POV-Ray : Newsgroups : povray.programming : How does povray distribute jobs? Server Time
8 Dec 2025 19:52:40 EST (-0500)
  How does povray distribute jobs? (Message 1 to 3 of 3)
Subject: How does povray distribute jobs?
Date: 24 Jan 2011 10:40:00
Message: <web.4d3d9ce399d6562fed1c03580@news.povray.org>
This question is probably best suited for the 3.7 beta, but I do know some have
gotten 3.6.1 working with OpenMPI, so here goes:
How does povray distribute jobs? If there are multiple cores (let's say 3 slaves
and a single master), how are jobs queued and distributed to cores?
For example, core 1 finishes its job and sits idle. There are jobs waiting on
cores 2 and 3 - is the master clever enough to tell core 1 to take up the slack?
Or does the master leave these jobs until the end and process the jobs itself?
Any information on this would be great.
Thanks.
Subject: Re: How does povray distribute jobs?
Date: 24 Jan 2011 12:30:45
Message: <4d3db745@news.povray.org>
Am 24.01.2011 16:39, schrieb Jack Burton:
First of all, to avoid misunderstanding, a few clarifications:
- POV-Ray 3.7 does not assign jobs to cores; it assigns jobs to threads,
leaving it up to the OS to assign those to cores.
- POV-Ray's "back-end" (the portion of code that does the actual
computations) is not based on a master-slave architecture; instead,
there are identical threads, using mutexed access to some shared
ressources. (There is, however, a separate "front-end" thread that
collects the work results. It currently doesn't distribute the jobs though.)
Workload distribution in POV-Ray is actually pretty simple:
- The image to be rendered is divided into tiles, typically 32x32 pixels
in size; the computation of each such tile comprises one job.
- There is only one single job queue, shared by all threads. Whenever a
thread finishes a job, it pulls the next job from the queue (using
mutexing to prevent race conditions or some such).
- As soon as a thread would become truly idle (because there are no jobs
left in the queue), it terminates, so there is actually no such thing in
POV-Ray as an idle render thread (except while waiting for a mutex or
some such of course).
- The tiles are the smallest work units there is, so it may happen that
one thread is still busy computing a particularly "expensive" tile,
while the other threads have already terminated due to lack of work.
Date: 25 Jan 2011 11:35:00
Message: <web.4d3efb28456e245eed1c03580@news.povray.org>
Thanks, that's a lot of help.
I'll post back here if I have any more questions.
