POV-Ray : Newsgroups : povray.programming : easy way to do a baseball field? Server Time
11 Jan 2026 04:51:21 EST (-0500)
  easy way to do a baseball field? (Message 1 to 3 of 3)
Subject: easy way to do a baseball field?
Date: 6 Sep 2010 23:00:01
Message: <web.4c85a9c21a759ffdb295fc90@news.povray.org>
i was looking for an easy way to do a baseball field like this one:
http://www.proschoice1.com/images/baseball_field.gif
any advice is welcome.
thanks..
Subject: Re: easy way to do a baseball field?
Date: 10 Sep 2010 14:50:00
Message: <web.4c8a7cadc6cded8cd939a6800@news.povray.org>
I was going to suggest object pigment(s) until I tried it and failed the
attempt.  :)
Here's what I finally did instead. Needs rescaling to be correct measurements
for a real field. I didn't consider thickness either, just wanted all parts to
show. Originally was making a pigment pattern for a flat plane anyhow. I haven't
used POV for that purpose in uncounted years, maybe somebody else has answers.
Also, you would want to think about how to go about doing real
dimensions/measurements. I chose not to use actual numbers of feet/meters for
this, only going for a likeness of the drawing you gave, otherwise I might have
done this minus the 45 degree angle first so as to have axial distances then
afterward rotate the field (if you understand my meaning).
// baseball field (needs much adjusting)
//cmd:+w400 +h350 +a0.2 +r4
camera
 orthographic
 location <0,1111,88>
 look_at <0,0,88>
 up 350*z
 right 400*x
#declare BBFP=
union // baseball diamond
union  // dirt
 box
  <0,-0.01,0>, <200,0,200>
  rotate -45*y
  translate -88*z
 cylinder
  <0,-0.1,-69>, <0,0,-69>
  18
 pigment {rgb <0.7,0.5,0.3>}
 finish {ambient 1}
} // end dirt
difference // infield grass
 box
  <-45,0.01,-45>, <45,0.01,45>
  rotate 45*y
 sphere
  0,
  11
 sphere
  -63*z,
  15
 sphere
  <-60,0,0>,
  12
 sphere
  <60,0,0>,
  12
 sphere
  <0,0,60>,
  12
 pigment {rgb <0.1,0.5,0.2>}
 finish {ambient 1}
} // end infield
 difference // outfield grass
  sphere
   0,250
   scale <0.88,1,1>
  sphere
   0,90
  box
   <0,-0.1,0>, <360,0.1,360>
   rotate -45*y
   translate -88*z
   inverse
 finish {ambient 1}
 } // end outfield
 union // bases
  box // 1st
   -1,1
   scale <2,0.1,2>
   rotate 45*y
   translate <67,0,0>
  box // 2nd
   -1,1
   scale <2,0.1,2>
   rotate 45*y
   translate <0,0,67>
  box // 3rd
   -1,1
   scale <2,0.1,2>
   rotate 45*y
   translate <-67,0,0>
  difference // home
  box
   -1,1
   scale <2,0.1,2>
  box
   -1,1
   scale <3,0.11,3>
   rotate 45*y
   translate 2*z
   inverse
   translate <0,0,-67>
  box // pitch
   -1,1
   scale <2.5,0.1,0.75>
   translate <0,0,2>
  pigment {rgb 1}
  finish {ambient 1}
 } // end bases
 union // lines
  box
   0,1
   scale <0.8,0.15,260>
   rotate -45*y
   translate <-9,0,-62>
  box
   0,1
   rotate 45*y
   translate <9,0,-62>
  difference // batter's box
   box
    -1,1
   box
    -1,1
    scale <0.8,1.1,0.8>
   scale <3,0.15,5>
   translate <-6,0,-67>
   box
    -1,1
   box
    -1,1
    scale <0.8,1.1,0.8>
   scale <3,0.15,5>
   translate <6,0,-67>
  pigment {rgb 1}
  finish {ambient 1}
 } // end lines
} // end baseball diamond
object {BBFP}
Date: 10 Sep 2010 14:55:00
Message: <web.4c8a7e40c6cded8cd939a6800@news.povray.org>
Can't believe I just replied into programming with that CSG example!
Sorry all. Been too long since posting anything, and especially using web
interface. I was looking at the most recent digest and not paying attention to
where I was.
Lester, please ask about this in povray.general not here.
