POV-Ray : Newsgroups : povray.text.scene-files : Clouds.POV in feet, not miles Server Time
11 Nov 2025 11:26:58 EST (-0500)
  Clouds.POV in feet, not miles (Message 1 to 3 of 3)
Subject: Clouds.POV in feet, not miles
Date: 9 Oct 1998 12:12:39
Message: <361e27e7.0@news.povray.org>
The following POV code is an adaptation of Mike Andrews clouds.pov code
for just the clouds. I have a need to see how it was done, but in units
of feet and not miles. I have tried to modify it, but it comes out pure
black - though it renders just as slowly as his clouds.pov scene! Anyone
know what I am doing wrong?
Jon
// Start of cloud code ... rather a mess.#declare cloudShape = density
{ spotted ramp_wave }
#declare D_Cloud_Center =density {   cloudShape triangle_wave
colour_map {      [0.5 colour Gray95]      [1.0 colour Gray75]   }}
// Calculate the correct colour_map values.#declare NT =
floor((groundRad + 6) / 6);#declare DT = (groundRad + 6)*5280 /
NT;#declare V1 = 1 - (6 - 2.0)*5280 / DT;#declare V2 = 1 - (6 -
2.5)*5280 / DT;#declare V3 = 1 - (6 - 3.5)*5280 / DT;#declare V4 = 1
- (6 - 4.5)*5280 / DT;#declare V5 = 1 - (6 - 5.5)*5280 / DT;#declare
V6 = 1 - (6 - 6.0)*5280 / DT;
// container for cloud.difference {   sphere { 0, (groundRad + 6.0)*5280
} sphere { 0, (groundRad + 3.5)*5280 }   pigment { rgbf 1 }   interior {
     media {         intervals mSamples         scattering { 2, rgb 5
extinction 1.0}         samples 2, mSamples         confidence 0.9999
     variance 1/1000         density { D_Cloud_Center scale 2*3*0.2*5280
}   // fine scale cloud detail   density { D_Cloud_Center scale
2*3*0.08*5280 }         density {         // confine the cloud to the
container            onion            colour_map {          [V1 rgb 0]
     [V2 rgb 0]        [V3 rgb 0]        [V4 rgb 1]        [V5 rgb 1]
    [V6 rgb 0]            }            scale DT         }         //
large scale cloud detail         density {            onion
colour_map {        [V1 rgb 0]        [V2 rgb 1]        [V3 rgb 1]
 [V4 rgb 0]        [V5 rgb 0]        [V6 rgb 0]       }            warp
{ turbulence 0.25*0.8 octaves 3 lambda 3 omega 0.7 }            scale DT
        }      }   }   translate -groundRad*5280*y   hollow}
// atmosphere #declare NT = floor((groundRad + 20.0) / 20.0);#declare
DT = (groundRad + 20.0)*5280 / NT;#declare V1 = 1 - (20.0 -
5.0)*5280 / DT;#declare V2 = 1 - (20.0 - 5.0)*5280 / DT;
sphere {   0, (groundRad + 20.0)*5280   pigment { rgbf 1 }   interior {
    media {         intervals mSamples   scattering { 4, rgb atmCol
extinction 1 }   samples 2, mSamples   confidence 0.9999   variance
1/1000         density {            onion ramp_wave
colour_map {               [V1 rgb 1]               [V2 rgb 0.5]
      [1  rgb 0]            }         }         scale DT      }   }
Download 'iso-8859-1' (6 KB)
Subject: Re: Clouds.POV in feet, not miles
Date: 9 Oct 1998 13:08:26
Message: <361e34fa.0@news.povray.org>
Sorry about that last message, I accidentally sent it as HTML. Here it is as
pure text.
for just the clouds. I have a need to see how it was done, but in units of
feet and not miles. I have tried to modify it, but it comes out pure black -
though it renders just as slowly as his clouds.pov scene! Anyone know what I
am doing wrong?
    Jon
    #declare cloudShape = density { spotted ramp_wave }
    density {
       colour_map {
          [0.5 colour Gray95]
          [1.0 colour Gray75]
    #declare NT = floor((groundRad + 6) / 6);
    #declare DT = (groundRad + 6)*5280 / NT;
    #declare V2 = 1 - (6 - 2.5)*5280 / DT;
    #declare V4 = 1 - (6 - 4.5)*5280 / DT;
    #declare V6 = 1 - (6 - 6.0)*5280 / DT;
    difference {
       sphere { 0, (groundRad + 6.0)*5280 }
       pigment { rgbf 1 }
       interior {
          media {
             intervals mSamples
             scattering { 2, rgb 5 extinction 1.0}
             samples 2, mSamples
             confidence 0.9999
             variance 1/1000
             density { D_Cloud_Center scale 2*3*0.2*5280 }   // fine scale
cloud detail
       density { D_Cloud_Center scale 2*3*0.08*5280 }
             density {         // confine the cloud to the container
                onion
                colour_map {
              [V1 rgb 0]
            [V2 rgb 0]
            [V3 rgb 0]
            [V4 rgb 1]
            [V5 rgb 1]
            [V6 rgb 0]
                scale DT
             // large scale cloud detail
             density {
                onion
           colour_map {
            [V1 rgb 0]
            [V2 rgb 1]
            [V3 rgb 1]
            [V4 rgb 0]
            [V5 rgb 0]
            [V6 rgb 0]
                warp { turbulence 0.25*0.8 octaves 3 lambda 3 omega 0.7 }
                scale DT
       hollow
    // atmosphere
    #declare DT = (groundRad + 20.0)*5280 / NT;
    #declare V1 = 1 - (20.0 - 5.0)*5280 / DT;
    sphere {
       pigment { rgbf 1 }
       interior {
          media {
             intervals mSamples
       scattering { 4, rgb atmCol extinction 1 }
       samples 2, mSamples
       confidence 0.9999
       variance 1/1000
             density {
                onion ramp_wave
                colour_map {
                   [V1 rgb 1]
                   [V2 rgb 0.5]
                   [1  rgb 0]
             scale DT
       hollow
Date: 14 Oct 1998 09:49:26
Message: <36249DAF.C82A9116@remove-this.reading.ac.uk>
Hi Jon,
    Your basic problem is that the medias are now too dense for your distance
unit.
    If you put in
        #declare atmCol = atmCol / 5280;
just after atmCol is defined and change
          [0.5 colour Gray95]
          [1.0 colour Gray75]
to
          [0.5 colour Gray95 / 5280]
          [1.0 colour Gray75 / 5280]
in the D_Cloud_Center declaration it should work.
    Have fun,
        Mike Andrews.
> am doing wrong?
>     Jon
>     density {
>        colour_map {
>           [0.5 colour Gray95]
>           [1.0 colour Gray75]
[code clipped]
