POV-Ray : Newsgroups : povray.programming : code cleanup Server Time
29 Aug 2025 06:46:48 EDT (-0400)
  code cleanup (Message 1 to 3 of 3)
Subject: code cleanup
Date: 15 Aug 2017 15:55:01
Message: <web.599340ed879ff37936107e040@news.povray.org>
i just ran cppcheck for povray sources:
[libraries/tiff/libtiff/tif_ojpeg.c:925]: (error) Invalid number of character
'(' when these macros are defined: 'C_LOSSLESS_SUPPORTED;OJPEG_SUPPORT;never'.
ok, 'never' should obviously never be defined, otherwise it would not compile.
[libraries/tiff/contrib/stream/tiffstream.cpp:117]: (error) Uninitialized
variable: ostr
 ostream* ostr;
 if(ts->m_outStream != NULL) {
     ostr = ts->m_outStream;
 } else if(ts->m_ioStream != NULL) {
     ostr = ts->m_ioStream;
 streampos start = ostr->tellp();
Here another else branch would be good in order to handle the case of
ts->m_outStream == NULL and ts->m_ioStream == NULL
(if that is possible (who knows))
[libraries/tiff/tools/tiffsplit.c:64]: (error) Buffer overrun possible for long
command line arguments.
might be triggered from the outside, if tiffsplit is used at all.
[source/base/povmscpp.cpp:1757]: (error) Memory leak: nodeptr
In case of an exception nodeptr cannot be freed anymore...
[source/base/povmscpp.cpp:1781]: (error) Memory leak: nodeptr
In both cases could
 err = POVMS_InstallReceiver(context, ReceiveHandler, hclass, hid, (void
*)this);
 if(err != pov_base::kNoErr)
  throw POV_EXCEPTION_CODE(err);
be moved to the beginning of the method? I see no dependency to local variables
here.
[windows/cmedit/ccodemax.cpp:289]:
[windows/cmedit/ccodemax.cpp:305]:
[windows/cmedit/ccodemax.cpp:321]:
[windows/cmedit/ccodemax.cpp:685]:
[windows/cmedit/ccodemax.cpp:699]:
The return value of malloc() should be checked before usage.
Hope you find that useful, best regards Heiko
Subject: Re: code cleanup
Date: 15 Aug 2017 16:50:01
Message: <web.59935e21e42ebdf653e6c55b0@news.povray.org>
> In both cases could
> *)this);
> here.
No. This exception will always have to be a fatal error for the application
because if is more or less an emergency exit when POV-Ray runs out of memory. So
it is too late the fiddle with memory anyway. Basically all POVMS errors are
fatal because it means communication within POV-Ray's threads is broken, in
which case you actually "leak" whole threads...
Date: 15 Aug 2017 18:37:41
Message: <599377b5@news.povray.org>
Am 15.08.2017 um 21:51 schrieb hexcoder:
> variable: ostr
This is libtiff, a 3rd party library. We won't be doing code cleanup in
there.
Thorsten commented on those already.
This is helper code for integrating CodeMax, a 3rd party library
providing the editor component for the Windows GUI. As we hope to get
rid of that component at the next possible opportunity (it doesn't fit
neatly with our current license), we probably won't be doing much code
cleanup in there either.
