POV-Ray : Newsgroups : povray.text.scene-files : Re: a little game Server Time
13 Jun 2026 10:58:26 EDT (-0400)
  Re: a little game (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: a little game
Date: 9 Jan 1999 02:20:02
Message: <36970322.0@news.povray.org>
Okay in that case I got it
Mike Metheny
lon### [at] vtedu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
Date: 9 Jan 1999 04:01:51
Message: <36971aff.0@news.povray.org>
Here's my part.  Ack sorry I posted the image here too. (In the above post).
Mike Metheny
lon### [at] vtedu
     location <-100, 10, -100>
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
pigment {rgb C/10 filter C/9}
  normal {waves .4 turbulence .2 scale .1 phase clock}
  finish {ambient .6-(C/11) diffuse .2+(C/15) specular .6 roughness .01
reflection .25
   irid {.6 thickness .3 turbulence .2} brilliance -.15 metallic .4}
  interior {ior 1.05 caustics 4 fade_distance 1.5 fade_power 1}
scale <C/3,C/4,C/5>*7 rotate C*45*y rotate clock*360*y
  translate <3,5,-7>*4
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  superellipsoid { <0.1, 0.1> }
  superellipsoid { <1.0, 0.1> translate  0.93*y }
  superellipsoid { <1.0, 0.1> translate  0.93*x }
  material{
    texture{
      pigment { color rgb <0.8, 0.0, 0.0> }
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  scale <2.5, 2.5, 1.25>
  rotate <0, 0, 45>
  translate  <-80, 3.3, -70>
//End Johannes' part 1
// Start Ken 3of3
  #declare Obelisk =
  intersection{intersection{intersection{
  plane{x,0 rotate  5*z translate 9*x }
  plane{x,0 rotate  5*z translate 9*x rotate  90*y }
  plane{x,0 rotate  5*z translate 9*x rotate 180*y }
  plane{x,0 rotate  5*z translate 8*x rotate 270*y}}
  plane{x,0 rotate 30*z translate 5*x translate 60*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate  90*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 180*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 270*y}
  plane{y,0 inverse}}
  cylinder{z*-10,z*10,6 scale<1,1.75,1>inverse pigment{rgb 0}}}
  #declare OBTex =
  texture{pigment{granite turbulence 5 color_map{
  [.25 rgb<.70,.67,.64>][.50 rgb<.65,.63,.59>]
  [.75 rgb<.70,.67,.64>][1.0 rgb<.65,.63,.59>]}}
  finish{ambient .4 diffuse .35}}
  #declare Obelisk_Set =
  union{
  object{Obelisk scale<1.5,1.25,1>translate<-100,0,50>texture{OBTex scale
10}}
  object{Obelisk scale<1.5,1.25,1>translate< 100,0,50>texture{OBTex scale
10}}}
  union{
  #declare A = 0;
  #while  (A<10)
  object{Obelisk_Set translate 250*z*A}
  #declare A=A+1; #end rotate 45*y}
  fog{distance 150 color rgb<.70,.67,.63>fog_type 2 fog_offset 15 fog_alt 1}
// End Ken 3of3
//Spider's part one .
//I decided the scene needed a sky.. I had planned on adding some mountains
in the bkg, but I didn't have my HF's left.. (damned)
//The sky is very fuzzy and carootnish, a bit dark, but I like it...
//If there is space later, I have a #declare foor a minor wood.... (Hmm...
24 trees, *48 (Gnarled trees.))
