POV-Ray : Newsgroups : povray.text.scene-files : Re: 35 mm film metallic box Server Time
30 Mar 2026 18:40:06 EDT (-0400)
  Re: 35 mm film metallic box (Message 1 to 6 of 6)
Subject: Re: 35 mm film metallic box
Date: 24 Aug 1998 17:22:53
Message: <35E1CA7B.7E2FBD94@hotmail.com>
miro wrote:
> Someone has and can facilitate me a file or code to generate the image of a
> round metallic box for a 35 mm cinema film?
> Thanks!
What's so special about this box? Can't you just use some cylinders and CSG?
I'd be os so happy to show you, but I don't know what this box looks like
exactly...
It can't be that hard, though (??).
You're welcome.
JK
Date: 24 Aug 1998 17:52:11
Message: <35E1C41A.D8349107@pacbell.net>
> > Thanks!
> exactly...
> You're welcome.
> JK
I would think two cylinders and two torus would just about do it.
See example below. If you want a better texture do it your self.
K.Tyler
camera{location z*-30 look_at 0}
light_source{<0, 0,-100>rgb 1}
light_source{<0,14,   0>rgb 1}
union{
cylinder{<0,-1,0>,<0,0,0>10.0}
cylinder{<0, 0,0>,<0,1,0>10.1}
torus{10.1,.1}
torus{10.0,.1 translate .95*y}
pigment{rgb<.97,.98,1>}
finish{metallic ambient .3 diffuse .1 reflection .12
specular 1 roughness .01 brilliance 2}
rotate 15*-x}
sky_sphere{pigment{gradient y color_map{[0 rgb 1][1 color rgb<.196,.6,.8>]}}
pigment{bozo color_map{[0 rgb 1][.5,.55 color rgbf 1 color rgb 1][1 rgbf 1]}
scale 2}}
Date: 25 Aug 1998 18:39:38
Message: <35E32E03.18E78762@hotmail.com>
K. Tyler wrote:
> > > Thanks!
> > exactly...
> > You're welcome.
> > JK
> K.Tyler
> union{
> torus{10.1,.1}
> rotate 15*-x}
> scale 2}}
  It's the sky sphere that does it.
JK
http://surf.to/jkhome
Date: 25 Aug 1998 18:46:58
Message: <35E3225C.8BDB071A@pacbell.net>
JK wrote:
> K. Tyler wrote:
> > > > Thanks!
> > > exactly...
> > > You're welcome.
> > > JK
> > K.Tyler
> > union{
> > torus{10.1,.1}
> > rotate 15*-x}
> > scale 2}}
> JK
  Thank you. Thank you very much !
K.Tyler
Date: 2 Sep 1998 11:47:14
Message: <01bdd64c$13747620$8c00a8c0@shindo>
K. Tyler <tyl### [at] pacbellnet> wrote in article
<35E1C41A.D8349107@pacbell.net>...
> JK wrote:
image of a
> > > Thanks!
CSG?
like
> > exactly...
> > You're welcome.
> > JK
>  <snipped a quite reasonable film box>
	I've made a couple of slight improvements on Kens film box. See attached
file. I think it makes it clearer what it's meant to be and you can adjust
its dimensions by changing #declare'd variables. Texture still needs work.
Scott Hill
Sco### [at] DDLinkscouk
Software Engineer (and all round nice guy)
Company homepage : http://www.ddlinks.demon.co.uk
"The best trick the devil ever pulled was convincing people he didn't
exist..."
								- Verbal Kint.
"the Internet is here so we can waste time talking about nothing in
 particular when we should be working" - Marcus Hill.
Download 'filmbox.pov.txt' (2 KB)
Subject: Re:The Internet Film Box Project or IFBP
Date: 5 Sep 1998 08:39:32
Message: <35F1227A.3F99C6AB@pacbell.net>
> Scott Hill
Nice touch. Your right, that texture still needs work. Anybody ?
K.Tyler
