POV-Ray : Newsgroups : povray.programming : 3D Object intersection tests Server Time
3 Apr 2026 17:10:21 EDT (-0400)
  3D Object intersection tests (Message 1 to 2 of 2)
Subject: 3D Object intersection tests
Date: 27 May 2013 14:15:01
Message: <web.51a3a1b8cb2bcff272bd51150@news.povray.org>
I've been searching through the documentation and haven't been able to find what
I'm looking for.
What are the functions and or tests that provide a means to test if two objects
are in contact, intersect, or whether one is contained by the other ?
Sorry if this is a MTFM.
Subject: Re: 3D Object intersection tests
Date: 27 May 2013 14:34:33
Message: <51a3a739$1@news.povray.org>
Le 27/05/2013 20:11, Steaphany nous fit lire :
> I'm looking for.
Hello,
please notice that povray.programming is not about the Scene Description
Language (SDL) (that's a common misconception, so just to set the ground
for further discussion).
> http://www.povray.org/resources/newsgroups/
Indeed, in the SDL, there is no such capability (IIRC).
In the source code, there is no point in such test either. The code
computes intersections of Ray with Objects, and might (when needed) used
the sorted list of intersections against the Inside test of an Object
(usually to reduce such list to less intersections, to respect the
requirements of CSG).
