POV-Ray : Newsgroups : povray.programming : Different Objects Server Time
28 Aug 2025 23:02:49 EDT (-0400)
  Different Objects (Message 1 to 7 of 7)
Subject: Different Objects
Date: 27 Jul 2014 12:10:00
Message: <web.53d523da96b2c7506f623e950@news.povray.org>
For Box in POV-ray we have to give only two values i.e. corner1 and corner2 as:
Box
{<corner1><corner2>}
Now I want to draw objects in POV-ray as shown in below links
http://ctrlv.in/363770
http://ctrlv.in/363771
These objects in BRL-CAD came under ARB (Arbitrary Convex Polyhedron).
Which path should I follow to make these four objects in POV-ray?
Subject: Re: Different Objects
Date: 27 Jul 2014 12:30:29
Message: <53d52925$1@news.povray.org>
> Box
For once, I will say "mesh" (or mesh2, it's the same object with a
different syntax).
But that's only the beginning of your problem.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 27 Jul 2014 12:45:07
Message: <53d52c93$1@news.povray.org>
>> Box
> different syntax).
Another approach would be using "intersection" of "plane"s.
Date: 28 Jul 2014 23:10:01
Message: <web.53d710285483635ec373e7b50@news.povray.org>
<snip>
> > different syntax).
I was trying to make arb5 i.e. number 1st object in this link
I use mesh for this object (but can use mesh2 also) as
#declare Red = texture {
    pigment { color rgb<0.8, 0.2, 0.2> }
    finish { ambient 0.2 diffuse 0.5 }
  #declare Green = texture {
    pigment { color rgb<0.2, 0.8, 0.2> }
  #declare Blue = texture {
    pigment { color rgb<0.2, 0.2, 0.8> }
#declare Yellow = texture {
    pigment { color rgb<0.5, 0.5, 0.5> }
mesh
triangle{<0, 0, 0> <2, 2, 2> <0, 4, 0>
  texture {Red} }
  triangle{<2, 2, 2> <4, 4, 0> <0, 4, 0>
  texture {Green}}
  triangle{<2, 2, 2> <4, 4, 0> <4, 0, 0>
  texture {Blue}}
  triangle{<2, 2, 2> <0, 0, 0> <4, 0, 0>
  texture {Yellow}}
Now I am trying to find out how to make face i.e. 1, 2, 3, 4
in above linked screen-shot.
One way is to make plan but its more complex as I have to first calculate the
normal of that plan. Is there any other way in which I make face using at-least
two vertices?
I want to convert BRL-CAD's arb5 model's vertices into POV-ray's vertices, so I
am looking into easiest way for doing it.
Date: 29 Jul 2014 04:19:30
Message: <53d75912$1@news.povray.org>
You can export your model in *.stl and use the stl2pov converter
http://rsmith.home.xs4all.nl/software/py-stl-stl2pov.html
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 29 Jul 2014 05:10:00
Message: <web.53d763db5483635ef9cee77e0@news.povray.org>
Its ok, I tried this. But actually I am making a converter for BRL-CAD i.e.
g-pov which converts BRL-CAD's .g database models directly into POV-ray models.
I want easiest ways so that if model in BRL-CAD is formed by 5 vertices (take it
as example) then it can be converted in POV-ray models by using those vertices.
Date: 29 Jul 2014 05:27:24
Message: <53d768fc@news.povray.org>
If you are not afraid of coincident surface, your object is not textured
with transparency and you do not need inside test, you can use mesh (or
rather mesh2 format) to generate the full set of triangles between all
the vertices.
It's just brute force combinations.
mesh2{
 vertex_vectors {
   5,
   ... // your 5 vertices coordinates here
 face_indices {
   10,
   <0,1,2>,
   <0,1,3>,
   <0,1,4>,
   <0,2,3>,
   <0,2,4>,
   <0,3,4>,
   <1,2,3>,
   <1,2,4>,
   <1,3,4>,
   <2,3,4>
// texture as usual
For N vertices, the number of face is N!/((N-3)!*3!) . (aka C(N,3) )
4 -> 4, 5-> 10, 6-> 20, 7-> 35.
You can use three loops to automatically generate the face indices,
according to N.
If you want a smarter transformation, you need to detect external
coplanar set of more than three points and choose a method to split the
polygon in triangles.