#declare fast=false; //Set this to true to remove some skies. (Good for
speed)
#declare SkyOut = 20000; //outer
#declare SkyIn = 15000; //inner
#declare SkyScale = 270; //The scale.
sphere { //Sky layer 1
  <0,0,0>,SkyOut
  hollow
  #if(fast=true) pigment { colour red 1 } #else
      bozo
      turbulence <0.70,0.4,0.7>
      octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.850, 0.700, 0.750> ] [0.1 color rgb <0.550, 0.600,
0.650> ]
        [0.5 color rgb <0.184, 0.184, 0.309> ] [1.0 color rgb <0.100, 0.100,
0.200> ]  }
      scale <3, 1, 3> scale SkyScale
    rotate <clock*360, -clock*240, clock*120>
sphere { //Sky layer 2
  <0,0,0>, SkyIn
  hollow
      bozo
      turbulence 0.65 octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.88, 0.85,0.85> ] [0.05 color rgb <0.80, 0.75,
0.75> ]
        [0.25 color rgbf 1] [1.001 color rgbf 1] }
      scale <6, 1, 6> scale SkyScale
    rotate <clock*240, -clock*320, clock*180>
//End Spider 1
// Lone Shepherd's part {Mike Metheny}
// A shuriken; transparent parts shown to show sort of a motion blur.  Would
add more but that would seriously increase render time :0
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                .95, // sweep the following shape from here
                                1, // ... up through here
                                9, // the number of points making up the
shape ...
                                <0,3>, <.75,.75>, <3,0>, <.75,-.75>,
<0, -3>, <-.75,-.75>, <-3,0>, <-.75,.75>,<0,3>
                                translate<0,-1,0>
                       cylinder{<0,-4,0>,<0,4,0>,.5}
                difference{
                        prism {
                                conic_sweep
                                linear_spline
shape ...
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
#declare bozotext1 =
        bozo
        color_map {
          [0.00 color rgb<0.184314,0.309804,0.184314>]
      [0.33 color rgb 0]
      [0.66 color rgb<0.55,0.47, 0.14>]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
   finish { phong .4 reflection .5 metallic}
#declare startrail =
union{       //transparent stars
#declare B=1;
#while (B<5)
#declare bozotext2 =
        bozo
        color_map {
          [0.00 color rgbt<0.184314,0.309804,0.184314,1-.2*B>]
      [0.33 color rgbt <0,0,0,1-.02*B>]
      [0.66 color rgbt<0.55,0.47, 0.14,1-.2*B>]
      [1.00 color rgbt <.5,.5,.5,1-.2*B>]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
object{star texture{bozotext2} scale 2 rotate<100,10,(5*B)-15> translate
<-75+2*B,25-4*B,-33-8*B>}
#declare B=B+1; #end
object{star texture{bozotext1}  scale 2 rotate <100,10,-5> translate  <-65,
5, -73>}
object{startrail}
//End Lone Shepherd (Mike Metheny) part
Date: 10 Jan 1999 17:45:43
Message: <36992DFD.4B5DCCCE@pacbell.net>
Mind if I take a whack at it?    (rendering on a P200 w 64MB, this MIGHT take a
few hours...)
> Mike Metheny
> lon### [at] vtedu
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
> 10}}
> 10}}}
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
> speed)
>   <0,0,0>,SkyOut
>   hollow
>     pigment {
>       bozo
>       color_map {
> 0.650> ]
> 0.200> ]  }
>   #end
>   <0,0,0>, SkyIn
>   hollow
>     pigment {
>       bozo
>       color_map {
> 0.75> ]
>   #end
> //End Spider 1
> #declare star =
>         merge{
>                 difference{
>                         prism {
>                                 conic_sweep
>                                 linear_spline
> shape ...
>                                 translate<0,-1,0>
>                 difference{
>                         prism {
>                                 conic_sweep
>                                 linear_spline
> shape ...
>                                 rotate <180,0,0>
>                                 translate <0,1,0>
>                  torus{.5,.05}
> texture {
>       pigment {
>         bozo
>         color_map {
>       [0.33 color rgb 0]
>       [1.00 color rgb .5]
>         turbulence 3
>         scale <3,.8,.8>*1.3
>         rotate <5,10,30>
> #declare B=1;
> #while (B<5)
> texture {
>       pigment {
>         bozo
>         color_map {
>         turbulence 3
>         scale <3,.8,.8>*1.3
>         rotate <5,10,30>
> 5, -73>}
> object{startrail}
 george erhard
 microsoft certified system engineer
 http://home.pacbell.net/dcnblues
 remove "nospam" from domain when replying
Date: 10 Jan 1999 19:17:53
Message: <3699438F.4263A12C@pacbell.net>
OK, done.  Included is the source for this and a small file to make the
heightfield.  Render it separately (160x100 no AA works great) and put the image
it makes in your Include path.
