POV-Ray : Newsgroups : povray.programming : Entry point confusion? Server Time
14 Sep 2025 04:22:01 EDT (-0400)
  Entry point confusion? (Message 1 to 7 of 7)
Subject: Entry point confusion?
Date: 23 Feb 2011 15:35:01
Message: <web.4d656eb48c266d86d3fa8b3e0@news.povray.org>
Hi guys.
Quick question. I'm working on pov-ray for my final year project at uni, and am
getting a little lost. I posted a while ago about class diagrams and entry
points and was pointed at the TracePixel::Operator() method, however I was using
3.7 beta at the time. I've now switched down to the current stable release but I
now don't seem to have that class?? Is it a new thing in 3.7 or am I just
missing something?
Also what is the main entry point on windows? I found the povray.cpp which
contains a main method inside an #ifndef but when i attempted to place something
in this (cout for instance) I never saw it so I assume it never got executed.
Any help?
Thanks
Subject: Re: Entry point confusion?
Date: 23 Feb 2011 16:22:37
Message: <4d657a9d$1@news.povray.org>
Le 23/02/2011 21:31, Aidy nous fit lire :
> Hi guys.
> missing something?
Spell it correctly when searching
./source/backend/render/tracepixel.cpp:void TracePixel::operator()(DBL
x, DBL y, DBL width, DBL height, Colour& colour)
(that's in 3.7RC3) (notice the lower 'o', it's a c++ keyword)
If you are looking at 3.6, well, that's a bit of different story.
the local function trace_pixel() is in render.cpp
The source is available for unix (and alike).
For Windows, well... it's windows, and the usual entry point for an
application would be main() as usual for a console application, but
something totally different for the graphical part. (something like
WinMain... or some other sillyness, I just cannot remember from my
traumas with the various Visual Studio... )
Anyway, the virtual front-end is defined in the vfe subpart (and only
unix part is delivered), with a definition of ALTMAIN and its own main().
Date: 24 Feb 2011 09:05:01
Message: <web.4d6665262d7a67ded3fa8b3e0@news.povray.org>
as I say I've already found the operator code in 3.7 but now I'm using 3.6 so
could find it but I've found it all now thanks.
I have another problem though. I've got it compiling and to try and test I've
added some std::cout lines in the code, including the trace_pixel method, but
they never appear anywhere? any way I can get these to be shown somewhere? they
don't show in the output of visual studio and they don't show in a command
prompt :(
> > Hi guys.
> > missing something?
Date: 24 Feb 2011 10:00:23
Message: <4d667287@news.povray.org>
> prompt :(
Nah, you will need another Windows' expert for that one.
std::cout is not really friendly with graphic widgets... may be just
check in your project setting about the application mode (console/...),
it might be as simple as toggling a setting... or not.
Or dive deeper in code and get inspiration from the #debug processing.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 24 Feb 2011 16:15:11
Message: <4d66ca5f@news.povray.org>
GUI application usually don't show an output stream under
Windows but using a pipe sometimes works. Try starting from
command line with "pvengine.exe | more".
Date: 24 Feb 2011 17:12:16
Message: <4d66d7c0@news.povray.org>
>>> test I've
hod
You basically have to invoke AllocConsole() early in your processing for
a
GUI application to not throw away stdout.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 25 Feb 2011 12:35:00
Message: <web.4d67e75b2d7a67ded3fa8b3e0@news.povray.org>
Ah thanks for the help! The | more trick worked :D
