POV-Ray : Newsgroups : povray.programming : Really need help for pov ray Server Time
13 Sep 2025 22:47:23 EDT (-0400)
  Really need help for pov ray (Message 1 to 5 of 5)
Subject: Really need help for pov ray
Date: 7 Jan 2013 17:15:01
Message: <web.50eb47bf77c71680cece84010@news.povray.org>
Hi , I am a student user of pov ray . since pov ray is code editor , I want find
a way to build a user GUI,  which can increase the interaction between user  and
the code.
For example, when we modify  the light in a frame, user can through the GUI
type the number rather than go through the pov files .
How should I do ?
Really thanks for your help.
Subject: Re: Really need help for pov ray
Date: 7 Jan 2013 17:50:00
Message: <web.50eb50b9ce52ce9ccece84010@news.povray.org>
> the code.
> How should I do ?
Now my solution is define some parameter in the ini file using ini call for the
pov file , but I want build an interface to control the parameters
Date: 7 Jan 2013 18:01:54
Message: <50eb53e2$1@news.povray.org>
Maybe Moray is what you are looking for:
http://www.stmuc.com/moray/
Date: 7 Jan 2013 18:15:01
Message: <web.50eb5447ce52ce9cdb2fc060@news.povray.org>
> the code.
> How should I do ?
To my opinion, and according to my (somewhat limited) experience, scripting is
far more efficient than modelling with a 'wysiwyg' GUI, unless you use mainly
meshed objects, for which you need a specialized modeller (you can find some
that export meshes to POV-Ray).
To answer your question, perhaps one can use other handy langages, like python
or so, to write a GUI that generates POV-SDL. But I am afraid it would not be
that easy. Not so much easier than getting acustomed to scripting. However, it
would take a non neglectable amount of time to develop because the subject of 3D
is complex and POV-Ray deals with many aspects of it. See the richness of SDL...
Date: 7 Jan 2013 18:19:28
Message: <50eb5800@news.povray.org>
On second thought, you probably mean something like this:
Extend povray by a syntax such as
#parameter X = 5;
#parameter Y = 5;
for parametrizing scenes. This would be like declare but when
a render is started a dialog window opens with a property window
and allowing to change the default parameter values. Only after
clicking ok start the actual render.
But frankly I think it is not so convenient. Probably better to
write a front-end in another language that writes the INI file and
starts POV-Ray.
Note that you can also pass parameters on the command line
when starting povraz (Declare=IDENTIFIER=FLOAT).
