message: <3696236D.1A365341@pacbell.net>
> Johannes
HEY !! Mr. Tyler  has it. It shall return.
Ken Tyler
tyl### [at] pacbellnet
Date: 8 Jan 1999 13:36:16
Message: <36964F4C.E6C5D7B2@bahnhof.se>
Hello..
I'll be waiting for it, I think I have something.. (Prepare for RENDER time...)
//Spider
> > Johannes
> Ken Tyler
Date: 8 Jan 1999 14:17:16
Message: <3696594A.6787954B@pacbell.net>
It returneth.
Next person !
Ken Tyler
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  intersection{intersection{intersection{
  plane{x,0 rotate  5*z translate 9*x }
  plane{x,0 rotate  5*z translate 9*x rotate  90*y }
  plane{x,0 rotate  5*z translate 9*x rotate 180*y }
  plane{x,0 rotate  5*z translate 8*x rotate 270*y}}
  plane{x,0 rotate 30*z translate 5*x translate 60*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate  90*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 180*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 270*y}
  plane{y,0 inverse}}
  cylinder{z*-10,z*10,6 scale<1,1.75,1>inverse pigment{rgb 0}}}
  #declare OBTex =
  texture{pigment{granite turbulence 5 color_map{
  [.25 rgb<.70,.67,.64>][.50 rgb<.65,.63,.59>]
  [.75 rgb<.70,.67,.64>][1.0 rgb<.65,.63,.59>]}}
  finish{ambient .4 diffuse .35}}
  #declare Obelisk_Set =
  union{
  object{Obelisk scale<1.5,1.25,1>translate<-100,0,50>texture{OBTex scale 10}}
  object{Obelisk scale<1.5,1.25,1>translate< 100,0,50>texture{OBTex scale 10}}}
  union{
  #declare A = 0;
  #while  (A<10)
  object{Obelisk_Set translate 250*z*A}
  #declare A=A+1; #end rotate 45*y}
  fog{distance 150 color rgb<.70,.67,.63>fog_type 2 fog_offset 15 fog_alt 1}
// End Ken 3of3
Date: 8 Jan 1999 14:48:58
Message: <36966055.1A3B1517@bahnhof.se>
I'm at it.
//Spider
Ken wrote:
> It returneth.
> Next person !
> Ken Tyler
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
Date: 8 Jan 1999 15:27:28
Message: <3696695A.22ED9A48@bahnhof.se>
Done..
Added a sky.
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
  union{
  #declare A = 0;
  #while  (A<10)
// End Ken 3of3
//Spider's part one .
//I decided the scene needed a sky.. I had planned on adding some mountains in the
bkg,
but I didn't have my HF's left.. (damned)
//The sky is very fuzzy and carootnish, a bit dark, but I like it...
//If there is space later, I have a #declare foor a minor wood.... (Hmm... 24 trees,
*48
(Gnarled trees.))
#declare fast=false; //Set this to true to remove some skies. (Good for speed)
#declare SkyOut = 20000; //outer
#declare SkyIn = 15000; //inner
#declare SkyScale = 270; //The scale.
sphere { //Sky layer 1
  <0,0,0>,SkyOut
  hollow
  #if(fast=true) pigment { colour red 1 } #else
      bozo
      turbulence <0.70,0.4,0.7>
      octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.850, 0.700, 0.750> ] [0.1 color rgb <0.550, 0.600, 0.650> ]
        [0.5 color rgb <0.184, 0.184, 0.309> ] [1.0 color rgb <0.100, 0.100, 0.200> ]
      scale <3, 1, 3> scale SkyScale
    rotate <clock*360, -clock*240, clock*120>
sphere { //Sky layer 2
  <0,0,0>, SkyIn
  hollow
      bozo
      turbulence 0.65 octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.88, 0.85,0.85> ] [0.05 color rgb <0.80, 0.75, 0.75> ]
        [0.25 color rgbf 1] [1.001 color rgbf 1] }
      scale <6, 1, 6> scale SkyScale
    rotate <clock*240, -clock*320, clock*180>
//End Spider 1
Date: 9 Jan 1999 00:37:27
Message: <3696EA0F.DC52CEEC@televar.com>
I'm going to add a bit, should be done in a few hours...
Spider wrote:
> Done..
> Added a sky.
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
bkg,
*48
> (Gnarled trees.))
>   <0,0,0>,SkyOut
>   hollow
>     pigment {
>       bozo
>       color_map {
>   #end
>   <0,0,0>, SkyIn
>   hollow
>     pigment {
>       bozo
>       color_map {
>   #end
> //End Spider 1
Date: 9 Jan 1999 02:08:25
Message: <3696FF62.98333316@televar.com>
Ah, nevermind.  I'm tired and my additions are ending up too far away to see the
detail.
