POV-Ray : Newsgroups : povray.programming : Simple way to make POV-Ray for windows work in command line mode Server Time
10 Nov 2025 19:38:01 EST (-0500)
  Simple way to make POV-Ray for windows work in command line mode (Message 1 to 8 of 8)
Subject: Simple way to make POV-Ray for windows work in command line mode
Date: 1 Dec 2009 03:05:00
Message: <web.4b14cd5db06b1c31384d1150@news.povray.org>
Hello,
I just wanted to share how I solved the problem of making POV-Ray work in
command line mode in windows.
I added another windows command line switch "/CMDMODE" by adding a boolean
variable "command_line_mode" and the following code in pvtext.cpp:
if (stricmp (commandstr, "CMDMODE") == 0)
        command_line_mode = true ;
        while (*s == ' ')
          s++ ;
        continue ;
In pvengine.cpp I added the following piece of code after the "switch
(placement.showCmd)" part:
placement.showCmd = show_state ;
if (command_line_mode) {
    placement.showCmd = SW_HIDE;
I also removed the splash screen completely but you can test for
command_line_mode there as well I guess.
Subject: Re: Simple way to make POV-Ray for windows work in command line mode
Date: 1 Dec 2009 13:04:24
Message: <4b155aa8$1@news.povray.org>
Which makes that version violate the POV-Ray license if you distribute it.
	Thorsten, POV-Team
Date: 1 Dec 2009 18:35:00
Message: <web.4b15a71a2f1f1b7d1384d1150@news.povray.org>
>  Thorsten, POV-Team
Yes, I know, but I just wanted to share this little piece of information if
anyone finds it useful. I am not going to distribute it, I will just use this
feature personally for calling POV-Ray from a Java program.
It is a bit difficult for me to understand why the windows version doesn't have
support for using it from the command line. I mean, it has this great editor
that the other versions don't have but doesn't have the command line mode which
was the original "spirit" of POV-Ray.
Don't get me wrong here, I really support that you protect this great piece of
software but I really can't understand this particular design decision.
Date: 1 Dec 2009 19:06:00
Message: <4b15af68@news.povray.org>
It does. I invoke it from C#. I don't really follow why you think it
doesn't.  Yes, it *also* opens a window, if that's what you mean.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 1 Dec 2009 19:29:16
Message: <4b15b4dc@news.povray.org>
> have support for using it from the command line. I mean, it has this great
> editor that the other versions don't have but doesn't have the command
> line mode which was the original "spirit" of POV-Ray.
You can compile POV-Ray without any GUI support at all. It behaves the same
as the Unix version (except that, as far as I know, it won't even have a
preview window). No need for any code change.
Last I checked, it was just another target in the Visual Studio solution.
Date: 2 Dec 2009 07:05:01
Message: <web.4b1656e72f1f1b7d1384d1150@news.povray.org>
That was what I meant... I intend to call several separate instances in
parallel, which makes multiple windows appear all the time.
I am currently exploring that other target in Visual C++
Thanks!
Date: 2 Dec 2009 10:10:00
Message: <web.4b1682d22f1f1b7d1384d1150@news.povray.org>
I have struggled with nmake and the provided makefile.vc, which seems to have a
USE_GUI option (which I guess that you meant by target?), but eventually, after
two hours of frustation, I decided that its not worth the trouble.
I guess that my first ugly hack will have to do :(
Date: 3 Dec 2009 07:30:01
Message: <web.4b17ae8a2f1f1b7d1384d1150@news.povray.org>
I downloaded the beta source which seems to have more targets. I'll give it
another go!
And I am sorry for my previous, very depressing post :)
Thanks for all the help so far!