But, y'all knew that already...
I probably 'broke the rules' by making this two files instead of one, but then
again, this is pretty freeform! ":)
// Desc: "A Little Game"
// Date:  1/10/98
// Auth:  (gemelli started it...)
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
10}}
10}}}
  union{
  #declare A = 0;
  #while  (A<10)
// End Ken 3of3
// in the bkg, but I didn't have my HF's left.. (damned)
// 24 trees, *48 (Gnarled trees.))
#declare fast=false; //Set this to true to remove some skies. (Good for speed)
  <0,0,0>,SkyOut
  hollow
      bozo
      color_map {
0.650> ]
0.200> ]  }
  <0,0,0>, SkyIn
  hollow
      bozo
      color_map {
0.75> ]
//End Spider 1
// add more but that would seriously increase render time :0
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                .95, // sweep the following shape from here...
                                9, // the number of points making up the shape
                                translate<0,-1,0>
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
        bozo
        color_map {
      [0.33 color rgb 0]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
#declare B=1;
#while (B<5)
        bozo
        color_map {
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
5, -73>}
object{startrail}
// begin DcnBlues contribution (george erhard)
// sort of hexagonal thing to fill up the space in the right front corner...
height_field
  tga
  "hexplane.tga"     // source posted after this source, render seperately!
    pigment { rgb <0.658824, 0.658824, 0.658824> }
    finish {
        ambient 0.3
        diffuse 0.7
        reflection 0.15
        brilliance 8
        specular 0.8
        roughness 0.1
    normal {
        bumps -0.5
        scale <1, 0.001, 0.001>
     scale <25, 3, 25>
     translate  <-95, 0, -115>
    // End dcnblues contribution... such as it was!  :)
// END "LITTLEGAME"Source
// HEIGHT-FIELD GENERATOR FILE -- render this seperately!
plane
  z, // backplane
  7.5 // move it a little ways away
        hexagon
        color rgb 1
        color rgb 0.5
        color rgb 0
        rotate 90*x
  finish {ambient 1  diffuse 0} // look ma, no lights needed!
 george erhard
 remove "nospam" from domain when replying via e-mail
Date: 10 Jan 1999 21:14:24
Message: <36995DA5.D310F145@bahnhof.se>
let me ask here...
Are we allowed to add again ???
Just wondering, having a few ideas... *grin*
//Spider
Date: 10 Jan 1999 22:10:59
Message: <36996BC5.3BB74528@virginia.edu>
I have the file now... bbiab..:))
Steve
Date: 11 Jan 1999 00:49:44
Message: <369990F8.89541F1A@virginia.edu>
I am also finished.  Here is the source (again, detatch the heightfield
source and render separately I did it at 320x240 no AA)
Steve
// Date:  1/10/98
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
scale 10}}
scale 10}}}
  union{
  #declare A = 0;
  #while  (A<10)
     #declare A=A+1;
  rotate 45*y}
fog_alt 1}
// End Ken 3of3
mountains
(Hmm...
speed)
  <0,0,0>,SkyOut
  hollow
      bozo
      color_map {
0.600,
0.650> ]
0.100,
0.200> ]  }
  <0,0,0>, SkyIn
  hollow
      bozo
      color_map {
0.75> ]
//End Spider 1
Would
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
here...
shape...
                                translate<0,-1,0>
                difference{
                        prism {
                                conic_sweep
                                linear_spline
here...
shape...
