POV-Ray : Newsgroups : povray.text.scene-files : variable turbulence Server Time
6 Oct 2024 06:59:21 EDT (-0400)
  variable turbulence (Message 1 to 1 of 1)
Subject: variable turbulence
Date: 24 Mar 2001 15:28:21
Message: <1071.482T853T11623722PeterC@nym.alias.net>
An attempt at varaible turbulence.  This is the source
for the image over in the binaries group
#declare ntsc = false;
global_settings {
  assumed_gamma 2.2
  location 0
  direction <0, 0, 1>
  #if (ntsc = true)
    right <(640 / 400) * (10/11), 0, 0>
  #else
    right <640 / 480, 0, 0>
  up <0, 1, 0>
  translate <0, 0, -8>
plane {
  <0, 0, -1>, 0
    spherical
    scale 5
    pigment_map {
      #declare turb_amount = 0;
      #while (turb_amount < 1)
        [ turb_amount
          radial
          frequency 12
          turbulence 2 * (1 - sqrt(turb_amount))
          color_map {
            [ 0.0 color rgb 1 ]
            [ 0.025 color rgb <0.2, 0.5, 0.8> ]
            [ 0.05 color rgb 0 ]
            [ 0.95 color rgb 0 ]
            [ 0.975 color rgb <0.2, 0.5, 0.8> ]
            [ 1.0 color rgb 1 ]
          scale 1/5
          rotate x*-90
        #declare turb_amount = turb_amount + (1/30);
  finish { ambient 1 diffuse 0 }
/* actual end of this file */
