POV-Ray : Newsgroups : povray.programming : Computationally intensive parts of POV-ray? Server Time
8 Dec 2025 19:53:57 EST (-0500)
  Computationally intensive parts of POV-ray? (Message 1 to 4 of 4)
Subject: Computationally intensive parts of POV-ray?
Date: 16 Mar 2010 19:30:01
Message: <web.4ba0144391591f2aa3b6170e0@news.povray.org>
Hello,
I'm trying to locate portions of POV-ray that bottleneck performance so that I
can try and offload some of POV-ray's workload onto a hardware accelerator.  I'm
just trying to see how fast I can get POV-ray to run by programming an FPGA to
accelerate certain portions of the code, but I'm finding it hard to locate in
the source.
Thanks!
-Michael Poon
Subject: Re: Computationally intensive parts of POV-ray?
Date: 17 Mar 2010 03:39:40
Message: <4ba0873c$1@news.povray.org>
> the source.
The bottlenecks for POV-Ray that best fit into hardware are the same as for
any other ray-tracer: The bounding. It is uniform and simple (for hardware)
and can easily be solved in parallel. You can find various SIGGRAPH papers
(early to mid 2000s) on real-time ray-tracing that also covered or
referenced hardware BSP algorithm implementations.
	Thorsten, POV-Team
Date: 25 Mar 2010 17:50:00
Message: <web.4babd960fe47c66a7c6dd4d00@news.povray.org>
> > the source.
>  Thorsten, POV-Team
Hmm, ok, I figured it would be that or calculating intersections.  The thing I
need help on though is figuring out where to plug in my hardware into the
source.  So looking through the source, I'd take a guess that most of the
computation is done in render.cpp, but a lot of it seems boilerplate and I'm
having a difficult time trying to find where all of the computation is being
done.  If you could point me to certain functions, I'd appreciate it greatly.
Thanks!
Michael
Date: 26 Mar 2010 02:59:39
Message: <4bac5b5b@news.povray.org>
If you need a well documented source code, you might be better off doing
your project as an extension to the PBRT Ray-Tracer (www.pbrt.org), which is
actually part of the book with the same name.
Otherwise you will need to take a look at the
source/backend/support/bsptree.cpp source file and how it is tied into
POV-Ray 3.7.
	Thorsten