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
        bozo
        color_map {
      [0.33 color rgb 0]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
#declare B=1;
#while (B<5)
        bozo
        color_map {
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
<-65,
5, -73>}
object{startrail}
corner...
height_field
  tga
seperately!
    finish {
        ambient 0.3
        diffuse 0.7
        reflection 0.15
        brilliance 8
        specular 0.8
        roughness 0.1
    normal {
        bumps -0.5
     scale <25, 3, 25>
//Begin Steve's Contribution.
//I know it is really ugly code, but it is an old formula that I
modified
//to fit the situation.  (It took me awhile to figure out what i wanted
to add)
#declare Element=sphere{<0,0,0>, 0.5}
#declare Side = 135.0;
#declare Angle = ((12-2)/12)*pi;
#declare a = 0.0;
#declare b = 0.0;
#declare c=1.0;
#while (c<=12)
       #declare Point = <a,0,b>;
       #declare a = a+Side*sin((pi/2)-(2*pi-Angle));
       #declare b = b+Side*sin(2*pi-Angle);
       #declare Angle = Angle + ((12-2)/12)*pi;
       object{
              Element
              translate Point
               pigment {rgb <1,0,0>}
               finish {
                       ambient 0.2
                       diffuse 0.3
                       specular 0.8
                       reflection 0.7
                       roughness 0.0001
                       metallic
       #declare c=c+1;
#declare c=1.0;
#declare a = 0.0;
#declare b = 0.0;
#while (c<=12)
       #declare d=c;
       #declare a2=a;
       #declare b2=b;
       #declare Angle2=Angle;
       #while (d<12)
              #declare Point2 = <a2,0, b2>;
              #declare a2 = a2+Side*sin((pi/2)-(2*pi-Angle2));
              #declare b2 = b2+Side*sin(2*pi-Angle2);
              #declare Angle2 = Angle2 + ((12-2)/12)*pi;
              cylinder{Point, Point2 ,0.5
                       finish {
                              ambient 0.1
                              diffuse 0.2
                              specular 1
                              reflection 0.8
                              roughness 0.0001
                              metallic
              #declare d=d+1;
       #declare c=c+1;
//END Steve's section
plane
  z, // backplane
        hexagon
        color rgb 1
        color rgb 0.5
        color rgb 0
        rotate 90*x
Date: 11 Jan 1999 04:04:22
Message: <3699BE5C.E9462BBA@imerir.asso.fr>
I think there's no problem !
Go ! Go ! Go !
                        David GEMELLI
> let me ask here...
> //Spider
Subject: Re: a little game (Bob Hughes)
Date: 11 Jan 1999 15:44:01
Message: <3697F61A.F3E07FBF@melbpc.org.au>
Bob Hughes wrote:
> //bobs part one
> <snip>
> reflection .25
Hi Bob.
    I am having trouble rendering your part of A Little Game.
    POV-Ray stops during parsing with an error message to the affect that
    "Interior" is an unknown command.
    I am using POV-Ray 3.01, and I could not find it in the POV-Ray help files.
Regards Alex
  ,-._|\  Alex McMurray
 /  Oz  \ ale### [at] melbpcorgau               Melbourne PC User Group.
 \_,--.x/ P.O. Box 215 Melton. Vic.  3337                     Australia
       v
Date: 11 Jan 1999 15:51:27
Message: <369A63D4.B92672EB@pacbell.net>
Alex McMurray wrote:
> Bob Hughes wrote:
> > //bobs part one
> > <snip>
> > reflection .25
> Hi Bob.
> Regards Alex
>        v
  Interior is a new function of Pov v3.1. You should consider upgrading
to the most recent version as it has many new and very useful features.
To get past this for now just comment out the interior statement.
Move what you can into the finish statement to render the scene with
your additions and then remove them afterwards to repost the scene
here.
I presume this will be acceptable with the rest of the participants as
well. Most everyone else is already usin g v3.1 so it shoudn't cause
anyone else problems. Remeber that if your object uses halo's
or atmoshphere it won't work for people using v3.1 as these features
have been discontinued.
Ken Tyler
